Welcome to the North American Subaru Impreza Owners Club Tuesday January 27, 2015
Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 01-12-2011, 11:26 AM   #151
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Originally Posted by Leonardo View Post
Loving this car!!
Any chance to get the Prova mirrors for the BL/BP Legacy, Specially in Blue?
Originally Posted by RallySport Direct View Post
I got 1 set in stock. Give us a call and we can get them for you
Will do!
I still want these, just for the record.
Leonardo is offline   Reply With Quote
Old 01-12-2011, 11:59 AM   #152
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Let us know when your ready
Only thing is that the OEM mirrors are flat, these are convex. In japan the OEM mirrors are also convex. The Prova mirror uses a double sided adhesive on the back side to mount to the stock lens. As the OEM mirror in US is flat and these are convex you will want to add some extra double sided adhesive to the back side of the mirror in the center to prevent it from falling off and giving you the best contact.
We did this on our STi and they are on there to stay. We have seen people not do this and they have fallen off, so just keep in mind that you will need to buy about $4 of double sided tape from your local hardware store to ensure these puppies stay on.
Kirill
RallySportDirect.com
RallySport Direct is online now   Reply With Quote
Old 01-12-2011, 12:04 PM   #153
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
I have a roll of 3M waiting!
Old 01-13-2011, 04:39 AM   #154
team23jordan
Member#: 48132
2011 STi
the car is pure sex!!
subscribed!
team23jordan is offline   Reply With Quote
Old 01-13-2011, 07:32 PM   #155
RallySport Direct
Member#: 33174
We are Open Late!
Engine bay...Stock for now
How do you get -4.25 degrees of camber with still some camber to go? Easy max out your Top hats
Old 01-13-2011, 07:36 PM   #156
RallySport Direct
Member#: 33174
We are Open Late!
And this is how she sits while its cold and snowy outside. We fire her up every few days and drive it around the block, but with constant snow we have to wait for the roads to be dry and clean.
Stickers all removed. What you guys and gals think?
My fingers still hurt from helping peal the stickers off. Putting on stickers is 10X easier then taking them back off I swear.
The Cobb Exhaust got stolen by Cobb a few weeks ago so that they could use it to make a jig and put it into production.
Kirill
Old 01-13-2011, 08:16 PM   #157
betterthansx
Member#: 259103
11' STI
What are the mod plans for this beast? Rotated GT35?
betterthansx is offline   Reply With Quote
Old 01-14-2011, 11:13 AM   #158
JohnnyG
Member#: 164671
2009 WRX 265
How do you have the harnesses mounted in the rear seats? Are you using the ISOlatch connections for child seats?
JohnnyG is offline   Reply With Quote
Old 01-14-2011, 11:21 AM   #159
RallySport Direct
Member#: 33174
We are Open Late!
Not 100% set on turbo size, but something in the 50lb range. Simple reason is response and drivability. Huge turbo's are fun, but mid range TQ, throttle response and quick spool up will be the main concerns.
We used I bolts in place of where the hardware went to hold in the stock seat belts. Giving a much better anchor point.
Old 01-14-2011, 11:35 AM   #160
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Love it without the decals!
Go with the Borg Warner twin scroll setup with their new turbos. Saw it at PRI and I'm still drooling.
Old 01-14-2011, 05:41 PM   #161
blue_wrx_chic03
Member#: 34519
03 WRX
WRX blue
i have pics on my iphone from the pri show that i took of that turbo setup, it would be pretty wicked on that car. i spend a bit of time there drooling on it.
blue_wrx_chic03 is offline   Reply With Quote
Old 01-14-2011, 06:35 PM   #162
THE_SMURF
Member#: 260624
2007 Z06/ZX10R
Originally Posted by ryyiann View Post
why not just buy a base wrx and dump a **** ton of money into it rather than taking apart an sti and putting money into it... i suppose because of the new modeled sti sedans
thats what they all do, buy an STI and automatically swap the seats, brakes, wheels and change the exterior, put a big turbo, build the block and most of the times leave the trans alone.
Originally Posted by logic246 View Post
It is a waste of money to try to make a base wrx into an STI far less a high performance car.
Reason we chose the STi is some of the benefits that it has over the WRX. The 6spd transmission with 3 LSD's and DCCD make it a much more potent vehicle when driven hard. 5X114.3 is also another huge benefit, as the wheel bearings hold up much better. Then the ABS is much more complex on the STi and is designed to work much faster and is more controllable then the WRX.
The new WRX is a great platform and a solid car, the STi just comes with some nice features that are hard to pass up for not much more money.
3 LSDs yes, good reason, i mean you buy 1 for the WRX and she is still golden
6 speed trans, well throw in some PPG gears and problem solved
never had a problem with my wheel bearings
a more complex ABS is well over rated
and considering most things are swapped when bought i think its not much money to waste, but not mine none the less, car does look good.
THE_SMURF is offline   Reply With Quote
Old 01-17-2011, 08:56 PM   #163
subaru_kid
Member#: 207888
2003 Impreza 25RS
Platinum Silver
Isn't that spot a bad idea for racing due to how low it is? Or are the belts just more for looks? Just curious.
We used I bolts in place of where the hardware went to hold in the stock seat belts. Giving a much better anchor point.[/quote]
subaru_kid is offline   Reply With Quote
Old 01-17-2011, 11:11 PM   #164
B03scooby
Member#: 102929
200_ 07STi,03,07 STi
SWP/ WRB/UGM#239
car looks super clean without the decals
B03scooby is offline   Reply With Quote
Old 01-17-2011, 11:30 PM   #165
subaru_kid
Member#: 207888
2003 Impreza 25RS
Platinum Silver
Either way it looks good.
Old 01-20-2011, 02:17 AM   #166
soundsofsnow
Member#: 230039
99 Camry of doom
Rust
Clean! I'm not diggin the three gauges on deck though.... gotta hide that stuff to keep it cleanER.
soundsofsnow is offline   Reply With Quote
Old 01-20-2011, 10:47 AM   #167
betterthansx
Member#: 259103
11' STI
Kirill
Silly question perhaps, but how strong are the tow hooks? Would they be strong enough to pull another vehicle out of the ditch? We have had some crazy snow here lately and just curious if I ever needed to lend a helping hand
Old 01-20-2011, 03:00 PM   #168
RallySport Direct
Member#: 33174
We are Open Late!
These are more or less designed to pull the car out of sand traps or just short distance pulling. I dont think they would hold up trying to pull a F150 out of a ditch.
Old 01-21-2011, 04:06 AM   #169
vashiori
Member#: 173721
'11 SWP WRX GV
I <3 SBC
need more pics of the car w/out stickers please! perhaps side view and back view??? debating if I wanna do completely white trunk like you guys
vashiori is offline   Reply With Quote
Old 01-22-2011, 12:32 AM   #170
808hi
Member#: 88726
2011 Impreza STi
would the tow hooks be able to tow a uhaul trailer if im moving furniture and what not for the day, or would it stress out the car too much?
808hi is offline   Reply With Quote
Old 01-22-2011, 09:23 AM   #171
Hokie-wrx wagon
Member#: 87194
2008 Impreza WRX STI
Spark Silver Metallic
Definitely not! You'd need an actual tow hitch mounted to the car's frame for any kind of towing.
Hokie-wrx wagon is offline   Reply With Quote
Old 01-23-2011, 11:16 AM   #172
Snig
Member#: 152466
JDMTrollisJDM.
Snig is offline   Reply With Quote
Old 01-23-2011, 04:21 PM   #173
Nate_1990
Member#: 234485
2004 STI
Rally Blue
I used one of your tow hooks to pull my friends chevy 1500 out of the snow. Mind you it wasn't 100% my end he was going in reverse but these tow hooks are beast.
Nate_1990 is offline   Reply With Quote
Old 01-23-2011, 04:23 PM   #174
Nate_1990
Member#: 234485
2004 STI
Rally Blue
oh and I'm loving the cosworth intake, keep up the good work.
Old 01-24-2011, 12:57 PM   #175
RallySport Direct
Member#: 33174
We are Open Late!
More sticker less images
AVO's 2011 STI Sedan is here! AVOturboworld Member's Car Gallery 192 01-29-2011 05:55 PM
2011 STI sedan on the 'Ring BlueLGT General Community 5 06-09-2010 11:57 AM
2011 STi Sedan at NY Auto Show Interior Flair Texas Impreza Club Forum -- TXIC 54 04-05-2010 08:31 PM
2011 STi sedan remotehuman New England Impreza Club Forum -- NESIC 55 04-04-2010 11:48 PM
