Old 08-18-2010, 07:28 AM   #1
micky.allan
Member#: 216537
2003 wrx
white
Default millage trip/ outside temp help needed
hi i have a 2002 bugeye.
my millage trip works but will not hold memory.
every time i turn the car off it resets back to zero. also maybe un related but the outside temp readout just says --- and the shift light resets its self also. (sti clocks) i have tried another clock set. and has the same problem.,
micky.allan is offline   Reply With Quote
Old 08-18-2010, 08:19 AM   #2
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
So you have an STI cluster in your WRX? That isn't clearly spelled out in your op.
skingfreak is offline   Reply With Quote
Old 08-18-2010, 09:49 AM   #3
micky.allan
Member#: 216537
2003 wrx
white
yes sorry. sti clocks in a 2002 wrx. but the problem is the same with both the wrx and the sti clocks. everything else works as it should.
Old 08-18-2010, 04:08 PM   #4
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
There is a fuse under the hood that ties continuous power to the areas that need it, like the memories. Make sure the fuses are ok under the hood. Use a test light to make sure power is getting to the fuses and to both sides of them.
Outside Temp reading incorrect...Help! Pak-Man Electrical & Lighting 11 11-19-2006 04:39 PM
Help! Outside Temp Sensor location on 04 STI Squiden Electrical & Lighting 4 11-09-2006 11:50 AM
water temp.oil temp.problem need help veightkiller Vancouver Impreza Club Forum -- VIC 8 01-21-2005 12:09 AM
