Old 08-14-2010, 10:27 PM   #1
serious
Member#: 22879
Default Replacing a SOHC ej25 automatic versus manual trans?
Hi all, long story short, I've replaced an engine in a 2000 legacy sedan that has an automatic transmission with a 2000 2.5 sohc engine from an manual transmission car.
Swapped over everything including complete intake manifold and all sensors, but now I've got a couple of codes. Camshaft and crankshaft sensor codes and it won't start. Also, It's pretty much pissing gas out the tail pipe (no joke!)
After some looking, I found the left hand side cam pulley has different pickup notches for the sensor. I'm guessing the crankshaft pulley is different too as I'm getting both of these codes.
So after all that, is this just as simple as swapping over the pulleys and being done with it or am I in for a surprise something like the pulleys won't fit the other cams?
I didn't want to take it out of time, so thought I would post here first.
Also, the original engine is a EJ251 with auto trans
Replacement engine is a Ej252 with manual trans
Thanks
serious is offline   Reply With Quote
Old 08-15-2010, 10:13 AM   #2
flstffxe
Member#: 155358
2008 Forester
Steel Silver
Swap the pulleys and be done with it, they fit.
flstffxe is offline   Reply With Quote
Old 08-16-2010, 11:46 PM   #3
subiman2005
Member#: 151686
2004 GTP Comp G
99 Legacy Sold
yes what he said^ I had the same issue month ago when I swapped a auto motor into my manual car just remove the timing belt and swap the crank gear and drivers side cam gear it will start first try lol
subiman2005 is offline   Reply With Quote
Old 08-17-2010, 01:30 AM   #4
serious
Member#: 22879
Yep, they fit great! Swapped everything over and yes, first crank of the key and she fired right up. Now, I just have to change the engine oil and it smells like a gas station.
Thanks!
WTB: sohc 2.5, manual trans, ecu, etc. for my 95 L!!! IIdiceII Tri-State Area Private Classifieds 9 11-21-2007 07:27 AM
Automatic versus manual transmission in WRX Fireball1 Newbies & FAQs 1 07-18-2007 05:57 PM
Automatic to Manual Trans. l3tix Transmission (AT/MT) & Driveline 1 08-07-2003 09:46 PM
"Manual" automatics abound, BUT "automatic" manuals? uncleho General Forum Archive 5 09-15-2000 12:44 AM
Auto Tranny versus Manual Tranny? NickSTi General Forum Archive 20 05-12-2000 07:14 PM
