Vancouver Impreza Club
Old 08-16-2010, 04:55 PM   #1
6th gear
Member#: 126860
2004 STi Aspen White
1971 Corolla Racecar
Subaru Stars Fuel Octane Questions
I always use Chevron 94 (I think most of us with turbos do) however, I'm heading down to California for an Indycar race this weekend.
Questions:
  1. Which stations carry decent fuel?
  2. Should I grab a couple bottles of octane boost just in case?
Tanks,
Geremy
6th gear is offline   Reply With Quote
Old 08-16-2010, 05:03 PM   #2
Jeff54
Member#: 129503
2002 It's resting
6 > 4?
what mods on car?
Jeff54 is offline   Reply With Quote
Old 08-16-2010, 05:13 PM   #3
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
there are chevron's all along I5 and in Cali. They just don't have 94 octane.
Flash your car to a 91 map or stay out of boost.
minifreak is offline   Reply With Quote
Old 08-16-2010, 05:18 PM   #4
slowguy
Member#: 4326
what jeff asked. i'm reflashed to stage2 but it was an OTS map tuned for 91.. i always run 91..
slowguy is offline   Reply With Quote
Old 08-16-2010, 05:44 PM   #5
Linkseal
Member#: 102329
05 AW Piggy Gone
11 SP TOM'S IS-F
91 oct is good
Linkseal is offline   Reply With Quote
Old 08-16-2010, 05:53 PM   #6
Jeff54
Member#: 129503
2002 It's resting
6 > 4?
Originally Posted by Linkseal View Post
91 oct is good
no it's really not...
if his car is tuned for 94 octane, running 91 would be less than ideal
Old 08-16-2010, 07:18 PM   #7
KiraFayt
Member#: 161457
2004 WRX
This might be inconvenient and stupid, but would putting a bottle of Octane boost before every pump work?
KiraFayt is offline   Reply With Quote
Old 08-16-2010, 07:54 PM   #8
6th gear
Member#: 126860
Subaru Stars
Originally Posted by Jeff54 View Post
what mods on car?
Bone stock
That was question #2
Old 08-16-2010, 08:07 PM   #9
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Yeah, that's about right.
None of them do. Gas in California is designed to minimize visible smog at the expense of everything else.
Bone stock
Then just run 91, have some burritos, and call it a day!
Necromancer is offline   Reply With Quote
Old 08-16-2010, 08:10 PM   #10
TXSubieDood
Member#: 199859
2004 Impreza WRX/STi
AWDTuning delete!
if you're bone stock, what's the problem?
91 octane is a "premium unleaded fuel"
running 94 helps a little but if you really want the perks of running it get tuned with it.
TXSubieDood is offline   Reply With Quote
Old 08-16-2010, 08:32 PM   #11
Necromancer
Member#: 477
GC4 -> GGA -> GM6
In Vancouver there might be a legit reason to run 94 during the summer: It is widely available here, and 91 octane fuel is labelled as "may contain up to 10% ethanol" while 94 "contains no ethanol." Because the price difference is only a few cents per litre and E10 causes 3-4% worse fuel economy, you might almost break even. (shrug)
Old 08-16-2010, 09:37 PM   #12
tora
Member#: 5851
09 Forester XT
+ NA Miata
TX is just offended because their fuel sucks compared to ours...
tora is offline   Reply With Quote
Old 08-17-2010, 02:14 AM   #13
truenosan
Member#: 78893
2013 Scion
FRS
You will be fine running 91.
I drove down to cali when my car was stock, and had no problems running cali's piss for gas 91 octane.
truenosan is offline   Reply With Quote
Old 08-17-2010, 03:03 AM   #14
6th gear
Member#: 126860
Subaru Stars
Thanks,
That's kinda what I figured but just thought I'd run it past the VIC.
I've packed a couple of Octane Boost bottles if she protests but I don't think I'll need them.
Thanks Dudes.
Old 08-17-2010, 04:01 AM   #15
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
If you really want to play it safe go fill up with 91 octane here, plug the battery and reset your ECU and the fuel compensation and timing table.
Old 08-17-2010, 05:49 AM   #16
5 Zigen
Member#: 769
04 SoBaLo EsTea-ai
ZERO/SPORTS/99 GM6/05 BP6
i was having some problem with 76 gas station in WA, seems like my car doesn't really like it and giving me an ugly LV table. It's normal now with Chevron 94, weird.
5 Zigen is offline   Reply With Quote
Old 08-17-2010, 11:42 AM   #17
brendan_mac
Member#: 125055
12 STI hatch
I drove to L.A. and back on a Rocket tune for 94, and checked with pat before I went. It's within the car's parameters to "learn" for the lower octane fuel, and you could help it out by doing a half-and-half tank of 91/94.
When you get back, ecu reset and a tank of 94, and it should take advantage of it. Really though, unless you have a very aggressive tune on, it's not even an issue.
brendan_mac is offline   Reply With Quote
Old 08-17-2010, 01:15 PM   #18
Linkseal
Member#: 102329
05 AW Piggy Gone
11 SP TOM'S IS-F
Well you know I assume his car is on stock map since he did not mention any mod so...
Bone stock
I saw few cars ran really bad on 91 Oct while they are using 93 oct map, if you are on 93+ oct stage 2, I suggest drive it gently down the US hwy. Maybe just stick with those large brand gas stations closed to Hwy exit, try to
avoid to get cheap gas from those small non-brand gas stations since they might put the conditioner on their gas and this will hurt your car.
Old 08-17-2010, 02:40 PM   #19
5 Zigen
Member#: 769
04 SoBaLo EsTea-ai
^ conditioner in the gas is what i am guessing, there is no way the car runs so poorly with a 94 and 101 octane mix...haha...lucky i am aware and took it easy home!
Old 08-18-2010, 03:42 PM   #20
slystijohnny
Member#: 151812
2000 2.5 rSTI
copper
The octane boost does work, but if you're bone stock you won't need it unless something is horribly amiss under your bonnet.
If knock is a concern set up an alki system, you can do it on the cheap (under $750) if you're capable
slystijohnny is offline   Reply With Quote
Fuel Octane Question JL-07STI-LTD Newbies & FAQs 57 07-04-2010 01:09 AM
2 Questions about Service and Fuel Octane PeteyPabs069 Newbies & FAQs 33 07-23-2008 05:53 PM
Octane question--- 91 octane will hit $3 here Homerisking General Community 40 03-10-2005 12:50 PM
Schools in on fuel, octane etc Wombat North Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-02-2003 11:58 AM
Fuel Octane Loki General Forum Archive 14 03-20-2001 01:23 AM
