Welcome to the North American Subaru Impreza Owners Club Sunday May 24, 2015
Old 08-16-2010, 03:19 PM   #1
Davenow
Member#: 23676
Default Hella FF700 lights not very bright.
I would have expected these to have been at least as bright as the OEM headlights, but they arent. Not nearly. If I put my high beams on you cant even tell these are on. You can barely tell with the low beams on.
Any thoughts? I am thinking a weak ground maybe?
All connections are soldered, they are wired through the relay then to the battery.
Or am I just expecting too much from the 55W bulbs?
I picked up a set of 100W bulbs a few min ago, I'm gonna see if they are what I need.
Old 08-16-2010, 03:34 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
d0000000000000d....yer just gettin old and cant see like ya used too
Old 08-16-2010, 03:37 PM   #3
cantseejack
Member#: 225097
I had a set of FF700s; they aren't the brightest by a long shot. Probably going to go with FF4000 Halogens next.
cantseejack is offline   Reply With Quote
Old 08-17-2010, 10:51 AM   #4
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
What car do you have to start with? If you have retrofitted quad-HIDs, no wonder you don't see them... Did you aim them properly? My pencil 500s make a heck of a difference at a distance...perfect to complement high beams on empty freeway driving.
Old 08-17-2010, 12:22 PM   #5
Davenow
Member#: 23676
Its an 07 FXT, just standard reflector headlights. I may have Silverstar bulbs in them, but that's it, and I don't even remember if I did that.
Here it is
They are aimed, and I have tried re-aiming them a touch higher, they just dissapear when I get out anywhere near the range of my high beams, and even then you can only see them if the high beams are off.
I put 100W bulbs in them last night, that should help. I havent had it out on the road since I put them in though. Ill find out tonight.
Old 08-19-2010, 04:20 AM   #6
fastwrx25
Member#: 126441
03 bugeye
^^sexy foz.
I would like to see pics of lightoutput.
curious to see how bad they are.
fastwrx25 is offline   Reply With Quote
Old 08-20-2010, 06:27 PM   #7
Davenow
Member#: 23676
Originally Posted by fastwrx25 View Post
^^sexy foz.
I put a set of 100W bulbs in them and they are much better. WAY better. This is what I expected from them.
Ill try to get a pic tonight, but it will be with the 100w bulbs.
Old 08-21-2010, 03:15 PM   #8
jutes85
Member#: 127232
E92 M3
98' Foz
I dono, I have the 55W bulbs in my FF700's and they seem okay.
Low
Low+High beams
Low+High+FF700+FF1000 fogs.
If the 100W bulbs are as good as you say I might get a set. Did you go with anything particular?
jutes85 is offline   Reply With Quote
Old 08-21-2010, 06:37 PM   #9
Big-E
Member#: 123843
2006 WRX Sedan SGM
Let LED's light your way!
Nice car and nice lights!
As a suggestion, at 200 watts you should be using 14-gauge wire. Also, the wire that Hella uses off of the lamps themselves is aluminum wiring. Get rid of it. Use copper wiring throughout.
FS Gram Lights 57 Optimise Bright Silver --Light Weight Rims H.K. Phooey Wheels/Tires 8 01-25-2010 02:09 PM
WTT: Hella 500 amber fog lights for Hella driving lights Dforce SCIC Private Classifieds 29 08-30-2008 02:38 PM
WTT: Hella 500 amber fog lights for Hella driving lights Dforce Exterior/Styling 36 08-30-2008 02:36 PM
Cheap Low Beam H7 bulbs: Silverstar VERY BRIGHT ScubaruImpreza05 Tri-State Area Private Classifieds 0 07-27-2008 05:03 PM
Dim / Fog lights not working; Brights work. ??? DoodieHead Electrical & Lighting 1 11-26-2004 01:10 PM
