Old 10-23-2011, 04:43 AM   #301
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
how do you change thread's name on here?
Bariga is offline   Reply With Quote
Old 10-23-2011, 05:48 AM   #302
Member#: 264595
Originally Posted by Maxwell Power
Tomorrow monday? Now that it is just after midnight. Making today officially sunday.
Laying in bed using a smart phone perhaps? LOL
Well just to clarify, tomorrow as in today.. Not tomorrow as in tomorrow.? Duh. Haha. Sunday!
raffi@full-race is offline   Reply With Quote
Old 10-23-2011, 10:20 AM   #303
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
edit the 1st post and the click edit advance
Old 10-23-2011, 01:19 PM   #304
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
^ i did it still not changing,
Old 10-23-2011, 02:09 PM   #305
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
Hit Apply?
EtoS is offline   Reply With Quote
Old 10-23-2011, 05:33 PM   #306
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
EFR Looks good Bariga - subscribed.
When are you expecting this to hit the dyno for a base run?
Layvon
Layvon is online now   Reply With Quote
Old 10-23-2011, 06:46 PM   #307
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Still need to sort out leaking P&L Fuel Rail, and WG bracket.
And need to buy an intake "Homes!
Pics from today
Old 10-24-2011, 11:40 AM   #308
Maxwell Power
Member#: 190729
Pics from today
Where is it leaking from? I have -6 seals that work awesome.
Maxwell Power is offline   Reply With Quote
Old 10-24-2011, 12:33 PM   #309
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Pics from today
You don't need no stinking intake. Have Dom make you one.
Old 10-24-2011, 01:22 PM   #310
Member#: 264595
What diameter intake pipe are you thinking of using? I think we just got the 3 inch to 3.5 inch couplers in. Let me know if you need one.
Old 10-24-2011, 06:15 PM   #311
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
Looking forward to results. Also hoping this means one might be headed my way soon....
thefoos is offline   Reply With Quote
Old 10-25-2011, 01:45 AM   #312
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
The Fuel rail leaks from NTP fitting, Fuel pressure regulator leaks from rubber seal, and i need to get Revised WG bracket from Full-Race, and the intake id like to keep 3.5 inch
Dom i wont make it to break in session this week
Old 10-26-2011, 02:18 AM   #313
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Got WG Sorted out! It was a PITA but fits good!
WG has 20 psi spring, should be plenty!
Here are more detail pics of fitment, if i went larger turbo that would be impossible to fit
My hands look like i was in a fight club...
Possibly will get it started as soon as some more parts come in this week.
Old 10-26-2011, 02:31 AM   #314
Member#: 264595
Like...
Old 10-26-2011, 02:35 AM   #315
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Im going to run both coolant lines from top, should be ok as all the air will come out from top anyways.
Old 10-26-2011, 02:44 AM   #316
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Is it too tight of a fit to have the flow go across the center section? I need to know what to expect.
Old 10-26-2011, 02:55 AM   #317
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
It should even work if both were connected from one side, better than nothing right?
Old 10-26-2011, 10:25 AM   #318
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
sure, better than nothing, but BW recommends cross flow. I doubt it is the end of the world if you don't though....
Old 10-26-2011, 12:25 PM   #319
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Cross flow is sureley better as you get flow across the entire bearing section instead of the majority of flow going directly from the inlet and out the outlet on the same side. I think that if you wanted uniform bearing cooling you would want the flow path to go around the bearings to cool from both sides.
Old 10-26-2011, 12:41 PM   #320
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
It sucks that thing is like 20' long.
CKxx is offline   Reply With Quote
Old 10-26-2011, 01:20 PM   #321
Member#: 264595
Insert dirty joke here..
As for the coolant lines, it's not advisable to have them enter and exit on the same end. I'm sure it's better than nothing but you should be able to get the plumbing installed correctly now that the bracket is in place.
Old 10-26-2011, 01:45 PM   #322
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
It's already cluster ****ed there, if I have coolant lines going around the turbo that would be total mess, tops should be fine as coolant will also travel around the bottom and exit on top.
Old 10-26-2011, 01:48 PM   #323
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Like i said this turbo is 1000 times better to work on than Garret as all the bolts are easy accessible from all sides.
When i had 35R with twinscroll housing it was a nightmare
Old 10-26-2011, 03:06 PM   #324
faeflora
Member#: 169935
04 FXT, TurboMiata
Black, Green
20psi? *****. evo owners will laugh at you!
faeflora is offline   Reply With Quote
Old 10-26-2011, 03:49 PM   #325
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
What are you referring to
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 608 Yesterday 06:54 PM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 03:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 02:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 10:28 AM
