Old 08-18-2010, 06:53 PM   #1
zigzag801
Member#: 225784
2005 RS AW
Kawa Ninja
Default confused on starter/flywheel
After a long month of rebuilding my engine I finally got it in the car last night. Everything is hooked up, has coolant/oil and all that good stuff. But I have run into a problem that has confused me and my friend that is helping me out. I tried to crank the engine to start getting fluids in it but the starter just made a loud noise like a ghost was in my engine bay.
It sounds like the starter isn't syncing up with the flywheel...I just went to go see if the starter was in good condition at the local auto shop and they said it was just fine
so has anyone else had this problem and has a solution to this problem? I've been searching but can't find anything I just want my car up and running already! Thanks for the help!
zigzag801 is offline   Reply With Quote
Old 08-18-2010, 08:38 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
did you pull the plugs to prime the oil pump? If there's no compression, you won't hear much. Did you forget to install the timing belt?
yarrgh is online now   Reply With Quote
Old 08-18-2010, 08:49 PM   #3
zigzag801
Member#: 225784
2005 RS AW
Kawa Ninja
the plugs are pulled and yes the timing belt is installed. Everything is installed and put on just like it was before we pulled the engine out. The problem is, is that the engine isn't even starting. The starter motor is just spinning in place, so it's not cranking the motor
Old 08-19-2010, 10:29 AM   #4
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
can u install starter upside down?
the starter gear is facing up not hitting teeth of flywheel?
only 2 bolts on starter
would be easy fix
gl
AliBenn is offline   Reply With Quote
Old 08-19-2010, 07:21 PM   #5
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
smack the starter w/a hammer.
Old 08-20-2010, 08:29 PM   #6
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
LOL, I love that.
AFAIK, you can only install the starter one way, the right way, it doesn't fit the other way.
Is this starter the one that is correct for your application?
What starter are you using, what engine do you have, and what tranny are you using?
~Josh~
Old 03-18-2012, 07:15 PM   #7
mitchbugeyerex143
Member#: 283393
02 18g xt domtuned
did you ever get this problem fixed? i am having a similar issue, i just rebuilt my engine and i had the wires disconnected from the coil packs instead of pulling the plugs... does that make a difference? but mine scenario is a bit different, when i plugged in my battery to turn it over to prime everything and get oil thru the turbo oil line, anyways, i plugged in the battery and it sounded like the starter made a loud screeching sound as if i turned the ignition and it was already started. but my key was not in the ignition turned to the off position. everything else was plugged in correctly to my knowledge. anybody have this issue, HELP please. thanks in advance.
-Mitchell
mitchbugeyerex143 is offline   Reply With Quote
Old 03-19-2012, 03:19 PM   #8
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
sounds like your + cable is touching your energize wire on the starter or you solenoid is stuck.
Starter/flywheel going? Vincentmoy Service & Maintenance 7 06-10-2009 03:13 PM
2005 STi Tranny, rear diff, dccd, yaw, starter, flywheel. moorebl Drivetrain 5 06-28-2008 10:30 PM
Confused on remote starters w/ factory alarm o2sys Car Audio, Video & Security 1 12-18-2005 01:58 PM
Confused on offsets - again Division By Zero Brakes, Steering & Suspension 8 09-27-2001 06:51 PM
confused on offsets James Kannookadan Brakes, Steering & Suspension 4 06-15-2001 02:13 PM
