Old 08-19-2010, 10:39 AM   #1
andrew3776
Member#: 172133
2003 vfdirty wrx
rotten banana
Default WRX starter issues after clutch install
Hey guys. Just got most of my car back together and i'm having issues with my starter. I installed the power and the ground on the clips but she wont turn over. Am i forgetting something?
andrew3776 is offline   Reply With Quote
Old 08-19-2010, 10:52 AM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Make sure all the fuses in the main panel under the hood are ok and if you haven't checked the safety switch to make sure it is passing power to the starter solenoid then check that.
Old 08-19-2010, 11:44 AM   #3
andrew3776
Member#: 172133
2003 vfdirty wrx
rotten banana
did that, then saw this little plug hanging next to my tranny. It plugged into the back of the starter behind the power wire. Nice hiding place for it. Cars up and running now after a 3 day fight.
Old 12-05-2010, 09:44 AM   #4
bigvicswrx
Member#: 260692
I had a trans shop rebuild my trans and now it doesn't start in the cold I'm stumped 141000 miles oe starter
bigvicswrx is offline   Reply With Quote
Old 12-05-2010, 10:56 AM   #5
Cougar4
Member#: 53443
Winestone
If all you hear is a fairly loud click when you go the START mode then the starter solenoid contacts may need to be replaced. It would also be a good idea to clean the battery connections.
2010 WRX crazy noise after clutch install Odin2347 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-27-2010 01:42 AM
Starter problem after clutch install naSTi wagon Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-22-2009 10:22 AM
Need help with starter after clutch install. (Pics Provided) MAJRMSA Electrical & Lighting 0 10-16-2008 10:07 PM
issues after clutch install? 06WRXTRacer Transmission (AT/MT) & Driveline 7 08-04-2008 02:44 PM
CLutch issue after clutch install jawwadh Mid West Subaru Owners Club Forum -- MWSOC 16 06-05-2006 01:07 PM
