Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 08-16-2010, 04:12 AM   #1
jxkim
Member#: 239150
2003 WRX Sedan
Default Seat/Carpet Cleaner
I have this yellowish stain on my rear seats that i have no clue what it is from. I used the blue coral carpet/seat cleaner, after seeing good reviews on it. but the stain looks the same. tried letting in soak in, did multiple passes, etc etc...
any good products you guys recommend? or cool tips? i have a 2003 wrx, which are the blue/black seats. last think i want is to ruin my seats... think a steam cleaner will do the trick?
jxkim is offline   Reply With Quote
Old 08-16-2010, 07:59 AM   #2
furiousC
Member#: 247576
Try tuff stuff. It has worked well for me in the past, and is what we used when I worked as a detailer at a Mercedes stealership. It would lift greasy stains but not sure about your 'yellowish' mystery stain. I'm pretty sure I know what that is
Resolve may work better, but I don't have experience with it. If there is a strange yellowish odor to it then Nature's Miracle works great in that department.
If that doesn't work maybe an oxy clean type cleaner will work. In the past I've gone as far as removing the seat cover from the foam and washing it in a bathtub, but that was an extreme case.
furiousC is offline   Reply With Quote
Old 08-16-2010, 05:19 PM   #3
snoboarder8232
Member#: 241289
Folex.
snoboarder8232 is offline   Reply With Quote
Old 08-17-2010, 03:33 PM   #4
91gl
Member#: 186019
try 303 carpet/upholster cleaner and a good brush, if that doesnt work then steam cleaning might be the only way
91gl is offline   Reply With Quote
Old 08-17-2010, 09:21 PM   #5
Apex44
Member#: 254522
04 Impreza WRX
tuff stuff or the OXY stain remover. both can be found in the automotive section at your local walmart.
Apex44 is offline   Reply With Quote
Old 08-17-2010, 09:34 PM   #6
hoffmanEstates
Member#: 122043
04 wagonier
psm
i take my seats apart and wash the cover;s and give the foam a wipe down with a hospital grade disefectant.
hoffmanEstates is offline   Reply With Quote
Old 08-18-2010, 02:23 AM   #7
Kfly04
Member#: 252005
2004 STI
Java Black
what color are your seats? find some paint dye that matches the same color and run with that if the seats are black just get some black spray paint and try it worked well for me.
Kfly04 is offline   Reply With Quote
Old 08-23-2010, 01:56 PM   #8
Drex368
Member#: 255701
303 makes great products, including a carpet/upholstery cleaner. Their original product is great for all plastics, inside and out.
Drex368 is offline   Reply With Quote
Bissell little green compact carpet cleaner Cyclops Car Care & Detailing 12 04-07-2009 09:39 PM
Carpet/Seat/Headliner Cleaner? northmiler89 Car Care & Detailing 8 07-06-2008 11:00 PM
Resolve = Magical Carpet Cleaner in a bottle WRSport Off-Topic 13 04-16-2005 10:57 AM
Carpet cleaner on seats?? DjMyst Interior & Exterior Modification 1 03-23-2004 12:38 PM
Capture Carpet cleaner DonA General Forum Archive 0 07-27-2000 03:34 AM
