Old 08-14-2010, 04:43 PM   #1
huzidada
Member#: 241360
2002 JDM V7 STI
Default EJ207 Build- EJ257 Block- Project Complete Pg3
Hi Guys.
Si I have a 2002 JDM EJ207 STI and I have had the motor rebuilt 2000miles ago. However my motor has sprung a bearing. The car is running the stock VF30 turbo. Mods are as follows...
Mods- 1. Manley Pistons- 92.5 mm
2. ACL Bearings main and rod
3. Cosworth Cometic gasket
4. ARP Rod bolts
5. Turbosmart E-Boost Controller
6. Walbro Fuel Pump 255lph
7. Spec Clutch Stage 3+ Carbon Kevlar
8. Injen intake
9. ECUTek. 175wkw @ 1bar. 200wkw @ 1.3bar
10. Full exhaust system
Now I know, this is a daily driver, and I tend to see WOT everyday, low boost, and basically drive the car hard. I thought my motor would last but low and behold, bearings ran. Oil level perfect, pump perfect, pick-up perfect, so it leads me to believe clearances were not that good. Anyway, when doing the rebuild, what can I do to prevent a spun bearing especially with my WOT daily driving( dont plan to change th VF30-Just want a quick daily)
My friend is an engineer and we have decided to do this motor ourselves.
What do we expect to replace when doing the build( besides the dameged internals-duh? What do we have to make sure to clean? Any chance of me finding the proper torque specs and clearances for the V7 EJ207? What do you guys think about clearances for rod bolts, since we used stock size ACL bearings ?
Any help would be greatly appreciated.
Update 01-09-2010
I believe this was the worst motor ever assembled---the guy was useless. Using a cheap silicone all round.
The bearing damage also happened in 3rd cylinder. The same one that detonation occured a damaged my piston. Guess there was something wrong there as well.
Last edited by huzidada; 08-05-2011 at 08:54 AM. Reason: Updated- Project Completed
huzidada is offline   Reply With Quote
Old 08-14-2010, 04:47 PM   #2
illmatic
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
Sorry to hear your motor go, what weight oil were you using? Since its your DD how about using the 79mm crank for more displacement.
illmatic is online now   Reply With Quote
Old 08-14-2010, 05:08 PM   #3
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
contact [email protected] and see if he'll help you out with the torque specs and build specifics...
maxpowr is offline   Reply With Quote
Old 08-14-2010, 05:16 PM   #4
huzidada
Member#: 241360
2002 JDM V7 STI
Well I was using Castrol Edge Sport 10w60 Fully Synthetic because it was recommended by my engine builder. However the car ran in(driven in) with the fully synthetic and I think that was a big no no!!!
If I go with the 79mm crank what else am I looking to change? And dont I lose my 8k rev limit if I change the crank?
Old 08-14-2010, 09:06 PM   #5
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
Big NO NO on the synthetic oil for break in...
If you get a 79 mm crank you need pistons with raised pin height...
You should also change your engine builder...
-soobaviator
soobaviator is offline   Reply With Quote
Old 08-14-2010, 09:56 PM   #6
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
spun bearing shouldn't happen from synthetic break-in, should it?
60wt oil with stock sized ACLs sounds like more of a culprit than synthetic break-in oil.
With a vf30 car, stock clearances are fine, but I'd be a lot more comfortable with 0W40, which is a viscosity also available in Castrol Edge Sport if that's the oil you like.
Concillian is offline   Reply With Quote
Old 08-15-2010, 12:00 AM   #7
AQ Motorsports
Member#: 60836
2006 Mod Class STI
TIMEATTACK!!
do you have an oil pressure gauge on the car?
was the oil cooler clean/new?
AQ Motorsports is offline   Reply With Quote
Old 08-15-2010, 04:14 PM   #8
huzidada
Member#: 241360
2002 JDM V7 STI
Nope the oil cooler was never changed. What about the AVCS..is that hard to clean? Where else is it important for me to clean?
My crank has these slight wear marks on them, but it looks ok..will post pics soon...Will the crank still be able to spin to 8kRPM(is is a JDM crank afterall) if I send it to the engineers or is it better for me to get a new crank( can get one from Japan..about $450) but will have to wait 4weeks for it.
If I go with the 79mm crank, can I go for the EJ257 one? But If so do I have to get it treated to spin to 8krpm? I will stroke it to 2.2L correct?
Im a bit concerned about blow-by. There is no damage to my pistons or cylinder walls(if thats where the pistons move). Will a pressure test show blow-by? Can I physically inspect the rings to know if they have set well? Dave from Rallispec is a bit concerned with Manley Pistons, and since they still new, I dont just wanna change them out.
Old 08-15-2010, 05:37 PM   #9
illmatic
Member#: 3536
Yes the 79mm crank is from the EJ257 part number 12200AA430 (Subaru STi Nitride-treated Crankshaft )
Old 08-15-2010, 06:14 PM   #10
huzidada
Member#: 241360
2002 JDM V7 STI
Cool, but will it spin reliably like the EJ207 crank to 8K?
For me, since the dollar is 8 times more than my currency, getting a billet EJ257 crank is too expensive, and I dont think the OEM EJ257 will be up for the job.
Old 08-15-2010, 10:36 PM   #11
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
if the motor blew up before, its definitely possible you had some debris still in your original oil cooler. I'm assuming you got a new oil pump when it was rebuilt, if not that is also a place for lots of junk to hide and ready to trash your motor. The AVCS works off the oil pressure, you can take off the oil feed lines and flush them with carb cleaner as a precaution.
fastnoypi is offline   Reply With Quote
Old 08-15-2010, 10:42 PM   #12
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i would never use an oil cooler over from a blown motor. i have had friends have has cleaned them throughly and still had failure. not worth the risk. please trash that old cooler.
Old 08-15-2010, 10:47 PM   #13
huzidada
Member#: 241360
2002 JDM V7 STI
Besides the oil cooler, what else should I change?
Old 08-16-2010, 03:13 AM   #14
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
I'd stick with the stock crank, the ej207 was designed much better then our american ej257 motor. Keep things how OEM designed them.
I'd run OEM head gaskets. Make sure to get the heads cleaned by machine shop if thats even possible. Before you install your oil pan double check for any particles of crap in there. Maybe replace your turbo oil and return lines or make triple sure they are cleaned to perfection.
Run a non-synthetic for at least the first 1000 miles. Weight would depend on your clearances.
Get an oil pressure gauge!!!
project_skyline is offline   Reply With Quote
Old 08-16-2010, 07:14 AM   #15
huzidada
Member#: 241360
2002 JDM V7 STI
Thanks for all the responses! I have decided to get a new ej207crank and since one of the conrods are gone, replace all the sti ones with manley rods to match the pistons:-) since im using a new oem crank, I dont know if I should run the std size acl bearings, the race acl bearings thats a bit 'looser', or run oversized bearings? Also, instead of getting a new oem oil cooler, I have a nice 16row and a 10row setrab oil cooler lying around( well the 10row was on my sr20). Can I remove the oem oil cooler and run a sandwich with built in thermostat? I also see there are sandwich adapters that dont have a thermostat but a valve inside them or something. Which to get?
Old 08-16-2010, 10:10 AM   #16
huzidada
Member#: 241360
2002 JDM V7 STI
Oh, and most important of all, especially since I have a high rev engine, should I go for the expensive cosworth pump or are one of the STI pumps capable of doing the same thing? Also I dont want to fiddle with the oil pump(adding shim etc)
Old 08-16-2010, 10:18 AM   #17
huzidada
Member#: 241360
2002 JDM V7 STI
Old 08-16-2010, 10:03 PM   #18
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
the stock oil pump spec that came originally with the v7 motor is fine. I dont think you would need an external oil cooler if you were daily driving it. If you were tracking it then that would be another story. Cold oil is really bad on the motor.
Old 08-16-2010, 11:09 PM   #19
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
you can buy an oem jdm 12mm oil pump through rallispec. yes i did say 12mm.
Old 08-17-2010, 08:25 AM   #20
huzidada
Member#: 241360
2002 JDM V7 STI
I should have stated my question better!
My oil pump needs to be changed. For $10 more than the standard V7 10mm pump, I can get the JDM 12mm pump, which I heard and am trying to confirm, will be a lot more beneficail for my car @ high rpm.
Or I can get the Cosworth pump that costs a lot of $ more!
Is the JDM 12MM a nice assurance to have for my EJ207 or should I spend "that" much more and buy the Cosworth one?
Old 08-17-2010, 11:56 AM   #21
RealDealTarheel
Member#: 142447
**** Texas
The EJ207 should have came with a 12mm oil pump.......
RealDealTarheel is offline   Reply With Quote
Old 08-17-2010, 12:16 PM   #22
huzidada
Member#: 241360
2002 JDM V7 STI
Im pretty sure you wrong boss
But maybe Im wrong
I think its those beautiful EJ20 Legacy blocks that come with the 12mm oil pump
The twin turbo-twin AVCS kind
Old 08-17-2010, 02:01 PM   #23
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
thats what i thought too, but i never verified it on mine
btw to the OP, while everything is apart get a waterpump that comes on the 257s they flow more than the stock 205/207 pumps.
Old 08-17-2010, 03:11 PM   #24
huzidada
Member#: 241360
2002 JDM V7 STI
So I should go for both the 12mm oil pump and the EJ257 waterpump and I should be good to go? The 12mm oil pump is cool for 8k rpm?
I am keeping it a 2 Litre! I like it as a 2 litre, cause they so fun to drive. Im getting a new OEM crank ( original 207). So questions for guys who know their bearings, tell me, are ACL bearings good for my vehicle, and since I rev so high from factory, what would be the best series, and size for me?
I had the ACL Race in there, and they spun, but I never eveer really knew what Subaru did when they built the car( Yes I KNOW! My ex-dealer who closed down now built my vehicle for me!)
Old 08-17-2010, 05:51 PM   #25
RealDealTarheel
Member#: 142447
**** Texas
But maybe Im wrong
I'm pretty sure you're wrong chief.
My EJ207 isn't pulled apart, is yours? If it is could you post the part number?
And the TT Legacy engines were severely screwed by being TT.
Spun bearing on my EJ207 whatishe Built Motor Discussion 15 07-09-2009 08:05 PM
Starting my EJ207 rebuild, pics and questions Hyper Built Motor Discussion 9 03-12-2009 10:53 AM
Spun Bearing...Rebuild. dub c Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 01-12-2009 10:23 PM
STi spun rod bearing rebuild part list. crusher145 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 32 06-20-2007 09:36 AM
FS:STi V7 Shortblock- with spun bearing (perfect for rebuild!!) Blugin Private 'For Sale' Classifieds 29 09-15-2004 10:55 AM
