Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 08-17-2010, 06:14 PM   #1
azn2nr
Member#: 35276
Default HELP!!! dropped my car off for some fab work and now it will not start
if anyone has any experience id greatly appricate it.
i took my car in for a new down pipe and dump tube. no electrical was touched. now i have the issue of the car not starting.
sympotms include.
no CEL when the key is turned to on.
when the fuel pump is pluged in there is no power to the plug. if its unpluged there is power.
key in door chime works.
relays are clicking over
no power at the ignition pin on the ecu and when power is bridged to it manually still nothing happens.
o2 sensors shorting out is the most commonly found issue online so we unpluged both to eliminate possibility of a short. still nothing
all fuses were isolated and checked and all of them are working properly.
this is my second subaru with an electrical gremlin that i am stumped on and as some of you may know the other car still doesnt run after 6 years.
azn2nr is offline   Reply With Quote
Old 08-17-2010, 06:26 PM   #2
nme187
Member#: 117763
I'd suggest checking the Main Relay under the driver dash. That spreads power to the ECU/FPC and so fourth. IIRC it's the brown relay.
nme187 is offline   Reply With Quote
Old 08-17-2010, 06:31 PM   #3
azn2nr
Member#: 35276
checked it. its working
Old 08-17-2010, 07:18 PM   #4
nme187
Member#: 117763
What happens when you turn the key over? Does the motor crank?
Plug in the test mode connectors and see if the ECU shows test mode.
Also what flavor of Subaru is this?
Old 08-17-2010, 08:01 PM   #5
azn2nr
Member#: 35276
its an 06 limited.
the motor turns over.
we are using a snap on ecu reader. ill try your suggestion later.
we forced the fuel pump on but to nothing under the hood is firing due to the ecu not turning on
Old 08-18-2010, 12:41 AM   #6
Subr-man
Member#: 169211
into a gearhead."
Goin' Back Old Skool
KIS, Keep it simple, they must have accidentally unplugged something under the hood.
did u load a tune on to the car too at the time of the down pipe? plugs still connected?
Subr-man is offline   Reply With Quote
Old 08-18-2010, 01:10 AM   #7
azn2nr
Member#: 35276
found the issue. the passenger tgv motor clip somehow got pinched between the turbo and the manifold the wire rubbed through and grounded out. car runs fine now.
Old 08-18-2010, 02:52 AM   #8
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
Haha, you found the needle! Can't believe you found that so quickly.
scoobydorift is offline   Reply With Quote
Old 08-18-2010, 03:02 AM   #9
azn2nr
Member#: 35276
i cant believe it either.
Old 08-18-2010, 02:08 PM   #10
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
I am going to insert the obligatory "you're going to blow it up".
car_cursed is offline   Reply With Quote
Old 08-18-2010, 04:37 PM   #11
azn2nr
Member#: 35276
i really wont. if anything it makes less power now.
Old 08-18-2010, 05:34 PM   #12
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
You'll find a way. You always do.
Took my car out for some spirited driving and ran into an issue. kite_tmr Brakes, Steering & Suspension 3 01-04-2010 07:15 PM
So tomorrow I drop my car off for a new transmission.....what will go wrong now? Keith Off-Topic 10 04-11-2008 07:48 PM
Precision Tuning-Just dropped my car off for service..... ScoobyNubieToo! Tri-State Area Forum 71 05-21-2006 03:15 PM
Driving to PA tonight to drop my car off for it's powerplant transplant blue-sun Mid West Subaru Owners Club Forum -- MWSOC 18 01-29-2005 11:25 AM
Dropped my car off for a windshield xtheviperx New England Impreza Club Forum -- NESIC 11 03-22-2003 12:28 AM
