Old 08-17-2010, 02:26 AM   #1
carlosdevil10
Member#: 221625
2002 WRX Bugeye
blue
Default ecuflash can't read ecu
hi i'm from guatemala and have the following trouble, i just buy a 1.3U cable from limitless but can't read my ecu. 2002 wrx usdm.I try to read following these steps.
-2 pair green connectors connected
-reflash connector connected
-already try ecuflash 1.291, 1.42
-try putting the ignition to 'on' at the same time as hitting ok, also after hitting ok and earlier.
- cable is installed in COM4
-ecu is stock no ecutek tune
please help i want to get rid of a cel , thanks
it starts ro load but after kernel get version it close interface.
carlosdevil10 is offline   Reply With Quote
Old 08-17-2010, 02:28 AM   #2
Chi_San
Member#: 53558
2002 WRX Wagon
Check the passenger side footwell for a second pair of green test connectors, and make sure they are also plugged in.
The connectors may be under the trim next to the door hinges.
Chi_San is offline   Reply With Quote
Old 08-17-2010, 09:45 AM   #3
SnowmanFX
Member#: 25753
2015 WRX
Lightning Red
I am having the same issues. I will check the connectors on the other side of the car today.
SnowmanFX is offline   Reply With Quote
Old 08-17-2010, 09:46 AM   #4
carlosdevil10
Member#: 221625
2002 WRX Bugeye
blue
i have already check it and they are connected.
Old 08-17-2010, 10:22 AM   #5
quazimoto
Member#: 70395
Call Limitless. I think I remember several people having issues with their cables. Take a screenshot of the Ecuflash page after you try to connect and post it up here.
quazimoto is offline   Reply With Quote
Old 08-17-2010, 06:15 PM   #6
surfrjag
Member#: 225671
2002 wrx impreza
the black pearl
i had same issue it sounds like. if it is the same issue, i ended up having to hit ok, then wait like 3 seconds then turn the key. sometimes takes me 20 tries to connect. other times i do it this way and it connects right away... the 02-03 are a pain to connect to sometimes
surfrjag is offline   Reply With Quote
Old 08-18-2010, 11:38 AM   #7
carlosdevil10
Member#: 221625
2002 WRX Bugeye
blue
you have a tactrix or limitless cable?? so you say try like 20 times to see if it works
Old 08-18-2010, 12:46 PM   #8
carlosdevil10
Member#: 221625
2002 WRX Bugeye
blue
this is the error i get.
Old 08-19-2010, 12:09 AM   #9
surfrjag
Member#: 225671
2002 wrx impreza
the black pearl
taxtrix 2.0 is what i use but should not matter yours is a taxtrix right? looks like the same error i get... try my method a few times and let us know if it works. car is going into text mode right? check engine light flashes as soon as you turn the key and fuel pump and fans cycle?
Old 08-19-2010, 11:30 PM   #10
carlosdevil10
Member#: 221625
2002 WRX Bugeye
blue
yes it is in test mode check engine light flashes ok i will try it like twenty times.
Old 08-19-2010, 11:37 PM   #11
carlosdevil10
Member#: 221625
2002 WRX Bugeye
blue
should i change ecuflash version?? im now using 1.43 beta
Old 08-20-2010, 04:35 PM   #12
NightCat
Member#: 254027
2006 Subaru WRX STi
same thing happens to me on my 1.3u cable on 02 wrx's
NightCat is offline   Reply With Quote
Old 08-21-2010, 12:56 PM   #13
carlosdevil10
Member#: 221625
2002 WRX Bugeye
blue
ok now im very angry i try like twenty times after ok , before ok and in the same time and the same error ahhhhhhhhhhhhh i just want to delete the cel code please help with this
Old 08-21-2010, 02:34 PM   #14
quazimoto
Member#: 70395
I'm pretty sure its the cable......
Old 08-22-2010, 10:05 PM   #15
carlosdevil10
Member#: 221625
2002 WRX Bugeye
blue
i start to think is the cable two because a already try it with two computers and the same thing try it in other car and nothing , limitless sucks . Today i contact limitless and they say send back the cable to replacement and i live in guatemala city very happy to pay shipping again.
Old 08-23-2010, 10:58 AM   #16
sidewayz
Member#: 5810
2001 S366 2.5RS
use the 2.0 cable.. the older cable is prone to work/not work
sidewayz is offline   Reply With Quote
Old 08-23-2010, 12:04 PM   #17
carlosdevil10
Member#: 221625
2002 WRX Bugeye
blue
i will return that 1.3U and get the 2.0 instead
Old 08-25-2010, 10:49 PM   #18
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
or ur ecu is locked
07wrx84 is offline   Reply With Quote
Old 08-26-2010, 12:59 PM   #19
carlosdevil10
Member#: 221625
2002 WRX Bugeye
blue
Originally Posted by 07wrx84 View Post
or ur ecu is locked
could it be locked when it is stock??
Old 08-26-2010, 01:00 PM   #20
carlosdevil10
Member#: 221625
2002 WRX Bugeye
blue
hi could someone help me with the address of limitless because i post a ticket in their page and no one answer
Old 09-06-2010, 04:06 PM   #21
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
It shouldn't be but if it's used u never know?!?!?
Old 09-07-2010, 02:27 AM   #22
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
if the fans start cycling and the CEL flashes when you are trying to flash it means that the ECU is not seeing the proper flash voltage and therefore does not go into the mode where it will allow a read/write of the map. Instead it is going into diagnostic mode. You could try to jump voltage to the appropriate pin perhaps??
ProdriveDreams is offline   Reply With Quote
Old 09-07-2010, 09:04 AM   #23
Drunkinchef
Member#: 145324
1991 MR2 T-Bar Turbo
Red
You've got to be kidding me! I have the same issue. If this cures it I'm going to crap myself! Thanks ProdriveDreams! I'll try this as well.
Drunkinchef is offline   Reply With Quote
Old 09-07-2010, 01:51 PM   #24
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
When in flash mode i believe the brake light and alternator light come on, but your CEL and airbag do not they might come on for a split second but immediately go out and nothing is flashing. this is why sometimes hitting ok a few seconds before trying to flash works, because it tells the ECU to go into flash mode before it powers on.
I tried searching around but my lunch break is short and I couldn't find anything quickly. Try posting a seperate thread asking specifically that if you can't find it. Or try PMing 'Colby'/searching around at open ECU as he built a usb cable for subaru's
Old 10-16-2010, 08:51 PM   #25
barneyprotune
Member#: 260267
Angry Same Issue
I got the cable ver 2.0 from tackrix and am having the same issue , exactly the same, TO add on i have tried my cable on abt five cars , when i plug the tactrix cable to an Obd2 for other cars coz i have the softwares it works pretty well, My suspect is ecu flash something is not compatible , i just wish i knew what, Ma on a laptop win xp service pack 2.
barneyprotune is offline   Reply With Quote
EcuFlash error message/can't read ecu. bluert Open Source Reflashes 7 08-12-2009 06:40 PM
Ecuflash can't read 2.5RS? formula91 Open Source Reflashes 0 04-24-2009 02:44 AM
Can't read ECU jarencibia Open Source Reflashes 2 10-17-2008 11:48 AM
2007 2.5i EcuFlash prob reading ECU GrundleJuice Open Source Reflashes 3 02-21-2008 09:40 AM
need help! can't read ecu thru ECUFlash sgmongoose Commercial ECU Reflashes 9 08-08-2007 11:58 AM
