Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2015
Old 08-15-2010, 03:05 AM   #1
quadtard
Member#: 104206
2004 WRX
Tunnel Ram Gray
Default Issue with brights
All of the sudden, one of my brights stays on during normal operation, and when the brights are turned on, it goes off. Its only on the driver's side. Its acting as if the function for the driver side bright is completely reversed. No changes have been made recently, no bulbs changed or anything. DRL has been disabled for years. Any ideas?
This is an 04 wrx
quadtard is offline   Reply With Quote
Old 08-16-2010, 12:46 AM   #2
Henry H
Member#: 184330
2008 Impreza 2.5i
Dark Grey Metallic
If no one else has a suggestion, my approach would be to diagnose.
Remove the highbeam relays
Test the relays
Test the leads to the relays
Come back with results. This is an interesting problem.
But to be sure, your high beams are doing something like this--?-->
Henry H is offline   Reply With Quote
Old 08-16-2010, 10:34 AM   #3
quadtard
Member#: 104206
2004 WRX
Tunnel Ram Gray
High beams are -o when lights/everything are off(car running, though), and o- when highs are on. indeed
Old 08-16-2010, 10:46 AM   #4
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
A short somewhere? Subies use a switched ground system, which means that a short on the -ve side actually turns things on. Either that or you enabled your wig-wag Police Package
Old 08-16-2010, 12:20 PM   #5
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
There may be a backfeed problem due to a blown fuse for the left side light. Check the fuses under the hood for the headlights. If you have any doubts on the fuse try reversing the left and right side fuses to see if that changes things.
Old 08-19-2010, 04:59 PM   #6
quadtard
Member#: 104206
2004 WRX
Tunnel Ram Gray
^^exactly it! thanks! I had a wire that was shorting out the fuse.
reguest white subies with bright colored rims 05ASPINREX Member's Car Gallery 5 10-26-2008 07:02 PM
how long until natural selection produces a breed of deer with bright orange fur? alacrity024 Off-Topic 7 10-21-2005 12:36 PM
saab with a little issue with it's windows pk! General Community 3 04-21-2004 03:53 PM
Any issues with stock turbo/injectors with Walbro pump? wagon-wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-27-2004 03:07 PM
Hella 500s with Brights Only??? downeyer Electrical & Lighting 5 03-10-2003 03:22 AM
