Vancouver Impreza Club
Old 08-18-2010, 07:19 PM   #1
J_ride008
Member#: 216669
2002 Impreza WRX
Default Need help with turbo?
I have an 02 wrx. The turbo is leaking oil on the exhaust side, through a shaft on the top that goes to a solenoid type thing. What are my options? Is it repairable or rebuildable? Am I able to fix it myself? [IMG][/IMG]
J_ride008 is offline   Reply With Quote
Old 08-18-2010, 11:18 PM   #2
Horkus
Member#: 112667
2002 WRX wagon
I don't even think there is suppose to be oil there. was it oil that you dripped on from pulling the tranny oil stick?
Horkus is offline   Reply With Quote
Old 08-18-2010, 11:35 PM   #3
J_ride008
Member#: 216669
2002 Impreza WRX
I took the heat shield off to see where it was coming from. Its slowly seeping out from where the shaft is coming out of the turbo.
Old 08-18-2010, 11:48 PM   #4
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Is your exhaust blue?
The only way oil could be coming out of there is if its leaking inside the turbo. Otherwise that oil is coming from somewhere else and collecting there some how.
Splinter is offline   Reply With Quote
Old 08-18-2010, 11:57 PM   #5
J_ride008
Member#: 216669
2002 Impreza WRX
I haven't noticed the exhaust being blue. I only noticed it because it was dripping on to my axel and kicking up on to my down pipe, there for causing it to smoke out my hood scoop.
Old 08-19-2010, 12:04 AM   #6
J_ride008
Member#: 216669
2002 Impreza WRX
I'm guessing then I'll have to rebuild it then.
Has anyone rebuilt there turbo? Is it worth rebuilding? Cost? or is it better to find one in good working order?
Old 08-19-2010, 12:23 AM   #7
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
I'm not sure if the TD04 on your car is rebuildable at home or not, but I do know that you can get them redonkulously cheap on the forums. Post up a WTB in the classifieds and see if anyone has one for like $100
Alternatively, this could be a great excuse for an upgrade!
Old 08-19-2010, 12:26 AM   #8
Linkseal
Member#: 102329
05 AW Piggy Gone
11 SP TOM'S IS-F
agaree, go for upgrade or replacement, not worth to repair if turbo is oil leak like this
Linkseal is offline   Reply With Quote
Old 08-19-2010, 02:28 AM   #9
Jeff54
Member#: 129503
2002 It's resting
6 > 4?
ummm thats the most random place for a turbo to be leaking...evar.....
eitherway, if u do need to replace it, dont rebuild, you can pick up a used td04 for <100$....
or pick up an evo III 16G....awesome replacement turbo for the ej205
or gt4088
Jeff54 is offline   Reply With Quote
Old 08-19-2010, 07:37 AM   #10
Horkus
Member#: 112667
2002 WRX wagon
Try pick one up from Rocket rally as I am sure they have a bunch to spare out.
Need help with Turbo Upgrade brianc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 11-10-2004 06:54 PM
Need help with turbo boost gauge! JDMSubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 12-10-2003 03:29 PM
need help with turbo upgrade EJ2002 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-16-2003 08:41 PM
Help! I need help with turbo 99 HOK Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 04-16-2001 08:05 AM
Need Help With Turbo Kit???? Xscreamer Normally Aspirated Powertrain 7 03-15-2001 10:55 PM
