Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Vancouver Impreza Club
Old 08-14-2010, 05:27 AM   #1
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
Default Motor swap issues! Thoughts???
ej22 swap from the brat USED to run like a top. Now that i'm trying to get the old brat up and running again it is giving me issues. Need some input to see if I'm missing anything.
Motor is a 1990 auto legacy ej22. Wiring has been stripped and reduced to a 'stand alone' system. Stock everything except the air box, exhaust, and fuel pump.
Car will start and run PROPERLY but will die ~5 seconds after starting.
I have checked/changed the maf, IAC, ecu, main relay, fuel pump relay, cam sensor... list continues...
I have also cleaned ALL of my engine/ecu powers and grounds. Confirmed my voltages at 4 of the ecu powers, injector, coil, TPS all giving the same results. (13.5v priming, 12v cranking, and 14v running)
Checked continuity between the ecu and the tps, IAC, maf, and cam sensor.
also checked my fuel pressure (remember this is an n/a motor) and i have 40psi at prime and 30-35 while running.
pressing the throttle makes it bog.
please give me some thoughts and ideas to what it could be.
Full troubleshooting overview can be found here:
http://www.ultimatesubaru.org/forum/...505#post947505
Zefy is offline   Reply With Quote
Old 08-14-2010, 04:45 PM   #2
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Have you checked to see if your ECU is getting the proper readings from the TPS, idle sensor and MAP?
minifreak is offline   Reply With Quote
Old 08-14-2010, 05:21 PM   #3
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
I'm not sure what they are supposed to be, so no i have not. I've confirmed that they are getting power, but if it is a 'correct' signal, i'm not sure.
I have a perfect power 6 but it's only got the rpm and tps connected to it so far. (just tapping in to the signals)
what should the tps, maf, and IAC be producing?
Old 08-14-2010, 07:48 PM   #4
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
It should produce change in voltage as the sensors goes through it's ranges. On an OBDII car the best way to check would be to hook the car up to a laptop and see those values in realtime.
On Loomin's engine we weren't getting proper TPS values from the ECU, after some trouble shooting we tracked it down to the difference in wiring harness causing the ECU not receiving the proper signals.
Old 08-14-2010, 09:53 PM   #5
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
now we fixed it by simply re-pinning the harness corectly, break in is finished and it rips like a ****ing animal! too bad my gay stock clutch cant hold worth ****. **** me i have to change that too!.
Loomin is offline   Reply With Quote
Old 08-14-2010, 11:40 PM   #6
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
this is not an obd2 engine. obd1 is all i got. and my blinky light shows everything is working 'correctly'.
tried a few other things like bypass the fuel pump relay and main relay giving them both their own battery. so i know everything is getting power.
tried unplugging the maf and tps while in these states and nothing happened.
i also found a pin that is a 'california identifier' pin on the ecu. this is not supposed to be grounded but it was. This, now that i'm thinking about it, doesn't make sense because it is routed right to a ground from the get go meaning it was grounded in the old legacy it was in for the first ~18 years of its life... Anyways... didn't make a difference...
Also sounded like the fuel pump was struggling a bit while it was pumping (because i bypassed the relay i didn't prime anymore, just on all the time) so i put another 5 liters in it and it smoothed right out. wouldn't it be nice if it turned out i just didn't have enough gas? well it wasn't that easy i guess because it stayed the same. My fuel pressures are a little more smooth now but i still see the same results.
what the hell is going on...? i've got it running SUPER smooth then it's like somebody is jacking my keys 5 seconds later.
Old 08-15-2010, 04:27 AM   #7
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
put more than 5L in it.
Old 08-15-2010, 08:32 AM   #8
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
I put an extra 5L in it. Giving it about 12 total... Its only a 30L tank.
Old 08-16-2010, 03:35 AM   #9
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
hmmmmm.... hows the coil?
JDM FXT Motor Swap into 02' WRX Cam Position Sensor Issue dailo13 Subaru Conversions 14 08-18-2009 04:40 PM
Need more info for sti motor swap - hvac, motor and so on. hybrid gti 2 Subaru Conversions 4 09-29-2008 11:41 PM
dash swap and motor swap questions aka_tur Subaru Conversions 6 02-27-2007 06:21 PM
Hypothetical...swapping cams when doing motor swap kaisersouse Normally Aspirated Powertrain 0 04-14-2006 08:54 AM
Tiny det issue. Thoughts? Davenow Engine Management & Tuning 16 09-29-2005 11:01 PM
