Old 08-16-2010, 05:19 PM   #1
michaelcisek
Member#: 238379
2000 Outback Sport
Two-Toned Silver/Brown
Outback Sport Muffler Baffles: Necessary?
After an extensive cleanout of the replaced warranty parts storage at work, I came across a Bosal muffler that had been replaced due to a small dent in the side and an apparent whistling noise.
I have a 2000 OBS with a 2002 WRX stock catback on it, sounds alright, however, i'm looking for a little more sound.
I was wondering if anyone else has heard/done/seen the results of a straight muffler with the baffles cut out. I figure since I got this for free, It wouldnt be of much loss just to cut it open, remove the baffles, and maybe strap it on my car.
michaelcisek is offline   Reply With Quote
Old 08-16-2010, 06:54 PM   #2
GrimmSpeed
Member#: 136396
2012 wrx
white
At that point you might as well not run a muffler at all and straight pipe it. I would maybe try throwing the bosal on as is and see how it sounds. If you don't like it you can always take it off.
Mike
GrimmSpeed is offline   Reply With Quote
Old 08-16-2010, 07:02 PM   #3
michaelcisek
Member#: 238379
2000 Outback Sport
Thanks Mike! That was my initial plan, put it on and see how it sounds. I do want it to look like there is a muffler there, which is why I'm using it.
Bosal Part No. 229 693
Subaru Part No. SOA8375400
Old 08-16-2010, 11:11 PM   #4
grafton
Member#: 187936
97 Legacy w12:1CR
05 LL Bean outback
i ran with a gutted wrx muffler for a while and it sounded like crap...
grafton is offline   Reply With Quote
STI topmounts- necessary/not necessary? zelig Brakes, Steering & Suspension 3 12-07-2002 09:43 PM
Is it necessary to tape down sticky balancing weights? megatron Brakes, Steering & Suspension 13 06-04-2001 08:50 PM
Where for installing muffler+ FocuZ muffler STi Boy New England Impreza Club Forum -- NESIC 3 05-15-2001 05:29 AM
turbo timer: is it necessary? satrya Factory 2.0L Turbo Powertrain 3 04-19-2001 01:48 AM
Message Board Statistics All times are GMT -4. The time now is 08:01 PM.
