Welcome to the North American Subaru Impreza Owners Club Monday June 17, 2013
Old 11-11-2010, 05:51 PM   #26
2milehi
Member#: 81633
'98 RS-T
Originally Posted by cjake39 View Post
This was my solution on Monday...
I was able to get two bolts out with a breaker bar and the right 10mm hex socket. The other two stripped the head out so we welded the hex socket to the bolt head that worked for one. The other one blew out the back of the socket, so a 3/4 wrench fit nicely over it....
We did have to use about a 4-5ft breaker bar. Some tools must be sacrificed for this job apparently. Heat from the welds did the most good to free it up.
I have had success welding a nut over the damaged bolt, but I have not tried that on this particular application.
2milehi is offline   Reply With Quote
Old 11-12-2010, 12:33 PM   #27
cjake39
Member#: 161269
2007 STI Limited 247
Urban Gray
Yah, I was going to use an autozone wrench then thought it might break that one in a million pieces... Tools are an ongoing investment :shrug:
cjake39 is offline   Reply With Quote
Old 11-12-2010, 04:08 PM   #28
2milehi
Member#: 81633
'98 RS-T
Yeah that would be the ol' proverb - from the frying pan into the fire
Old 11-12-2010, 05:45 PM   #29
nosmo
Member#: 53142
06' STI,02WRX,982.5
www.Flat4lv.com
Best way I have found.... Worked many times. Use a grinder. Grind the head to somehwat of a hex head, this does not have to be exact at all. Then use this tool. Has worked every time.
nosmo is offline   Reply With Quote
Old 11-15-2010, 02:32 AM   #30
WRX_FTW
Member#: 240792
04 AW STi Stage ?
04 AW FXT Stage 3
i used a cobalt drill bit, worked like a charm................ for the first bolt. the part about the sharpening is no joke, too dull to get very far in the second bolt. im going tomorrow to get it sharpened since i dont have a bench grinder, and probably buy a backup bit just in case.
WRX_FTW is offline   Reply With Quote
cam sprocket removal investigation Gator GT Factory 2.0L Turbo Powertrain 1 03-12-2006 11:29 PM
cam sprocket removal White 2.5rs Normally Aspirated with bolt-on Forced Induction Powertrain 6 01-03-2005 02:58 AM
Removing cam sprocket ilmaestro Normally Aspirated Powertrain 5 02-22-2004 07:35 PM
Cam sprockets hard to remove? dwx Factory 2.0L Turbo Powertrain 8 10-15-2003 01:41 PM
cam sprocket removal help 9 Service & Maintenance 2 02-21-2002 12:01 AM
Message Board Statistics All times are GMT -4. The time now is 11:42 PM.
