Old 08-15-2010, 02:26 AM   #1
piercepcable
Member#: 199670
Default 2.5 Air Filter....
I need to get a new air filter for my 2002 Impreza 2.5.... are there "good" and "bad" air filters.... or are they all about the same. I don't do any performace racing or anything like that.... just want to keep the air clean for a reasonable price.... it's been more than three years since I have replaced.... ug!
Secondly, is it a hassle to install.... I would imagine not by looking at it.... but if there are any tricks to make it go easier, I'd appreciate that too!
Best!
piercepcable is offline   Reply With Quote
Old 08-15-2010, 04:04 AM   #2
msingell
Member#: 153097
2012 CRZ
PWP
i tried a k&n filter for a while, but dirt and road salt collected pretty badly on the filter seeing as how it is oiled. i now use stp paper filters. they have a metal edge all the way around and keep their shape as you try to get the airbox around them.
you may find a telescoping mirror and a flashlight handy to have when changing the air filter. three years on the same filter? you gotta get a new one.
msingell is offline   Reply With Quote
Old 08-15-2010, 08:50 AM   #3
GrundleJuice
Member#: 165749
The K&N and all the other oiled gauze filters filter poorly and often foul the MAF sensor's probe which can cause erroneous MAF voltages to be observed by the ECU. There have even been documented instances where engine oil analysis showed abnormally high silica (dirt) levels. Oh, they resulted in no power gains.
The OEM filter is a good build quality so it's probably also a great filter. Any quality aftermarket paper filter should also be a good option. For stock and modified engines, the paper filter is not a restriction.
GrundleJuice is online now   Reply With Quote
Old 08-15-2010, 04:28 PM   #4
cmiovino
Member#: 134005
2004 WRX Premium
I've stuck with paper through the years. Cheap and effective at keeping out particles. You won't gain anything from changing it, so why spend the extra $$$.
Old 08-17-2010, 11:53 PM   #5
bhilly82
Member#: 254417
09 Impreza
Peperika
I love my AVO panel filters, its a dry type washable filter. not bad price a 55.
bhilly82 is offline   Reply With Quote
Old 08-18-2010, 09:09 AM   #6
piercepcable
Member#: 199670
I put in a standard paper filter. Seems to fit just fine.
I posted a link to a photo of the old one I took out.... what is that dark spot?
https://docs.google.com/leaf?id=0B6m...thkey=CKX03O0M
Old 08-18-2010, 10:16 AM   #7
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Stick with paper, and change it every year. Cheap and effective. Don't forget that both the NA and WRX Imprezas have the same air filter, so it's more than sufficient for our NA's.
Old 08-18-2010, 10:24 AM   #8
ttatsumi
Member#: 85763
OEM - not a bad price either.
ttatsumi is offline   Reply With Quote
Old 08-18-2010, 10:04 PM   #9
ThaPuertoRican15
Member#: 245018
06 Forester
SGM
dark spot is most likely oil from the CCV. ive seen it before on other old filters.
ThaPuertoRican15 is offline   Reply With Quote
'99 RS 2.5 Fender filter box and Engine air box - both have filters in them. cjfike Normally Aspirated Powertrain 5 11-02-2005 11:55 AM
MY99 2.2 Impreza Air Filters wagman01 Normally Aspirated Powertrain 2 05-25-2004 05:35 PM
2.5RS Air Filter? JOHN16V Normally Aspirated Powertrain 17 02-06-2003 12:19 AM
WTB: 2.5RS Air Filter Box DGoReck Tri-State Area Forum 1 11-07-2002 12:33 PM
AMSOIL 2 Stage Air filter mach_six Forester Forum 5 09-13-2001 11:54 PM
