Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 12-05-2011, 03:37 PM   #326
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Originally Posted by PearlRex11 View Post
Is their any problems so far with you running the AEM or COBB SF (can't remember which you used) map with it or are you protuned now?
We used the AEM map, and after checking everything it was withing a reasonable operating range. However a pro-tune would really be needed to get the intake completely scaled.
Running a different map for the intake is really just a bandaid though.
RallySport Direct is offline   Reply With Quote
Old 12-07-2011, 01:07 PM   #327
glowingfupa
Member#: 302545
2005 Leggy LGT
Default sexy
that thing is just downright sexy. Aspen white, no better color
glowingfupa is offline   Reply With Quote
Old 12-07-2011, 02:08 PM   #328
PearlRex11
Member#: 284420
2011 WRX Sedan
Cool thank you for the info!
PearlRex11 is offline   Reply With Quote
Old 12-10-2011, 09:23 PM   #329
RallySport Direct
Member#: 33174
We are Open Late!
Oh boy...look what we got
She is going on corn juice as well
Who can guess what it is?
Little hit, GTX
ps. before people ask, we will be blocking the EWG on the turbo and continue using our EWG up pipe setup.
Old 12-11-2011, 04:42 PM   #330
fourmicah
Member#: 128760
2017 STI
Looks like the ATP 3076R to me, although I'm hoping not. I haven't liked the spool on any of the ones I've seen yet.
fourmicah is offline   Reply With Quote
Old 12-11-2011, 05:51 PM   #331
jockeygolfs
Member#: 260868
2011 STI
Gtx3576r???
jockeygolfs is offline   Reply With Quote
Old 12-12-2011, 01:40 PM   #332
RallySport Direct
Member#: 33174
We are Open Late!
Gtx3076 :d
Old 12-13-2011, 09:58 PM   #333
MercuryFree
Member#: 294225
2002 V7 WRX STi
WR Blue
Is THAT what those mounty things under/behind the seats are for? hah. Or are the harnesses custom mounted?
PS: Thanks for not being complete muppets with my international order the other week !
MercuryFree is offline   Reply With Quote
Old 12-14-2011, 11:54 AM   #334
angdefeo
Member#: 214908
2009 WRX Sti
Dark Grey
cant wait to add some of your parts to my car.
angdefeo is offline   Reply With Quote
Old 12-14-2011, 01:13 PM   #335
Renown Performance
Member#: 296338
2004 WRX Wagon
Those brackets in between those seats are normally meant for car seats for kids, but should definitely be sturdy enough to run the harnesses on!
-Sam
Renown Performance is offline   Reply With Quote
Old 12-14-2011, 01:48 PM   #336
ah2049
Member#: 261863
2015 Focus ST
OW
-Sam
I'm curious about the strength of those brackets. I would imagine they are a bit over-engineered when it comes to retaining a child and the seat, but I can't help but wonder whether or not they had adults in mind when they were designed.
Has any testing been done? Or maybe there is a manufacturing standard that doesn't differentiate between adults and children when it comes to that sort of safety feature...
ah2049 is offline   Reply With Quote
Old 12-14-2011, 04:36 PM   #337
HP10T
Member#: 75849
-Sam
I'm sure if they were going to be tracking the car they would run a harness bar and loop the belts properly. Albeit those are just hooked up like that for show.
HP10T is offline   Reply With Quote
Old 12-14-2011, 04:50 PM   #338
RallySport Direct
Member#: 33174
We are Open Late!
That is correct.
The current set up is for show, as it is hooked up into the rear child safety restraint system. If the car is going to be tracked we will make sure to hook it up through a harness bar.
Old 12-14-2011, 08:13 PM   #339
ah2049
Member#: 261863
2015 Focus ST
OW
Originally Posted by RallySport Direct
That is correct.
Ah, good to know!
Old 12-16-2011, 11:10 AM   #340
Murilo08wrx
Member#: 303505
awesome!
Murilo08wrx is offline   Reply With Quote
Old 12-25-2011, 02:02 AM   #341
kalobsti07
Member#: 246103
gtx3076
kalobsti07 is offline   Reply With Quote
Old 01-13-2012, 01:10 PM   #342
aikencolon
Member#: 300348
2011 WRX STi
Satin White Pearl
I know I'm a little late to this thread and I looked through the first 5-6 pages, but did I miss the dyno numbers after all of these add-ons?
I own the same 2011 and I'm curious to know what this car is putting to the wheels so I can get a good bell weather as to what I should expect when mine goes into the shop in a week for my stage 2 mods (ceramic coated Invidia down and uppipes, ID1000cc fuel injectors, Walbro 255ltr/hr fuel pump, & retune).
Thanks.
EDIT: Wait, I found a dyno print out on page 8, but that can't be right. All those mods and it's showing 269whp and 295ft/lb??!!?? I had my Stage 1 protune done 2 weeks after I bought this same exact car. All I modded was the Cosworth cold air intake, Cobb AP and SPT catback exhaust (no hp gain) and I'm at 274whp and 333ft/lb. (See photo) How are your numbers so low with that shopping list full of mods? I must be missing something here.
aikencolon is offline   Reply With Quote
Old 01-13-2012, 01:17 PM   #343
aikencolon
Member#: 300348
2011 WRX STi
Satin White Pearl
Originally Posted by RallySport Direct View Post
Spoiler is a bit much, but this interior is sick. The red stitching from the steering wheel all over the interior? Sooo clean. RSD, can you PM with the info on this interior work? Cost, time involved, etc.
Hah, you even changed the SI knob. What gauge cluster is that? That interior makes we want to throw up on my shoes... in a good way... cause I don't have it.
Old 01-13-2012, 03:39 PM   #344
RallySport Direct
Member#: 33174
We are Open Late!
Thanks.
Dyno's are just tuning tool, so peak numbers dont mean much until you have before and after numbers to compare to from the same dyno.
This particular dyno puts stock STi's around 215-220 WHP range, so with that being the start we are about 100WHP up from stock. Along with using 10% enthonoled 91 octane fuel.
The spoiler did change the look of the car quite a bit, however its one of those things most people either love or hate.
http://www.rallysportdirect.com/JPM-...-Red-Stitching
http://www.rallysportdirect.com/JPM-...-STI-2008-2011
http://www.rallysportdirect.com/Prov...ive-Dial-Black
http://www.rallysportdirect.com/Prov...-STI-2008-2011
http://www.rallysportdirect.com/Brid...at-Low-Cushion
http://www.rallysportdirect.com/Taka...t-Harness-Long
http://www.rallysportdirect.com/Taka...-Shoulder-Pads
Other then that, the rear seats, pillars, Dash, center cosole was a custom job by JPM Coachworks. For stuff like that I suggest to contact them directly for the most accurate quote, it is several thousandth to have the entire interior wrapped as in our STi.
Kirill
RallySportDirect.com
Old 01-13-2012, 04:36 PM   #345
jollyblue84
Member#: 292300
01 GC8
blue
Very nice.
jollyblue84 is offline   Reply With Quote
Old 01-15-2012, 10:36 PM   #346
amvegeta
Member#: 148342
Good job very nice sti!!!
amvegeta is offline   Reply With Quote
Old 01-22-2012, 03:51 PM   #347
diablo2184
Member#: 278224
favorite color on them. im growing on the new body style. looks good!
diablo2184 is offline   Reply With Quote
Old 02-16-2012, 07:33 PM   #348
RallySport Direct
Member#: 33174
We are Open Late!
Old 02-17-2012, 12:30 AM   #349
WR Boxer
Member#: 171395
2004 STi
Java Black Pearl
If it doesn't save weight, what's the point? The back of the car looked really good being all one color.
WR Boxer is offline   Reply With Quote
Old 02-17-2012, 11:35 AM   #350
Omega_2nr
Member#: 298119
I normally love real CF.
But d00d, somehow the STi now looks like Charlie Chaplin or something:
Omega_2nr is offline   Reply With Quote
AVO's 2011 STI Sedan is here! AVOturboworld Member's Car Gallery 192 01-29-2011 04:55 PM
2011 STI sedan on the 'Ring BlueLGT General Community 5 06-09-2010 10:57 AM
2011 STi Sedan at NY Auto Show Interior Flair Texas Impreza Club Forum -- TXIC 54 04-05-2010 07:31 PM
2011 STi sedan remotehuman New England Impreza Club Forum -- NESIC 55 04-04-2010 10:48 PM
