Old 08-15-2010, 06:07 PM   #1
09suby
Member#: 222590
2009 Impreza 2.5i
Spark Silver Metallic
Default Turbo kit
Does anyone know if this turbo kit can be adapted to fit my 2009 impreza 2.5i?
http://www.turbo-kits.com/impreza_turbo_kits.html
09suby is offline   Reply With Quote
Old 08-15-2010, 06:49 PM   #2
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
Putting the turbo on the engine is not the problem. The engine is. It's not built for boost.
chazly413 is offline   Reply With Quote
Old 08-15-2010, 08:30 PM   #3
jeonster
Member#: 198854
2013 WRX
I wouldn't do that to my 2009 impreza. But then again you're not me.
Try it out and tell us how it ends up.
jeonster is offline   Reply With Quote
Old 08-15-2010, 09:07 PM   #4
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
This is your second thread about turbos.
Once is enough.
Head on over to the Aftermarket Forced Induction thread and read some of the stickies then go ask questions there.
formula91 is offline   Reply With Quote
Old 08-16-2010, 01:52 AM   #5
VIsubi
Member#: 187834
06 2.5i impreza
Red
Casey has a 2.5i wagon the thread is 2.5i-t over on the N/A with FI thread. He's running 7psi with no issues. But that's with the Cobb accesport as the brains. A piggyback might need lower boost. The engines handle boost just fine aslong as you don't turn it up. Run the right fuel and don't let ur tank go lower than 1/4 tank. 1/2 if your doing track days or rallycross. Then save up for pistons and or rods if u want more boost. There are some people running 10 psi but that's really chancing it and have 100+ octane fuel. Sean at rallitek is the tuner behind that tune on caseys car. Plus your 09 is a healthier motor than most that go turbo. Spanking wrx's is pretty fun when your a sleeper but have it set in your head that you will want to upgrade internals down the road. The block can take boost I have a friend who has a ej253 in his sti converted 06 wagon with wiseco pistons and rods from his sti and sti heads running 14 psi no issues. His sti block had some issues so he swapped pistons into n/a block and spanking
VIsubi is offline   Reply With Quote
Old 08-16-2010, 09:44 AM   #6
GEE-OTTO
Member#: 201277
2009 Legacy GT
yes that kit can be made to fit your 2.5i but you will have to get it tuned to handle the boost and a low boost application 7psi and lower won't kill the EJ253 I would run 6PSI max
GEE-OTTO is offline   Reply With Quote
Old 08-16-2010, 11:47 AM   #7
09suby
Member#: 222590
2009 Impreza 2.5i
Do you know if I would be able to use Opensource as my EM?
Old 08-16-2010, 12:23 PM   #8
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
DIY PSI? Count the tires on your backup transportation. If there are at least two, go for it.
LetItSnow is offline   Reply With Quote
Old 08-16-2010, 12:44 PM   #9
VIsubi
Member#: 187834
06 2.5i impreza
Red
or 4 then your fine..again it will handle boost at 6 psi..you will get bored once you get use to it wanting to increase boost thinkin a lil won't hurt then boom. Open source should be able to do it from what people claim its the best...to me next to accessport its the best. lol my back up wheels is 6 so I'm going supercharged at 7 psi and I know it will handle boost fine..waiting on kit now
Old 08-16-2010, 12:55 PM   #10
Henry H
Member#: 184330
2008 Impreza 2.5i
Dark Grey Metallic
Ah, supercharging. That's actually the route I'd like to go one day. There is more usable speed and response from supercharging (in the range of normal driving that is).
Henry H is offline   Reply With Quote
Old 08-16-2010, 02:10 PM   #11
GEE-OTTO
Member#: 201277
2009 Legacy GT
2009 5MT 2.5i can be tuned. The real issue here if you are going to turbo your car DO IT RIGHT. I would wait till the warranty has expired personally but if you must just do it RIGHT. And ignore the negative, sarcastic comments this thread is bound to receive there is a member on this site that boosted his 2.5i from a homemade kit and it is running fine currently
Old 08-16-2010, 02:32 PM   #12
09suby
Member#: 222590
2009 Impreza 2.5i
I have an automatic version. I am also supported. I am going to wait until my warranty is over. I am just doing research as I plan to boost my car summer of 2011. Do you have the name of the member who has done this?
Old 08-16-2010, 02:37 PM   #13
09suby
Member#: 222590
2009 Impreza 2.5i
What I meant was does Opensource support boost on a N/A?
Old 08-16-2010, 03:16 PM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Try it out and tell us how it quick it blows up.
Old 08-16-2010, 03:25 PM   #15
08imprezahatch
Member#: 247867
08 2.slow
Default Turbo
09Suby I'm not positive who Gee Otto is referencing but it is probably Olsen726 he has a pretty great thread going.
http://forums.nasioc.com/forums/show...753564&page=14
08imprezahatch is offline   Reply With Quote
Old 08-16-2010, 04:11 PM   #16
GEE-OTTO
Member#: 201277
2009 Legacy GT
Yup Olsen726 was the member!
Old 08-16-2010, 04:12 PM   #17
GEE-OTTO
Member#: 201277
2009 Legacy GT
Maybe by 2011 the AVO Kit will be in production
AVO 2.5i Turbo Kit 09suby Normally Aspirated Powertrain 3 08-16-2010 06:53 PM
Ft: So Cal: Gt35r .82 Ar Turbo Kit For Stock Location Turbo Kit EvO KiLLeR 2005 Engine/Power/Exhaust 4 06-02-2008 01:21 PM
AVO Turbo Kit vs TSI Turbo Kit Mechkiller31st Normally Aspirated with bolt-on Forced Induction Powertrain 6 12-01-2004 07:02 PM
Wanted: Turbo Kits or Turbo Kit Parts Acejam2k Private 'Wanted' Classifieds 1 01-05-2004 01:34 PM
