Welcome to the North American Subaru Impreza Owners Club Sunday February 1, 2015
Old 08-13-2010, 12:43 PM   #1
superfasteddie
Member#: 95394
Default Bugeye Window Issues. Help...
03 bugeye sedan. My driver window is the only one that works properly. Up + down all the time with no issues. Passenger front will go down fine and ONLY go up with lots of coaxing, pulling, etc. Passenger rear is the same story, takes lots of work. Driver rear is defunct all together = fail. Stuck down. I don't hear any clicking, motor noise or anything. I keep running my battery down trying to mess with all of them. I got a replacement passenger front switch to fix the front but it didn't do a damn thing. Is my master switch gone? I've searched, I've messed with it. Any ideas? How do you know if it's a regulator vs switch issue?
Thanks
superfasteddie is offline   Reply With Quote
Old 08-16-2010, 04:20 PM   #2
superfasteddie
Member#: 95394
Nothin? Nobody?
Old 11-22-2010, 06:27 PM   #3
Buurma
Member#: 258394
2001 GC8
Pear black
figure anything out? sounds to me your passenger side motors could be weak or the window track could be full of gunk. as far as the rear drivers window i'd check wire connections
Testing switches is simple, find a Ohm meter and see if there is any continuity when you press the switch.
Buurma is offline   Reply With Quote
Old 11-22-2010, 08:54 PM   #4
Jncominco2
Member#: 170212
02 WRX Sedan
MBP
does it do the same thing from the window switch itssself? not the main one?
if it does it on the main one and the individual one, its probably grease/motor problem. check the tracks
if it only does it on one and not the other, its the switch
Jncominco2 is offline   Reply With Quote
'02 WRX wagon driver window issue doridori Service & Maintenance 14 09-04-2012 11:53 AM
Front left power window issue Pines Electrical & Lighting 13 10-09-2010 03:58 PM
Need help..JDM HID headlight installed on bugeye..getting issues.. bhluv Electrical & Lighting 15 10-14-2008 06:28 PM
Drivers Side Window Issue Laugh Damon Electrical & Lighting 3 12-05-2007 02:53 PM
2001 impreza - power window issues BaylorRS Texas Impreza Club Forum -- TXIC 2 11-11-2007 10:39 PM
