Old 08-13-2010, 07:17 PM   #1
drumzzzzz
Member#: 157994
2003 WRX
Sedona Red
Default 97-98 EJ22 n/a with EJ22T pistons/cams
has anyone ever succesfully fit EJ22T factory pistons or cams to a 97-98 EJ22 n/a engine?
Does the newer piston pin and diameter changes cause problems? Also will turbo cams work with the roller rockers?
drumzzzzz is offline   Reply With Quote
Old 08-13-2010, 08:43 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
That's a lot of labor to drop the compression ratio. Are you still using the stock 2.2l heads?
If so, that's your real problem. Get some DOHC Ej25 heads and both your problems go away at once. You get 8.6:1 compression and heads that flow like the wind. It's a much better approach with much better results.
Old 08-13-2010, 09:00 PM   #3
drumzzzzz
Member#: 157994
2003 WRX
Sedona Red
I was reading about the DOHC head swap, however some said that things don't line up quite right (gaskets, combustion chamber ect ..) Would it be easier to just swap an EJ20 before that?
It seems the N/A EJ22 boosters like the later SOHC heads for the larger valves and roller rockers, and the engine would be getting a full teardown/rebuild anyways for a piston swap.
Old 08-13-2010, 09:16 PM   #4
turbo01gc8
Member#: 217973
2001 turbo impreza L
acadia green
trying to find out same with 01 2.2L. do they fit? also heard that sohc is the way to go
turbo01gc8 is offline   Reply With Quote
Old 08-13-2010, 09:47 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
There's theoretical and then there's practical. Those talking theory go on about quench area and coolant passages in the head gasket, etc. etc. Practical people build the engine and sees if it overheats or has detonation issues from those theoretical ideas.
What I am getting at is I am not someone who just passes on things I don't know to work from firsthand experience and exposure. I've built this engine and run it. A local friend built this engine on his '01 OBS and ran it around close to 1 bar of boost from a turbo the size of an 18G for close to 50k mile before he blew it up on purpose. He wanted to see the limit, so he took it to the drag strip and kept turning the boost up in 1psi increments until he broke something.
If you want to use SOHC Ej25 heads, go for it. They flow great as well. The DOHC heads are so nice because they can so easily be converted to cool and oil the turbo. It's a bit more work on the SOHC but they will work well too. It's up to you, but for someone with a Phase I engine and electronics I would suggest the DOHC and for someone with the Phase II engine and electronics I would go SOHC. It's easier to set up and run with a piggyback on the stock ECU that way.
Old 08-13-2010, 11:27 PM   #6
drumzzzzz
Member#: 157994
2003 WRX
Sedona Red
Which gasket do you use for the swap? It does sound like a far easier way to reduce compression, and still run N/A cams, not to mention a 97/98 DOHC ecu is basically plug in play.
Old 08-14-2010, 09:09 AM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
I use the gasket for the block. So phase I Ej22, thick phase I ej22 gasket. For phase II ej22, use thin phase II ej22 gasket.
Old 08-16-2010, 12:41 AM   #8
drumzzzzz
Member#: 157994
2003 WRX
Sedona Red
appreciate all the info, it's helping narrow down the turbo build options.
Old 08-16-2010, 12:07 PM   #9
turbo01gc8
Member#: 217973
acadia green
so if we use 2.2 block with 2.5sohc, which timing belt do we need? which years are phase1 and 2?
Old 08-16-2010, 03:51 PM   #10
Matt Monson
Member#: 832
99 2.5RS, '85 911
Timing belt always matches the heads.
Old 08-16-2010, 05:30 PM   #11
rsfc3s
Member#: 253967
99 impreza
i have the ej22t pistons, rods, and cams if you need them! I have the complete motor and wiring if you need any extra stuff. Good luck with the build.
rsfc3s is offline   Reply With Quote
Old 08-16-2010, 07:20 PM   #12
thorne
Member#: 130063
2003 WRX
Silb
I'm thinking about doing STi Rods + EJ22t Pistons in my next build.
thorne is offline   Reply With Quote
Old 08-21-2010, 01:58 AM   #13
cgannon
Member#: 255486
k, so i dont have enough posts in order to start a thread to ask this, but i have a 97 impreza, 2.2. and i'd like to turbo it, but dont have the slightest idea where to start. i know u need to lower the compression, but the engine has 228k ... soo where do i start guys? 16 yrs old, not making a lot of money, 2-3 grand tops. goal is 220+ hp. please, anything is better than the nothing that i have now.
cgannon is offline   Reply With Quote
Old 08-21-2010, 10:58 PM   #14
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Re-read post #2. If you dont want to spend alot of money, buy a set of either DOHC or SOHC EJ25 heads. They usually fetch about $250-$350 a pair, depending on condition. I would replace the valve stem seals, cam seals, and maybe lap the valves if you feel like it.
Grab a set of EJ22E headgaskets, a rear main seal and front crank seal along with a Haynes manual for your car, follow the directions to bolt the heads onto your block. Install motor and be happy, look for stock turbo parts from wrx's upgrading. Your going to need engine management, injectors, turbo engine crossmember(or cut yours and reinforce it). This is not everything you will need, just stuff off the top of my head.
Do alot of searching on the subject to get a feel if you really want to do this or not.
~Josh~
Old 08-22-2010, 11:32 PM   #15
cgannon
Member#: 255486
Thanks so much! next noobie question.. where can i get these parts? and if any1 else can think of anything else i'll need to do this, please let me know. its an "open deck" apparently, some say this is a bad idea, others say it doesnt matter open or closed.. i think i'm gonna go for it and see what happens, moneys made for spending right? haha
Old 08-23-2010, 12:15 AM   #16
ballitch
Member#: 74907
98 cam'd EJ251
The for sale forum is a good place to start, also Ebay.
As far as the open deck issue, it's fine to boost it. As long as the tune is good, it should take a decent amount of power before it pops. If it does take a crap on you, buy another one out of a junkyard for $100 and rebuild it.
~Josh~
Old 08-24-2010, 07:20 PM   #17
Matt Monson
Member#: 832
99 2.5RS, '85 911
Get to know the locals by hanging out in your regional forum and checking the classifieds there.
And when you hit the junkyards look for 91-94 Legacy turbos. They are a great source for conversion take off parts. You might even score an Ej22T closed deck block that the junkyard doesn't know is special. I paid $100 for my first Ej22T longblock. I was so excited when I found it in that car and asked what they wanted for it. Their system made no distinction between turbo and non-turbo longblocks and since all the turbo stuff was gone they didn't even know it was a turbo. I got the engine for $100 and the crossmember for another $25.
Old 06-04-2012, 02:08 PM   #18
Joshsmiley55
Member#: 297223
95 Impreza Coupe
Green
would the compression from an 97 ej22 with ej22t pistons work with a set of sohc 2.5 99 rs heads? i canr figure out the compression for the ej22 with ej22t pistons.
so i can only do one thing. either the ej22t pistons or either the 2.5rs heads.
im doing a turbo setup with just a td04.
i really want the ej22t pistons and rods because they are forged, but if i go with the 2.5rs heads i can push more psi because better flow.
also i port and polish all of my own heads so im pretty sure that effects compression as well.
if anyone can pm me and point me in the right direction that would be amazing!
Joshsmiley55 is offline   Reply With Quote
Old 06-04-2012, 07:54 PM   #19
69subaru360
Member#: 159682
1995 WRX
2015 F150
EJ22T pistons are cast not forged and EJ22T rods are the same as any other EJ engine except the newer STI.
You'd be wasting your time with them.
Old 06-04-2012, 11:31 PM   #20
Joshsmiley55
Member#: 297223
95 Impreza Coupe
Green
ok thats why you post stuff on forums! thank you! i hate false information =/
dont the ej22t pistons put out a lower compression ratio?
Old 06-05-2012, 08:35 AM   #21
69subaru360
Member#: 159682
1995 WRX
2015 F150
Yeah too low, like 7.5:1
Old 06-07-2012, 12:26 AM   #22
ballitch
Member#: 74907
98 cam'd EJ251
Stock EJ22T CR is 8.0:1 Which is exactly what you would get if you swapped EJ22T pistons into your block, since the heads have the same chamber volume, and the crank and rods are the same.
AFAIK, no Subaru has ever came from the factory with forged pistons...AFAIK, all Subaru cranks are forged.
If I were you, I would do what Monson said, "if phase 1, use DOHC EJ25 heads, if phase II, use SOHC EJ25 heads."
You have a phase 1, BTW.
~Josh~
Old 06-07-2012, 01:57 AM   #23
69subaru360
Member#: 159682
1995 WRX
2015 F150
A few of the older jdm stis did. V7 and a select few GC ones like some of the RAs.
Old 06-08-2012, 12:03 AM   #24
ballitch
Member#: 74907
98 cam'd EJ251
Good to know, thanks.
~Josh~
Old 10-31-2012, 09:21 AM   #25
97ej22e
Member#: 327710
1999 Impreza OBS
Green
I've been in the process of building what some of you are talking about. I have an ej22e short block and I am putting on ej25d heads and ej22t pistons. Best part about the dohc heads (as mentioned above) is that they have an oil feed for the turbo, and you can drill into them for the coolant (either the return or supply I am not sure) and the oil return. I talked to a master mechanic about the compression ratio and he said if I am near 7.5:1 compression ratio it will be safe to run a good amount of boost. I could care less about off the line power. I don't plan on launching my car or trying to race from a dead stop, don't feel like replacing my transmission.
97ej22e is offline   Reply With Quote
Stock cam specs and interchangability- 97 2.5 heads with 04 STi cams? boostedballs Built Motor Discussion 5 05-11-2010 12:10 PM
Mechkiller31st's 98 EJ22 getting swapped with 94 Ej22T Mechkiller31st Subaru Conversions 3 04-25-2010 05:55 PM
help with timing specs for 97 impreza ej22 paul power Newbies & FAQs 2 04-17-2009 03:13 AM
97-98 impreza 2.5 pistons in a 2004 block? upjeeper Built Motor Discussion 4 11-17-2007 03:47 PM
Wanted: Dyno sheets for a STOCK 97-98 and 99-01 EJ22 Harmonix Proven Power Bragging 0 12-14-2005 06:42 PM
