#1 |
surf ninja
Moderator Member#: 157784
VIC
Vehicle:02 swapped bugeye 2.5L wagon / 05 wagon |
Out of the blue yesterday my desktop computer started to have some issues. It wont start up windows. When you turn it on, it loads up to the windows logo then restarts, and keeps doing that. Cannot start in safe mode, it restarts when loading also. My roomate updated something to do with java before the problems started, but I dont know if that could cause this.
I have the Vista disc, and when I put it in it loads from the cd and asks me if I want to do a restore. I have restored it and when Im using the internet I cannot download any torrents it gives me an error "couldnt load main class"... (I use Azureus for my dl's) I thnk maybe my copy is corrupt or something, so I try to download a new version of the program to install, when I try to open the file it gives me the same error. I do a virus scan (spybot & avg) and run through the system not finding really any issues. I restart when its done and the process starts all over again. Constantly restarting unless I boot from cd, run the restore and can load windows again.... frusterating. I have run the restore 4 times now and its not fixing the problem. Anyone able to lend any advice? edit- something else I just found, was if I search in google when I click the link it takes me to some debt couselors, or discount furniture, etc... something is inside my compter stealin my interwebz ![]()
#2 |
Member#: 4326
Vehicle:2010 turdle |
i just want you to know.
i clicked this thread. in hopes of being your saviour but alas all i can tell you is.. too much porn. |
#3 |
Member#: 250287
VIC
Vehicle:2010 WRX White |
Does your computer do anything before it reboots? Like, do you see an error message or blue screen? Or does it just look like it dies or flickers suddenly then quickly reboots again?
#4 |
Member#: 235744
VIC
Vehicle:07 2.5i Sedan Ltd Newport Blue |
download, install and run this:
Malwarebytes once done scanning, if it finds any infections/threats remove them. im pretty sure its a trojan or something in your computer. - JC |
#5 |
Member#: 241552
TXIC
Vehicle:2008 PB EVO X MR SSS Phantom Black Pearl |
you can also try and run a harddrive sector test....
#6 |
Member#: 223335
VIC
I had this issue before, the fix for me was to download Malwarebytes' Anti-Malware, and then run a scan. Then delete a process that was just random numbers or something. ie. 2947819421.exe. Do that stuff in safe mode, then you have to find the file location of that .exe and delete that manually after deleting through Malwarebytes. Then boot up normally, and it SHOULD be fixed.
#7 |
Member#: 52631
Vehicle:2004 WRX WRB |
That has happened a couple times on our XP machines here at work. The trick that seems to work most of the time is fixing the MBR and boot sector. The process may be slightly different in Vista but you will want to access recovery console, get to the command prompt and use the fixmbr and fixboot commands.
#8 | ||||
surf ninja
VIC
How do you do this? Quote:
#9 | |
Member#: 143277
VIC
Vehicle:05 STI PPP OBP 1098, Z1000 |
But considering where you are right now, why not save what you can then do a fresh install ? |
#10 |
Member#: 102329
VIC
Vehicle:05 AW Piggy Gone 11 SP TOM'S IS-F |
1) If you can be on safemode w/ Network I can RDA to fix it
2) If you have 2nd computer at home and your computer can open USB files then it can be fixed 3) If too much work for you, try system restore to last week or fresh install after backing up your files. |
#11 |
surf ninja
VIC
Can I do a fresh install and not lose my personal data? (downloads, pics, movies, etc...)?
like install without format? or is it pointless and I should just burn what I can and reformat? I can boot with cd and run in windows, surf the net, etc.... so I think I can boot to safemode with network connection.. |
#12 |
Member#: 102329
VIC
^PM sent
#13 |
Member#: 178560
VIC
Vehicle:2000 GC8 |
Your hard drive (OS) is corrupted. If you have a legit windows, the one you buy from the store, not the restore version that comes free with the computer. You can reinstall windows over top of your previous installation without formatting or losing your files. Your program files would require installation, but this is a quick fix.
However, it is better and more time effective to copy all your important files to another partition or another external drive. Format, clean install and start again. When you format, set your C drive partition for 80 GB for your windows and program files. Then your other partition for data. Make sure you have all the drivers you need before you install, such as sound, video, wireless and etc. Good luck and happy camping. |
#14 |
Member#: 129503
VIC
Vehicle:2002 It's resting 6 > 4? |
upgrade to windows 7...woot
#15 |
surf ninja
VIC
probably should format if I upgrade to windows 7 eh...?
#16 |
Member#: 185128
VIC
Vehicle:2005 Stage 2 STI Aspen White |
Don't load VISTA! It is one crappy OS. Go for Windows 7 if you do upgrade.
#17 |
surf ninja
VIC
I have vista, I would be going up to windows 7.
Come on now Jim, u know I have vista ![]() |
#18 |
Member#: 235744
VIC
+123133211 for upgrading to Windows 7!
you can do a direct upgrade if you are going from: Windows Vista Home Premium to Windows 7 Home Premium Windows Vista Business to Windows 7 Professional Windows Vista Ultimate to Windows 7 Ultimate If not, then you'd have to do a fresh install.. good luck! -JC |
#19 |
Member#: 178560
VIC
Vehicle:2000 GC8 |
Roll back to Windows XP SP3 =)
#20 |
Member#: 112667
VIC
Vehicle:2002 WRX wagon WRB |
Format c:\
#21 |
surf ninja
VIC
Im not that dumb
I just want the least ammount of work to get it back up and running good. |
#22 |
Member#: 102329
VIC
I am using Vista...so do I need to format c: /all ?
#23 | |
Member#: 143277
VIC
The problem with trying to repair or rebuild a windows installation is that it will take you 6 hrs of hunting for the solution unless you have friends in IT or know what to look for. Also the benefit is you get to start fresh with a non-bloated registry etc. etc. A very long time ago when I did A+ they always suggested re installation vs. troubleshooting lol |
#24 |
Member#: 102329
VIC
For normal virus removal and system clean up it takes 2~3 hours.
For system foirmat reinstallation it takes less than 2 hours. Plus, for files/docs/pics backup from old system and reinstall programs/drivers on fresh system take 2+ hours. So user needs to make own judgement at this point. But the rule is, Not everything can be fixed (Virus/system corruption), but eventually it will be fixed. (New system) |
#25 | |
Member#: 143277
VIC
When I did IT, my favorite repair was doing MBR problems, it's like 30 seconds to solve but it would take someone who knew nothing at least a day to learn lol. If I had to backup I just load up my 16gb flash drive. Back then that was a LOT of space haha. |
| Thread Tools | |
| Display Modes | |
| IM having boost trouble on my 04 wrx 2.0 any help??? | courtbud04wrx | Factory 2.0L Turbo Powertrain | 11 | 09-03-2008 02:52 PM |
| IM having boost trouble on my 04 wrx 2.0 any help??? | courtbud04wrx | Newbies & FAQs | 7 | 09-02-2008 01:30 PM |
| Calling OT computer builders... having some trouble | sportz135 | Off-Topic | 15 | 09-18-2005 08:12 PM |
| Having computer trouble... | Tkacik | Off-Topic | 12 | 07-18-2005 06:19 PM |
| Help!! I'm Having Computer Troubles!! | Rallycarperson | Off-Topic | 9 | 10-02-2004 09:47 PM |
