#1 |
Member#: 252335
Vehicle:2009 Impreza Black |
I have an 09 impreza 2.5i, no turbo
. I want to know what it would take if i would try to put on a turbo kit and if the transmission and rest of the driveline could take the power, or different pistons would need to be installed. What all would have to be done to the car if i would decide to turbo my subie
#2 |
Member#: 254987
Vehicle:2007 Impreza 2.5i Obsidian Pearl Black |
From what I've heard, your money is better spent on other upgrades. You can always do a cold air intake under the hood, but that 6k or so that you would be putting into the turbo would be MUCH better spent towards suspension, wheels, and exhaust.
#3 |
Member#: 1748
NESIC
Vehicle:'09 Outback Sport OBP over DGM |
You'll get more information in the "Naturally Aspirated with bolt on Forced Induction" forum, or wahtever it's called. That's for the bolt-on turbos and superchargers.
That said, get used to this response to this question: Q: "What's the best way to turbo an N/A Subaru?" A: "Trade it in and buy a WRX." It's not so much the tranmission and driveline that you should worry about. While the WRX 5-speed, I believe, gets different gearing, most of it is the same between the cars. What you need to worry about is the engine. The N/A 2.5 liter engine is not just the turbo'ed 2.5L without the turbo. They are significanly different animals. The open-deck design of the NA engine limits it's ability to be turbo'ed vs. the closed-deck design of the turbo'ed engine. You can run some low boost (6-7psi) on the NA 2.5L, but people have even had problems at that level, and blown their engines. To run higher boost, you will need significant modifications to the engine internals and once you get to that level and the amount of money you will have spent, you are better off just buying a WRX to begin with. For the money you would spend on turboing the NA car, if you traded up to the WRX you would get the turboed engine, AND you would also get the sportier seats, bodykit, spoiler, upgraded suspension, hoodscoop, etc. that come with a WRX above and beyond the turbo. I know that this is probably not what you want to hear (and you won't be the first, or last, to be disappointed to find out what it really takes to turbo the NA engine), but to truly turn an NA Subaru into a WRX is a very, very expensive proposition. If you want a hobby and have some cash to burn, it could be fun. If you just want a turbo, WRX is the better way to go. This is why most NA Suabru owner focus on suspension mods and things beyond the engine. There just isn't a lot of bang for you buck there. |
#4 | |
Member#: 102984
Vehicle:2005 2.5RS 4EAT Platinum Silver |
Also -----------------------------> Bolt on Turbo Forum, that way. |
#5 |
Member#: 161832
Vehicle:2000 Outback Limited Black |
WRX engines are semi-closed, not fully closed and r good to 18psi. closed decks are good to or over 30psi with the proper mods.
for my turbo project, i am getting a 2.5L STI block and internals to run 18psi. i plan to do heads and cams and maybe go over 20psi at some point. driveline can handle power, but u should think about upgrading when u near 400HP or more. |
| Thread Tools | |
| Display Modes | |
| WRX turbo set up on 2002 impreza | fasta$$wagon | Normally Aspirated with bolt-on Forced Induction Powertrain | 8 | 02-11-2009 01:41 AM |
| couple Q's on a turbo set-up DOM 3 | 04 Slo Sti | Factory 2.5L Turbo Powertrain | 29 | 06-15-2008 12:04 AM |
| 2002wrx turbo set up on 2001 2.5 rs | witte1919 | Normally Aspirated with bolt-on Forced Induction Powertrain | 9 | 03-13-2008 06:06 AM |
| need stock 04 and up wrx turbo set up | impr3vize | Private 'Wanted' Classifieds | 0 | 07-14-2005 02:58 PM |
| Question on rear sway bar set up | IronMosher | Brakes, Steering & Suspension | 2 | 01-12-2004 05:08 PM |
