Old 08-14-2010, 04:31 AM   #1
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
Default Engine swap issues. Need some input!
ej22 swap from the brat USED to run like a top. Now that i'm trying to get the old brat up and running again it is giving me issues. Need some input to see if I'm missing anything.
Motor is a 1990 auto legacy ej22. Wiring has been stripped and reduced to a 'stand alone' system. Stock everything except the air box, exhaust, and fuel pump.
Car will start and run PROPERLY but will die ~5 seconds after starting.
I have checked/changed the maf, IAC, ecu, main relay, fuel pump relay, cam sensor... list continues...
I have also cleaned ALL of my engine/ecu powers and grounds. Confirmed my voltages at 4 of the ecu powers, injector, coil, TPS all giving the same results. (13.5v priming, 12v cranking, and 14v running)
Checked continuity between the ecu and the tps, IAC, maf, and cam sensor.
also checked my fuel pressure (remember this is an n/a motor) and i have 40psi at prime and 30-35 while running.
pressing the throttle makes it bog.
please give me some thoughts and ideas to what it could be.
Full troubleshooting overview can be found here:
http://www.ultimatesubaru.org/forum/...505#post947505
Zefy is offline   Reply With Quote
Old 08-14-2010, 03:09 PM   #2
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
Stupid question time...
Are the fuel and return lines running to the correct places?
Just last week I got them mixed up upon re-installing an engine and quickly realized my error. The symptom was exactly as you describe.
PhilSine is offline   Reply With Quote
Old 08-14-2010, 04:17 PM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
That's a good one, Philsine, and not something I would have ever thought to ask.
I've got nuthin'.
Old 08-14-2010, 04:24 PM   #4
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
i think they are in the right place. if memory serves me correctly (i don't have access to the car) it should be the feed line on the top, return line in the middle, and vent on the bottom. Correct?
Old 08-14-2010, 04:51 PM   #5
Chi_San
Member#: 53558
2002 WRX Wagon
How much fuel pressure are you getting at your fuel rail? If that is fine, then honestly, it's time to check your vacuum lines.
Chi_San is offline   Reply With Quote
Old 08-14-2010, 10:46 PM   #6
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
i am getting 40psi after priming, and about 30-35psi while running... this should be plenty for a an n/a ej22 no?
Old 08-14-2010, 11:03 PM   #7
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Looking at the other thread, you say that you had the IACV on/off, has it been recalibrated?
Need some input on engine build kromHASaWRX Mid Atlantic Impreza Club -- MAIC 11 02-13-2010 11:39 PM
need some input on a coilover issue kon dog Southern California Impreza Club Forum -- SCIC 20 12-31-2008 04:03 AM
Engine not running right; need some input Texasrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-04-2006 07:51 AM
May need a new(er) laptop. Need some input. wizzman New England Impreza Club Forum -- NESIC 21 10-29-2005 02:47 AM
having vacuum/lean run issue...need advice/input Homemade WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 06-08-2004 07:21 PM
