Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 05-13-2012, 04:19 PM   #376
Mchang
Member#: 320013
Lovin the look of the blue against white !
Mchang is offline   Reply With Quote
Old 05-13-2012, 05:47 PM   #377
Pearly_Whites
Member#: 164714
2007 WRX TR
Satin White Pearl
Originally Posted by RallySport Direct
Happy Monday!
How did you get that much rear camber when the toe is only adjustable? My rear camber zeroed or toe in -1* is only around 1.5-1.7
Pearly_Whites is offline   Reply With Quote
Old 05-13-2012, 05:54 PM   #378
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
We are using the Cusco Trailing Arms and Lateral Links along with the Whiteline Toe Arms. This gives us full suspension adjustment in the rear as far as we can go until the axles are maxed out.
http://www.rallysportdirect.com/Cusc...r-Lateral-Link
http://www.rallysportdirect.com/Cusc...r-Trailing-Arm
http://www.rallysportdirect.com/Whit...h-Toe-Lock-Kit
RallySport Direct is offline   Reply With Quote
Old 05-15-2012, 01:16 PM   #379
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Originally Posted by RallySport Direct View Post
Proto Holder!
The AP is now safe and sound in the grips of Proto
Wonder if it fits in the LegGT and where can I get it?
Leonardo is offline   Reply With Quote
Old 05-15-2012, 01:29 PM   #380
RallySport Direct
Member#: 33174
We are Open Late!
They are universal
http://www.rallysportdirect.com/cata...to+tuning+tool
Old 05-15-2012, 01:32 PM   #381
CobbWRX
Member#: 310040
2004 WRX and 15 sti
Can't wait to
Order mine!
CobbWRX is offline   Reply With Quote
Old 05-15-2012, 04:25 PM   #382
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
PM me a price shipped please!
Old 05-15-2012, 08:36 PM   #383
PearlRex11
Member#: 284420
2011 WRX Sedan
I will be picking up one of these fa sho
PearlRex11 is offline   Reply With Quote
Old 05-19-2012, 06:52 PM   #384
RallySport Direct
Member#: 33174
We are Open Late!
...more details on Monday
Old 05-20-2012, 07:31 AM   #385
DeadGeneration
Member#: 313753
2012 WRX
Dark Gray Metallic
No sedan exhaust from Cobb after this long?
DeadGeneration is offline   Reply With Quote
Old 05-21-2012, 03:59 PM   #386
RallySport Direct
Member#: 33174
We are Open Late!
Event: Dyno Tune/ Product Testing
Ambient Temp: 75-80F
Ambient Pressure 12.7psi/ 86kPA
Elevation: 4600ft
Weather: sunny
Car: 2011 STi
Tuner: Christian of Cobb Tuning
Dyno Info: Mustang
Transmission: 6spd,
Gear: 4th
Peak HP at RPM 91 Octane : 336WHP @ 5600RPM. Corrected
Peak Torque at RPM 91 Octane: 337WTQ @ 4600RPM Corrected
Peak HP at RPM 104 Octane: 383WHP @ 5600RPM. Corrected
Peak Torque at RPM 104 Octane: 382WTQ @ 4600RPM Corrected
Baseline hp/tq for a stock on same dyno: Stg2 2011 STi 262HP and 286TQ.
Target Boost: S# on Pump Gas 22PSi, S# on Race Gas 25PSi
Target AFR: 10.8-11.4 depending on the fuel
Fuel: 91octane with 10% ethanol, Sunoco GT104 unleaded.
Engine/Power Modifications:
Cobb Tuning AccessPort
Cobb Tuning Down Pipe
Cobb Tuning Heat Shield
Invidia Q300 Ti Tip Catback
ATP GTX3076
Cosworth Intake
Cosworth TGV Delete
GT Spec Oil Sandwich Block Adapter
Samco Radiator Hose Kit
Koyo Aluminum Racing Radiator
Omni Power 4 Bar map sensor
Injector Dynamic 1000cc TopFeed injectors
DeatschWerks 300lph Fuel Pump
Process West Top Mount Intercooler
Tomei Fuel Pressure Regulator Type-S
Tomei Fuel Pressure Gauge
Tomei Expreme Unequal Length Exhaust Manifold
GrimmSpeed Air Oil Separator
GrimmSpeed Electronic Boost Controller
AMR Performance Cast Turbo Inlet
GTSpec 44mm V-Band 3-Bolt External Wastegate Uppipe
TurboSmart Duel Port Blow Off Valve
Turbosmart Hyper-Gate45 Wastegate
Prova Radiator Cap
Drivetrain:
MODE RACING Double Adjustable Short Shifter
Kartboy Front Shifter Bushings
Kartboy Rear Shifter Bushings
PST Carbon Fiber Driveshaft
91 Octane Vs Stage2
104 vs Stage2
GT104 S# vs 91 S vs 91S#
Conclusion from our Test:
Starting off from where we left off on our 2011 STi sedan.
After finishing product testing on the Tomei Arms M7960 it was time to test out another turbo. We chose to go with the brand new state of the art GTX billet wheel technology from Garrett, and use the ATP GTX3076R Stock location turbo.
The goal for this stage of the build was to really maximize and fully utilize the stock components along with having a very fun and efficient car that was realistic for someone to drive on the street, track or drag. This turbo would be the perfect match for anyone who is trying to get the most out of a stock motor, have quick response, and have one wicked car.
To put everything out on the table, we really feel as though we were maximizing several key components on the car, the motor, and clutch is still 100% stock. The Process West intercooler was getting close to its peak efficiency, the turbo was running at 25Psi, and given the octane of fuel we were getting close to the peak stability point of both fuels that where being used. The amazing thing is just how fast this turbo spools, looking at both race and pump gas you can see that compared to the stock VF48 the increase in lag is quite minimal for the huge gain in performance. Also given the altitude of 4200ft this turbo, compared to sea level it would be able to easily produce over 400WHP at similar conditions do to the increased air density.
The power delivery on the vehicle is very smooth and predictable, given the high efficiency TMIC the lag is kept to a minimal and the throttle is very responsive. The vehicle very easy to drive, quick, fun, and overall a simple build utilizing quality bolt on components from proven manufactures ensuring that everything is running at a safe and optimal level.
Huge thanks to the following manufactures:
Cobb Tuning
Tomei
GrimmSpeed
ProcessWest
Cosworth
TurboSmart
Please let us know if you have any questions
Kirill
RallySportDirect.com
Old 05-28-2012, 10:35 AM   #387
DcSports92
Member#: 112041
1992 Subaru Legacy
Light Blue
Such a beautiful transformation.
DcSports92 is offline   Reply With Quote
Old 06-02-2012, 03:15 AM   #388
wrx yo
Member#: 231825
2011 WRX YO
seems a little low...
wrx yo is offline   Reply With Quote
Old 06-02-2012, 06:42 PM   #389
RallySport Direct
Member#: 33174
We are Open Late!
Oh snap!
Someone got a little brother
Old 06-05-2012, 12:50 PM   #390
RallySport Direct
Member#: 33174
We are Open Late!
From this Weekends JDMLegends Meet
Old 06-05-2012, 01:25 PM   #391
jockeygolfs
Member#: 260868
2011 STI
How does the AMR hard pipe line up with the turbo? Nice clean fit? Is there a nipple that is missing on it compared to the stock inlet? If so did you guys just tee together two of the returning lines?
jockeygolfs is offline   Reply With Quote
Old 06-05-2012, 01:27 PM   #392
RallySport Direct
Member#: 33174
We are Open Late!
The fitment is tight, but it does fit. Given its a 3" turbo, its about as good as I have seen from others.
As for the PCV system, we are running it through the GS AOS so its a bit different in that department compared to stock.
Old 06-25-2012, 04:58 PM   #393
JMann880
Member#: 253090
2010 Audi S4
Meteor Gray Pearl
the Alpine Rhino is looking sharp!
JMann880 is offline   Reply With Quote
Old 07-10-2012, 10:20 AM   #394
Lewiz555
Member#: 325690
like the stance
Lewiz555 is offline   Reply With Quote
Old 07-14-2012, 08:17 PM   #395
nickg92386
Member#: 326151
That thing is badass!
nickg92386 is offline   Reply With Quote
Old 07-17-2012, 07:54 PM   #396
RallySport Direct
Member#: 33174
We are Open Late!
Sorry for the long wait on the images, with the BNW event last weekend it took us a couple days to get the images.
But must say it does look great, and the install only took a few min.
Carbing Craft 2011+ STi and WRX Sedan rear bumper garnish.
Old 07-17-2012, 08:47 PM   #397
Pearly_Whites
Member#: 164714
2007 WRX TR
Satin White Pearl
Subtle and sexy. I need that piece. What's the price on these?
Old 07-18-2012, 12:15 AM   #398
RallySport Direct
Member#: 33174
We are Open Late!
sent you a PM
Thanks,
Rick
Old 07-18-2012, 12:26 AM   #399
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Really nice piece. No hatch love?
smeerone is offline   Reply With Quote
Old 07-18-2012, 02:08 PM   #400
Pearly_Whites
Member#: 164714
2007 WRX TR
Satin White Pearl
sent you a PM
Thanks,
Rick
Got it. Wasnt expecting that much. Probably going to wait, but they do look like great quality
AVO's 2011 STI Sedan is here! AVOturboworld Member's Car Gallery 192 01-29-2011 04:55 PM
2011 STI sedan on the 'Ring BlueLGT General Community 5 06-09-2010 10:57 AM
2011 STi Sedan at NY Auto Show Interior Flair Texas Impreza Club Forum -- TXIC 54 04-05-2010 07:31 PM
2011 STi sedan remotehuman New England Impreza Club Forum -- NESIC 55 04-04-2010 10:48 PM
