Old 06-20-2002, 03:31 PM   #1
Rich L
Member#: 961
1999 RS-Tw/ CobraMAF
Custom Rallispec kit/IC#1
Cool My Frankinstien MAF... pics
Leave it to Ford to fix the MY99 maf problem.
(SVO Cobra MAF)
Rich L is offline   Reply With Quote
Old 06-20-2002, 03:36 PM   #2
Rich L
Member#: 961
Question more...
heres a close up.
Any comments?
Old 06-20-2002, 04:23 PM   #3
matts2.5rs
Member#: 7067
2004 GTO
Torrid Red
The Ford MAF works fine?
matts2.5rs is offline   Reply With Quote
Old 06-20-2002, 06:30 PM   #4
Rich L
Member#: 961
It works great with the ARC2 and stock ECU.
You wire the ARC2 up to the ECU (like a SAFC)... and the moster MAF bolts right on.
Old 06-20-2002, 08:36 PM   #5
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
it's only a wee bit larger than stock.
ColinL is offline   Reply With Quote
Old 06-20-2002, 08:59 PM   #6
Rich L
Member#: 961
Hey Colin....
You know what they say about guys with big MAFs Right?
...its hard for them to get blown !!!
Old 06-21-2002, 12:42 AM   #7
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
mine's about that size and has an engine to match behind it. your, uh equipment , looks a bit off with the tubing diameter differences!
amen on no more blown '99 MAFs. friggin achilles heel of that year...
Old 06-21-2002, 12:58 AM   #8
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Can you supply detailed instructions and parts list w/ general prices? I am interested in doing this mod.
Drac9 is offline   Reply With Quote
Old 06-21-2002, 02:04 AM   #9
XT6Wagon
Member#: 524
04 STi
Why did you go with the Cobra MAF? They are a mere 70mm, and the Ford 80mm is much much more common now as nearly all the mod motor cars use them. So a wrecked truck with a 4.6, 5.4 or the V10 will give up a 80mm for next to nothing. I think they are also made of a plastic in the latest ones so they run cooler, and are lighter.
Oh and if you are really looking for the most, Ford has a 90mm MAF on the 01-02 Lightnings. These are a common upgrade to the 99-00 version.
XT6Wagon is offline   Reply With Quote
Old 06-21-2002, 09:46 AM   #10
RageHardIntoTheBendies
Member#: 1532
1999 RS, Silverthorn
www.zucru.com
Cool I have a unit from an F150, as soon as I get the perfect power piggyback I will be running that.
RageHardIntoTheBendies is offline   Reply With Quote
Old 06-21-2002, 10:01 AM   #11
Rich L
Member#: 961
Colin: Phat Ride. Me like.
Drac9: goto www.splitsec.com for info.
XT6: The MAF came with the kit. It good for over 500hp (so they say... and is plenty big enough). Jeesh 90mm?
Rage: Rallispec might give some insight on the wireing. Maybe you can use a different Ford MAF to bolt up... if the connector is the same.
Its not the cheapest solution...
but then again...
niether is buying MAF after MAF.
Old 06-21-2002, 10:44 AM   #12
Member#: 1532
www.zucru.com
Rich Wireing isno problem I have actually allready run the car with the MAF and couple of pots for tuning but I need more adjustablility.
Old 06-21-2002, 11:30 AM   #13
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
must be compensating for something haha you really gotta match the tubing size to that monster...but kick ass.
jeremy
Old 06-21-2002, 12:24 PM   #14
XT6Wagon
Member#: 524
04 STi
Well, its NOT good to 500HP.
You can tell the difference between a 70mm and a 80mm MAF on a SHO with just a chip (80mm needs one to correct the MAF signal). The 80mm makes 1-2 more HP through the upper powerband. So if its making more power at the 220-230 crank level what will it be doing at nearly twice the power?
I'd see if they would just sell the translation box, then go fishing under the hood of a recent ford truck at the junkyard.
$100 should get one of the 80mm easy if not less, and hopefully you could get the sweet stock airbox with it (big plastic tube heat shield with cone filter stock).
Old 06-21-2002, 06:01 PM   #15
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
XT6, surely a 70mm MAF is sufficient flow for a forced induction 2.5L.
look at the intake tract after it! without changing that I can't imagine an even larger MAF making any sort of positive affect.
Old 06-21-2002, 09:18 PM   #16
Rich L
Member#: 961
Colin you read my mind.
What size mm is 3.5 inches anyway?
XT6: Regardless... are you saying a forced induced Cobra (approching 500hp) would have to upgrade the MAF?
I was simply making a reference to its durability.
Im just happy it works.
Now how the heck am I going to upgrade the IC piping?!?!
Its welded to the IC!
Old 06-21-2002, 11:46 PM   #17
XT6Wagon
Member#: 524
04 STi
How large is the inlet to the Turbo? The toyota CT26 used a 2.75" outer diamiter to attach the hose to.
But again, you could likely pick up a fair bit of power with the newer 80mm MAF, if for no other reason the composite body ones are more accurate.
And the 70mm MAF was a very short run item, ford quickly switched to the current 80mm as its "large" MAF. As far as I know the 93 Cobra was the only car with the 70mm MAF.
Old 06-22-2002, 02:30 AM   #18
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
3.5" = about 89mm.
Old 06-22-2002, 05:27 AM   #19
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
you are correct and these things are HARD to come by. Tried to get ahold of one for a buddy of mine for his sentra...was told by ford's parts center it was nearly impossible.
jeremy
Old 06-22-2002, 05:59 AM   #20
XT6Wagon
Member#: 524
04 STi
Ya, they are also VERY popular as they are a bolt on upgrad for the 89-95 SHO's. no chip needed
I have one somewhere.....
FS(PA): Perrin GT30R rotated kit, .82 hotside, UP, 44mm Tial WG, DP, Big MAF **PICS** phlegmon Engine/Power/Exhaust 12 04-17-2010 03:32 PM
FS(PA): Perrin GT30R rotated kit, .82 hotside, UP, 44mm Tial WG, DP, Big MAF **PICS** phlegmon MAIC Private Classifieds 0 04-09-2010 07:38 PM
Samco turbo inlet not mating to my oem MAF hose B16A2NR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-08-2006 12:47 PM
ecu that replaces my 98 MAF...for emanage ultimate price? IllNastyImpreza Engine Management & Tuning 0 06-19-2006 08:54 PM
where is my ecu+maf wire White 2.5rs Normally Aspirated Powertrain 4 09-08-2003 01:13 PM
