Old 08-14-2010, 06:11 PM   #1
ONE_1
Member#: 185180
03 Forester XS
Default 98 EJ25DOHC into 99 2.5rs sohc, HALP
okay so i just bought this motor EJ25 DOHC out of a 98 2.5rs. My car is a 99 2.5rs w/ a SOHC EJ25. is it a straight forward swap or am i gonna have to do some wiring??? im feeling lazy and dont wanna search. any help will be appreciated.
ONE_1 is offline   Reply With Quote
Old 08-14-2010, 09:10 PM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
If it were me, I would try to find someone with a set of SOHC EJ25 heads and trade them for your DOHC EJ25 heads you got with that motor.
You would have to put a new set of HG's on the motor, but it would be plug and play, just make sure to use the headgasket that matches the block. I.E, Phase I EJ25 DOHC HG.
~Josh~
Old 08-14-2010, 09:28 PM   #3
ONE_1
Member#: 185180
03 Forester XS
will the heads off my motor work? if i use the intake mani and everything else. since my shortblock either spun a bearing or has a rod knock.
Old 08-14-2010, 09:32 PM   #4
ballitch
Member#: 74907
98 cam'd EJ251
If you have your stock heads that would be easy. How many miles are on this 98 block? If its less than 50k, you could chance it and use it with new HG's and seals and all that jazz.
The best solution would be to have a Phase II EJ25 block.
~Josh~
Old 08-14-2010, 10:46 PM   #5
ONE_1
Member#: 185180
03 Forester XS
The other motor has around 60k and was rebuilt by subaru of plano. Thanks for your help
Old 08-14-2010, 11:49 PM   #6
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
I think you'll have issues with the cam and crank timing if you try to run the dohc with a sohc ecu. I'm pretty sure the sprockets are different.
Tim Sanderson is offline   Reply With Quote
Old 08-15-2010, 08:53 PM   #7
SeeMonkey
Member#: 204190
It can be done. I've put a SOHC phase 2 motor in a DOHC phase one outback, the timing is the same. Biggest problem is the intake manifold is Not swapable. The Idle Air Controller from the DOHC is NOT compatible with the SOHC. I ended up frying the computer playing with the IAC wires. Your best bet would be to meet me half way in Mobile and swap engines with me. Or you could use the block from the DOHC with thick head gaskets with your SOHC heads. I haven't tried it, but I've read people try the oposite with thin head gaskets frequently since Phase 1 blocks are getting harder to find.
SeeMonkey is offline   Reply With Quote
Old 08-15-2010, 09:40 PM   #8
ONE_1
Member#: 185180
03 Forester XS
well i do have the ecu from the dohc motor. i just wanted a drop in plug n play swap. yea i cant for the life of me find a sohc ej25 locally.
Old 08-15-2010, 09:46 PM   #9
Storm
Member#: 5218
96L Most Over-
Developed Beater
Pull the DOHC heads off, put your SOHC heads on the shortblock and drop it in. Sell off the DOHC heads and keep on motoring. It'll be a bit of a hassle to make the EJ25D work with your current ECU and a whole harness swap to run the DOHC ECU is not a worthwhile venture for the amount of work.....unless it was a WRX harness, ECU and motor. That would be a viable and worthy swap.
Jay
Old 08-15-2010, 10:53 PM   #10
ONE_1
Member#: 185180
03 Forester XS
ok so what headgaskets would i need? i feel like such a n00b
Old 08-16-2010, 02:05 AM   #11
VIsubi
Member#: 187834
06 2.5i impreza
Red
Or keep the dohc heads by a highcompression block cams for heads and storage second engine. Then when you can find a L model impreza swap in engine and be a n/a beast in that lil car. Other than that like what everyone else said. Swap heads and new stronger HG. Ohh by the way. Welcome to your new hybrid impreza you along with everyone else. Just remember what u have from what in your car when it's time for parts.
VIsubi is offline   Reply With Quote
Old 08-16-2010, 01:10 PM   #12
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Use the thick phase I HG designed for the DOHC Ej25. You don't need to worry about it's quality or sealing. It's been redesigned just like the thin ones have. The key is that with a phase I block you want a phase I HG to keep the timing correct. Oh, and your pistons will hit the bottom of your heads at TDC with the thin gasket.
Old 08-16-2010, 03:39 PM   #13
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Is this supposed to be incoherent, or was that accidental?
Patrick Olsen is online now   Reply With Quote
Old 08-16-2010, 03:55 PM   #14
Storm
Member#: 5218
96L Most Over-
Developed Beater
^^^ I just skipped that and went straight to Matt's response. Spot on, as usual!!! I forgot to mention that the OP should stick to the EJ25D headgasket due to the unique way the pistons clear the deck at TDC on that model. I, for one, have had to tear down and redo a similar build due to using too thin of gasket on the phase I EJ25D block.
Jay
Old 08-16-2010, 08:05 PM   #15
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Is it just me who sees an issue with the above ?
It's like planning on cooking a 6 course formal dinner but being too lazy to buy potatoes..
Old 08-16-2010, 09:40 PM   #16
Matt Monson
Member#: 832
99 2.5RS, '85 911
Right. Did you see the join dates and member numbers of the people giving him straight answers? We're from a different era when "do a search" nazis didn't rule the day. There's really no reason to be a dick to people...
Old 08-16-2010, 11:06 PM   #17
ONE_1
Member#: 185180
03 Forester XS
Okay. So get the head gaskets from the dohc motor. Well thanks and yes I know I left myself open to a search nazi bashing. I actually did a small search and came up w/ nothing. You guys have been a lot of help and its much appreciated. But I may just sell the car as is. I really can't afford to not have a car anymore and I'm stuck on funds till later nxt month. I'm still up in the air
Old 08-17-2010, 12:51 AM   #18
02subbysnack
Member#: 176393
2002 vr7 sti wrb
ok just so i understand a dohc motor will not swap into a sohc car?even with intake swaps and ecu?
02subbysnack is offline   Reply With Quote
Old 08-17-2010, 04:20 AM   #19
SeeMonkey
Member#: 204190
Intakes are not swapable. Different size and bolt pattern. Idle Air controler from the DOHC intake will NOT plug into SOHC wiring harness, and no one has gotten it work that I know of. The ECU from the DOHC will work with the SOHC motor, except IAC as stated before. I think SOHC is non egr also so it would be throwing codes. Basicaly the car will run but will idle like crap, probably stall at idle when you turn the A/C on. Now if you took the time for ecu swap and full wiring harness swap it should work. But that's a crazy amount of work, and always the risk you screw it up. Much easier to swap heads keep your intake manifold and wireing stock and have it run like stock.
Old 08-17-2010, 04:59 AM   #20
Chi_San
Member#: 53558
2005 Baja Sport
Gray/Silver two tone
Do yourself a favor. Sell the DOHC engine, and get an SOHC.
It's just easier. Swapping heads is a pain. It doesn't quite work out right anyway. Plus, you end up with a set of heads you can't use anyway.
If you want to go DOHC engine, you can swap ECU and wiring harness. If I were in your shoes, I would probably go that route, but I probably would end up shooting myself after doing that as well, and I know how to read wiring charts.
For simplicity, my advice is to get an SOHC engine and put it in, even though I personally like the DOHC engine soooooo much more than the SOHC (and I've owned both myself).
Chi_San is offline   Reply With Quote
Old 08-17-2010, 09:03 AM   #21
Bluefoton
Member#: 141373
2008 2.5i-hatch -
true. sorry.
Old 08-17-2010, 09:48 AM   #22
ONE_1
Member#: 185180
03 Forester XS
There lies the problem. I can't (and trust me I've searched) find a sohc motor. Only person that has one lives out in florida and wants to meet halfway and trade me for my dohc enjine. Only problem is I don't have anyway or time to go out there and do it. This car has become more of a headache than I expected. I've always wanted one but now I truly regret buying it.
Old 08-17-2010, 10:18 AM   #23
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
http://forums.nasioc.com/forums/show....php?t=2039729
i can understand the choice, especially if time/tools/motor knowledge in short supply. (same issues i have BTW) wish i had time to help(new wife/new baby)
so swapping heads too much of a hassle?
cant find anyone here in h-town would help?
AliBenn is offline   Reply With Quote
Old 08-17-2010, 12:02 PM   #24
02subbysnack
Member#: 176393
2002 vr7 sti wrb
i have a complete sohc motor came out running just has a bent valve due to timing belt snapping. but if ur heads are good i have a block...
Old 08-17-2010, 03:45 PM   #25
Chi_San
Member#: 53558
2005 Baja Sport
Get yourself an ECU and harness then. That's the only suggestion I have...
You're going to have a lot of fun pulling your dash and a lot of interior trim stuff putting the harness in.
04 sti shortblock into 99 2.5rs Fast06wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-18-2008 07:37 PM
will a 99 2.5rs engine bolt into a 99 legacy outback? IllNastyImpreza Subaru Conversions 18 06-27-2007 10:26 PM
Ver 5/6 STi DCCD Trans into 99 2.5RS psyctto Transmission (AT/MT) & Driveline 21 02-11-2005 11:33 AM
2002 WRX turbo components into 99 2.5RS HELP!! slickguy11 Normally Aspirated with bolt-on Forced Induction Powertrain 1 10-16-2003 04:07 PM
93 WRX Rear diff into 99 2.5RS Cusco Transmission (AT/MT) & Driveline 2 03-24-2003 02:33 PM
