Old 08-15-2010, 11:07 PM   #1
thefultonhow
Member#: 107064
15 LR WRX base 6MT
05 LGT, 07 Spec.B - SOLD
Default EJ253 into EJ251 car
My brother's EJ251 engine in his 2001 Forester (160k) is burning oil at a rate of a quart every 700-800 mi. It seems to me that its days are numbered, and I don't have enough confidence in my mechanical abilities to do a rebuild. I have, however, done engine swaps before. I found a super-low mileage EJ253 from a 2006 Baja locally for cheap. Will it be possible to do the swap, considering the AVCS on the intake valves and the use of drive-by-wire and a MAF instead of throttle cable and MAP?
thefultonhow is offline   Reply With Quote
Old 08-16-2010, 01:42 AM   #2
VIsubi
Member#: 187834
06 2.5i impreza
Red
Yes. But you will have to swap out dbw throttle and components or just swap the heads and run the block. All ej253 blocks are the same. It's the heads that have the better cams. If you can do an engine swap you can change the heads and torque to spec since engines will be out of car. Head gaskets will need changing. Up for a better copper or metal gasket while your at it. Haven't seen any issues with 2006+ head gaskets but might aswell change it. Mine are still awesome on the 06 but I only have 17k on engine but I spirit drive a bit.
VIsubi is offline   Reply With Quote
Old 08-16-2010, 08:44 AM   #3
thefultonhow
Member#: 107064
15 LR WRX base 6MT
Can I just not hook up the AVCS stuff and run on the low cams? I know it's not optimal, but it would be easiest to not have to swap heads, and it's possible part of the oil consumption issue on my brother's car is through the valve seals or something. I have no problem swapping out the DBW stuff; I assume the most I would have to do is switch the throttle body.
Old 08-16-2010, 09:13 AM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Just to clarify, it's not AVCS, it's AVLS - variable lift, not variable timing.
Originally Posted by VIsubi View Post
... but I spirit drive a bit.
Is "spirit driving" like ghost riding?
My impression is that the low lift cams are quite low, to the point that I think the car would be a dog without having the high lift capability. The good news is that the AVLS is basically just ON or OFF, so you can use an RPM-triggered window switch (like drag racers use for NOS) to trigger the AVLS solenoid. That part's pretty easy. I'm not sure how well your stock non-AVLS ECU would react to the sudden change in cam lift (and sudden change in airflow).
And figure out mounting the throttle cable.
Pat Olsen
Old 08-16-2010, 09:24 AM   #5
GEE-OTTO
Member#: 201277
2009 Legacy GT
Why dont you just swap EVERYTHING and have the EJ253 ECU run the thing? you are getting the motor, so get the ECU make your life easier. Why would you want to rig the AVLS to run off a window switch when you have a ECU that will do it properly and worry free for many miles?
GEE-OTTO is offline   Reply With Quote
Old 08-16-2010, 09:32 AM   #6
thefultonhow
Member#: 107064
15 LR WRX base 6MT
Well, will the engine harness from the Baja connect up to the Forester body harness? Also, doesn't the 06 Baja use an immobilizer key?
EDIT: JK, the Baja did not use an immobilizer ever: https://subaru.locksmithsdrm.com/sr-...t_key_info.pdf
EDIT2: My brother's Forester is 5MT and the Baja is 4EAT. Won't that be a problem for the ECU?
Old 08-16-2010, 09:40 AM   #7
GEE-OTTO
Member#: 201277
2009 Legacy GT
Nope the Baja doesn't have the engine immobilizer which is odd they use the standard side cut keys if I am correct. The harness should swap fairly easy and make your life easy
Old 08-16-2010, 09:45 AM   #8
thefultonhow
Member#: 107064
15 LR WRX base 6MT
Even though the Baja is auto and my brother's Forester is manual?
Old 08-16-2010, 03:37 PM   #9
thefultonhow
Member#: 107064
15 LR WRX base 6MT
Old 08-16-2010, 04:10 PM   #10
GEE-OTTO
Member#: 201277
2009 Legacy GT
Now it comes out just do a head swap and intake manifold swap and plug it back into the Forester harness
Old 08-16-2010, 04:13 PM   #11
thefultonhow
Member#: 107064
15 LR WRX base 6MT
Bah. What do you think, is that cheaper or more expensive than a bottom end rebuild? The guy wants $800.
Old 08-16-2010, 06:31 PM   #12
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
you can buy newly remanufactured ECU's for $269 with a core. Another option if it turns into a big problem
Old 08-16-2010, 09:10 PM   #13
naimouasta
Member#: 47998
2002 WRX Wagon
2008 Legacy QSM
unless the guy does subaru rebuilds day in and day out, i doubt it will ever be the same.
naimouasta is offline   Reply With Quote
Old 08-16-2010, 09:16 PM   #14
thefultonhow
Member#: 107064
15 LR WRX base 6MT
It's a longblock with 34k that's never been disassembled... why would his experience with Subarus affect the condition of the internals?
Also, I don't do Subaru rebuilds day in and day out, but I'm not about to pay someone to do a professional rebuild on a 10-year-old car with 160,000 mi that's worth maybe $4,000 on a good day. It's going to be me feeling my way and consulting the FSM a lot, just like I did on my first engine swap (which took 3.5 weeks but started up right away and I only had to fix a couple minor things afterward, since I went by the book. Obviously subsequent engine swaps/clutch jobs/etc. have taken far less time).
Old 08-16-2010, 11:49 PM   #15
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
take the longblock from the new engine and put it on old intake manifold / etc... and move over all the accessories.... so no real wiring to do...
that's what i did.... put a 2006 2.5i engine in my 99rs.... my mechanic disconnected the avcs.... and car easily past emissions.... was cheaper than doing timing belts / headgasket fix.
Robin2 is offline   Reply With Quote
Old 08-16-2010, 11:50 PM   #16
thefultonhow
Member#: 107064
15 LR WRX base 6MT
How's the top-end power? Worse than the EJ25D? If so, how much worse?
Old 08-16-2010, 11:51 PM   #17
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
was the same i guess.... didn't see any difference.
Old 08-17-2010, 08:49 AM   #18
thefultonhow
Member#: 107064
15 LR WRX base 6MT
Based on that, I think I am going to buy this. I think I can probably sell sensors and maybe the intake manifold to make some money back, and maybe sell the old longblock for a couple hundred as a rebuildable engine. So it seems like this makes sense from a financial/labor standpoint if I can use the 2006 heads on the low cam profiles without issues.
Old 08-17-2010, 12:22 PM   #19
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
thats what i did..... sold the 2006 intake manifold to a friend for $75, sold the old longblock for $200... so new engine with 15k miles was essentially $850 for me..
Old 08-17-2010, 02:41 PM   #20
naimouasta
Member#: 47998
2002 WRX Wagon
2008 Legacy QSM
o i'm sorry. i thought you were talking about the bottom end rebuild.
Old 02-10-2011, 10:42 AM   #21
turbo38sfi
Member#: 273512
Robin,
If I'm reading this correctly, I think you did what I'm looking for answers for on if it will work. I have an 05 Legacy and putting in a motor from an 06 Impreza. The 06 has AVLS. Are you saying you dropped in the newer motor without hooking up any of the active valve stuff, swapped over your intakes and everything runs OK and the car is not a dog? I don't want to mess with swapping ECUs and such if I don't have to. Can you elaborate more and give us an update on your car since posting this?
turbo38sfi is offline   Reply With Quote
Old 01-04-2012, 12:29 PM   #22
TravisL
Member#: 288101
Old post, but I'm in a similiar situation.
I have EJ251 heads/intake and I'd like to use a newer EJ253 block. I have the 253 heads, but nothings else from it(no ecu, harness, intake etc).
Has anyone actually swapped the 251 heads onto a 253 block? Will the valves interfere? I read on rs25 on one old post that they will, but his heads had been decked at least twice. I plan to use the 6 star mls gaskets that may gain me precious 1000th's.
This thing is my only car and it's down so I'd really appreciate any help if you guys have the info, in the mean time I'll keep searching online.
Thanks!
TravisL is offline   Reply With Quote
Old 01-04-2012, 12:43 PM   #23
thefultonhow
Member#: 107064
15 LR WRX base 6MT
The intake manifold will work on EJ253 heads. I know because I did this swap in July and it's running fine. Not sure on EJ251 heads onto an EJ253 block though. I had the complete engine.
Old 01-04-2012, 12:58 PM   #24
JoshP
Member#: 94350
251 heads do not work on 253 block.
JoshP is offline   Reply With Quote
Old 12-14-2012, 06:18 AM   #25
-] Kenpachi [-
Member#: 211890
But how could I hook up the avls to a switch, cause mine drinks a lot of gaz.
-] Kenpachi [- is offline   Reply With Quote
uhhhh ohh.....cars parking brake just gave out...into another car... nottheliving Off-Topic 13 10-04-2005 10:13 PM
stuff going into my car tomrrow! Hyperdash Member's Car Gallery 4 09-08-2001 06:45 AM
thanks to everyone who tried to help me break into my car today at the autox jmott Texas Impreza Club Forum -- TXIC 3 08-12-2001 01:59 PM
Someone backed into my car and broke my C-west rear spat! adamsrs Interior & Exterior Modification 9 03-17-2001 07:21 PM
