Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 07-18-2012, 02:23 PM   #401
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Originally Posted by smeerone View Post
Really nice piece. No hatch love?
Jumping the gun
Should have some hatch models shorty as well
Kirill
RallySportDirect.com
RallySport Direct is offline   Reply With Quote
Old 07-30-2012, 12:35 PM   #402
RallySport Direct
Member#: 33174
We are Open Late!
So exactly 2 years ago today we got our 2011 STi.
Its been a great 2 years, not only having fun building this great project, but also testing new products, and also friendships that have been established!
So want to say thank you to everyone that has followed the build from the start, and everyone who has been involved. Even to this day we still have people pull us over on the roads, kids come up, and enthusiasts all around the country and the world enjoy the project as much as we have.
Thank you and we hope everyone has been enjoying this project as much as we have!
Kirill
Old 07-30-2012, 02:23 PM   #403
RallySport Direct
Member#: 33174
We are Open Late!
Picture from over this weekend at Miller Motorsports Park, LapBattle Time Attack event
Old 07-31-2012, 10:47 AM   #404
Caballo
Member#: 158369
2011 WRX
white
nice! I didn't realize you tracked this, too. Glad to see the parts getting put to good use!
Caballo is offline   Reply With Quote
Old 08-02-2012, 10:57 PM   #405
pegruder
Member#: 325584
2012 Impreza WRX
DGM - Stg2 304whp/308wtq
I absolutely love this car!
pegruder is offline   Reply With Quote
Old 08-04-2012, 02:15 AM   #406
Sqrl
Member#: 306611
2010 STI
Default Build #1 vs. #2
1) Will you provide us with a description of what you liked and/or didn't like in build 1 and build 2, and the pros and cons of each. Was build 2 the same goal as build 1 *with the goal of good low and mid range TQ, throttle response and quick spool up?
2) Which turbo did the RSD team like best? Is one better for one type of driving/goals and the other better for another? I'm sure I'm not the only person agonizing over which turbo upgrade to go with
3) Is there anything you would have done different or that you learned from either build that you can share with us?
Thanks!
Sqrl is offline   Reply With Quote
Old 08-04-2012, 07:52 PM   #407
RallySport Direct
Member#: 33174
We are Open Late!
Thanks!
We did the build power wise 3 ways. 1 was stage2, 2 was the Tomei Turbo, and 3 was the ATP turbo.
For stage 2 the best thing is that its very simple and used basic Off the Shelf Parts with Off The shelf Tuning. Best part is that you simply get an AccessPort, exhaust, intake, grab a buddy to help you install the parts and a few hours later you have a very safe and easy way to get the most out of the stock turbo.
For the Tomei Turbo, this was a bit involved as we upgraded all the supporting parts other then the Motor internals. The cool thing about this turbo is it really allowed us to max out the fuel we had around us and the instal was very straight forward. The turbo didnt have much more room to go as it was at its efficency, but for pump gas it was perfect.
The ATP turbo was a bit more involved, do to the physical size it was a bit more work to fit including having to do a 3" inlet. If you notice we didnt gain much more peak power numbers over the Tomei on pump gas, as pump fuel was the limiting factor. However it gave us ALLOT more head room to make power on race gas. The catch 22 on the ATP is the turbo has more to give then what we want to push the stock motor past, and as you can tell we stopped in the 380WHP range even though it has more room to go.
Goal for both ATP and Tomei turbo was to simply maximize the stock motor and pump fuel. I wouldnt say that one turbo is better then the other per say as they are simply different. The ATP uses the new GTX series billet wheel so this would be the new Hotness of turbo technology, however the price point shows this. Where the Tomei is a great turbo with out breaking the bank (or the motor). Overall both turbos work great, but do react different. The ATP is more responsive on building pressure and has a much larger power band, however this is to be expected with brand new technology of Billet wheels and ball bearing center cartage.
As for doing anything different, I dont think we would have. We got to try out several products and put up our research on the products for the Subaru community. Learn about what the car likes and doesnt like, and really explore the capability of the car
Kirill
Old 08-04-2012, 10:23 PM   #408
Sqrl
Member#: 306611
2010 STI
Thanks for the in-depth explanation, we appreciate it!
Old 08-22-2012, 08:47 PM   #409
PEAKING STI06
Member#: 329932
Nice build....
PEAKING STI06 is offline   Reply With Quote
Old 08-23-2012, 07:51 PM   #410
RallySport Direct
Member#: 33174
We are Open Late!
Thank you!! We appreciate all the support!
Rick
Old 09-02-2012, 03:51 PM   #411
jockeygolfs
Member#: 260868
2011 STI
Can you guys discuss what mods to the fuel pump housing was done to fit the DW300? I have a walbro already and have removed five tabs to get that in. I'm under the assumption that since I have done that already that the DW300 should drop right in now. Correct?
jockeygolfs is offline   Reply With Quote
Old 09-02-2012, 04:09 PM   #412
RallySport Direct
Member#: 33174
We are Open Late!
The install for the DW300 and the Walbro will be identical.
I used the how to: below to do the one on our car as it was the 1st that I modified for this. Only difference I did was to use a 3/16" hose on the top of the pump instead of a O ring to create a better seal. Took a bit more work to fit the pump, O ring and the upper 1/2 of the housing together. However with a little lube it made it allot easier.
http://www.iwsti.com/forums/how-inst...i-wrx-lgt.html
Hope this helps
Kirill
Old 09-02-2012, 04:40 PM   #413
jockeygolfs
Member#: 260868
2011 STI
Thank you! Great to read that I'm already there.
Old 09-02-2012, 09:52 PM   #414
altezza2impreza
Member#: 95516
2011 WRX
how are the 23/20 sways working? would you recommend this setup for a 11 wrx hatch?
altezza2impreza is offline   Reply With Quote
Old 09-04-2012, 04:31 PM   #415
RallySport Direct
Member#: 33174
We are Open Late!
Sway bar sizing very much depends on the spring rates that yous suspension is using.
For soft(er) spring rates you will use bigger bars to counteract body roll
For stiff(er) spring rates you will use not as big of a bar, as the springs will do a good job at reducing body roll.
With the Tein Mono-Flex coilovers we felt as this size of sway bar did a very good job to balance the car out and maintain neutral feel while working with the spring rates and shocks that we are using.
There is no cookie cutter approach to the sway bar sizes to be honest, as it changes based on other suspension components.
Kirill
Old 10-11-2012, 03:24 PM   #416
RallySport Direct
Member#: 33174
We are Open Late!
From SubieFest 2012
Old 10-21-2012, 11:12 AM   #417
bspec
Member#: 215964
2008 Legacy spec.B
QSM
Looking good. I'd love to see it in person next time I'm in SLC (Draper) for work.
bspec is offline   Reply With Quote
Old 10-21-2012, 11:27 AM   #418
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Hey Kirill, anything for the 09 Smart FourTwo "451" ?
Leonardo is offline   Reply With Quote
Old 10-22-2012, 04:17 PM   #419
RallySport Direct
Member#: 33174
We are Open Late!
Can you spot the new items?
Kirill
Old 10-22-2012, 04:17 PM   #420
RallySport Direct
Member#: 33174
We are Open Late!
Lost on that question hahahah. Shoot me over a PM
Kirill
Old 10-23-2012, 11:00 AM   #421
Jdub.csu
Member#: 283784
2013 EVO X GSR
Kirill
Radiator CF Shroud
Strut tower brace is newish
Jdub.csu is offline   Reply With Quote
Old 10-23-2012, 03:13 PM   #422
RallySport Direct
Member#: 33174
We are Open Late!
Originally Posted by Jdub.csu View Post
Radiator CF Shroud
Bingo!
Kirill
Old 10-23-2012, 06:36 PM   #423
Jdub.csu
Member#: 283784
2013 EVO X GSR
Do I get a prize? Lol
Old 10-23-2012, 06:43 PM   #424
RallySport Direct
Member#: 33174
We are Open Late!
Hahahaha, sure
Next time you place a order, call in and ask for me. ill throw in a free hat for you
Kirill
Old 10-23-2012, 06:47 PM   #425
easterbran
Member#: 307359
'05 STi Stage II
Hahahaha, sure
Kirill
Lol that's awesome
easterbran is offline   Reply With Quote
AVO's 2011 STI Sedan is here! AVOturboworld Member's Car Gallery 192 01-29-2011 04:55 PM
2011 STI sedan on the 'Ring BlueLGT General Community 5 06-09-2010 10:57 AM
2011 STi Sedan at NY Auto Show Interior Flair Texas Impreza Club Forum -- TXIC 54 04-05-2010 07:31 PM
2011 STi sedan remotehuman New England Impreza Club Forum -- NESIC 55 04-04-2010 10:48 PM
