Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 08-17-2010, 10:37 AM   #1
Payback45
Member#: 129370
2009 Legacy GT LTD
Default Thermo and cam seals Now?
Is it a good idea to change the cam seals and thermo when doing a timing belt job?
Payback45 is offline   Reply With Quote
Old 08-17-2010, 12:25 PM   #2
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
Yes.
Also do the front oil pump seal and install a new water pump.
PhilSine is offline   Reply With Quote
Old 08-17-2010, 12:48 PM   #3
Payback45
Member#: 129370
2009 Legacy GT LTD
The water pump will be done. Is the front oil pump seal a big deal to change? is it expensive?
Old 08-18-2010, 02:57 AM   #4
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
Front oil pump seal costs around $8.00 and its basically the same as the cam seals in terms of removal and installation. Simply slide the crank gear off the end of the crank and go from there.
Old 08-18-2010, 11:22 AM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I vote no on the cam seals and the water pump. I think people on this forum love to do unnecessary preventive maintenance based on a ridiculously small sample of data.
Old 08-19-2010, 03:42 AM   #6
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
So, what you're saying is that its a better idea to skip the $8.00 seals and $50 water pump and gamble that they will both last until the next timing belt is needed?
If you do not do the seals when you have things apart already and they happen to fail within the next 100k miles (and they often do) then you'll need to spend another 3-5 hrs of your time and another $12 on coolant to replace them.
If you do not replace your water pump when you have things apart already and it happens to fail within the next 100k miles (and they often do) then you'll need to spend another 3-5 hrs of your time and another $12 on coolant when you replace it. Even worse is the prospect of a water pump failure where it siezes and chews the timing belt thus taking the valves with it. While water pumps do not typically fail in this fashion, do you really want to risk it?
Old 08-19-2010, 04:42 AM   #7
Henry H
Member#: 184330
2008 Impreza 2.5i
Dark Grey Metallic
With an intensive 105k maintenance interval with relatively cheap parts, I tend to agree with Phil.
FWIW I do my timing belt along with my 90k maintenance. You'd have to have had your car for 720,000 miles to "waste" an extra timing belt change.
Henry H is offline   Reply With Quote
Old 08-19-2010, 10:50 AM   #8
mostasteless
Member#: 52631
2004 WRX
I would highly recommend doing the water pump and changing the oil pump seal when doing the timing belt. It's easy, will cost you less than $100 and save you hours of labor down the road because one of the two are bound to start failing before you are due for another timing belt change. You don't have to do the thermostat but if you are removing the water pump you will have to drain the coolant so swapping it then will save you another coolant flush.
It is also not a bad idea to do the cam seals. Removing the cam sprockets can be a real PITA but once they are off swapping the seals are easy.
mostasteless is offline   Reply With Quote
Old 08-19-2010, 03:03 PM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Yes, because I don't think it's a gamble. If you can provide data that shows that there's a high failure rate, then I'll change my mind. (Note that anecdotal evidence on NASIOC is not data.)
How often is "often"? Do you have any data that shows how frequently the cam seals start to leak vs. mileage? And at what point does a cam seal leak really matter?
How often is "often"? Do you have any data that shows how frequently water pumps fail vs. mileage?
Again, yes, because I don't think it's much of a risk at all. Obviously the stakes are higher for a water pump failure than for a cam seal leak, but either way I think the likelihood of failure is very small. Of course, I base that only on my own anecdotal evidence - we've had 3 high mileage Subarus in my family and I've never seen a WP failure.
Preventive maintenance (replacing something "while you're in there") is basically just risk management. I don't think the risk of failure of those components is high enough to justify doing any extra work to replace them. Others may have a different assessment of the risk. Such is life.
Pat
crank and cam seals Javwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 02-28-2009 01:39 AM
WTB ASAP: 04 WRX head gaskets and cam seals Wrx1234 MWSOC Private Classifieds 2 04-14-2007 05:27 PM
Help with cam seal procedure and SOA TlistGT Service & Maintenance 7 11-15-2006 07:15 PM
Are 1.8 and 2.5dohc cam seals the same? 2slofouru Normally Aspirated Powertrain 2 12-17-2005 01:23 PM
Cam and Crank Seals 97 GT johndingk2 Legacy Forum 8 01-03-2005 01:25 AM
