Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 10-31-2011, 11:54 PM   #351
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
No.... He's aq Motorsports or the owner of their car, i think
http://forums.nasioc.com/forums/show....php?t=2163174
Old 11-01-2011, 02:40 PM   #352
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
It's JC, he's the owner and driver of the AQMS TA car and the Rodney Dangerfield of Time Attack...and I'll tell ya he's one funny SOB Sorry for bustin ya JC!
Old 11-04-2011, 10:31 PM   #353
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Started the car today so far no oil / coolant leaks,
It does have exhaust leak at T4 flange and at uppipe to header weird because i used grimmspeed fat gasket at uppipe and vbrand multilayer one on T4. Car still on jacks and tomorrow I’ll do some more checks before i drive it.....
Bariga is online now   Reply With Quote
Old 11-05-2011, 12:22 AM   #354
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
That is weird.. thought vband was very good about not leaking?!
Good luck man. Eager to hear your thoughts
Layvon is online now   Reply With Quote
Old 11-05-2011, 01:30 AM   #355
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
I believe Cometic makes a copper vband gasket also.
methaddict is offline   Reply With Quote
Old 11-05-2011, 02:03 AM   #356
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Sorry i was saying T4 Flange gasket not Vband connection, this is the gasket that i used
Old 11-05-2011, 02:11 AM   #357
methaddict
Member#: 159738
2004 WRB STi
Check how flat the mating surfaces are with straight edge.
Old 11-05-2011, 02:14 AM   #358
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
Why not use the one that came with your exhaust? I doubt FR would of sent you a crap gasket just for ****s n giggles.
EtoS is offline   Reply With Quote
Old 11-05-2011, 02:40 AM   #359
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
i dont trust single layer piece of metal lol, ill try to torq it down some more see if that help. As far as flanges being not streight i asked full-race to tripple check everything before shipping out so i wont call them not flat as of yet.
Old 11-05-2011, 02:44 AM   #360
big18g
Member#: 165872
2005 wrx
black
Unless its torqued down like less than 10ft/lb, I highly doubt simply tightening the connection will fix your issue. Sorry.
big18g is offline   Reply With Quote
Old 11-05-2011, 02:44 AM   #361
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
Umm if that is your reasoning no wonder you got leaks coming from everywhere. Why not entertain yourself for 10 mins and swap gaskets. Worse thing that'll happen is it'll work
Old 11-05-2011, 03:09 AM   #362
Phatron
Member#: 36033
CEO PhatBottiTuning
Usually Once a gasket is compromised you're not gonna magically make it seal.
Old 11-05-2011, 03:39 AM   #363
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
i bought a brand new up pipe from perrin many moons ago. flange was not flat, didnt seal. planed it...sealed.
maxpowr is offline   Reply With Quote
Old 11-05-2011, 02:02 PM   #364
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
just broke in the cams for 20 min at 2000 rpm, going to drive around for a bit and change the oil. Need to get coolant plugs on turbo little more tight, AFR is good even though i got different turbo and different compression engine - AEM rock!
Old 11-05-2011, 02:15 PM   #365
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
getting there!
Old 11-05-2011, 05:27 PM   #366
mxpop
Member#: 103776
2006 STI
Originally Posted by Crystal_Imprezav View Post
Didn't you guys crack the sleeve ("closed-deck"...), bend the rods, and destroy their last motor?
Yep
Cracked the sleeve from mid stroke up (closed decking only supports the top 1/4 inch of stock sleeve). Then crew member cranked motor after it was filled with water from crack. This caused crank to snap and bend rods.
This was not OFMS' fault nor was it bad BC parts. It was an OEM part that was overstressed by us in search of more track records (which we achieved BTW...). The rod/crank death was a result of cracked sleeve and then our crew member cranking motor when he shouldn't have. Oh well...
FWIW, any brand rod/crank would have failed in same manner if subjected to same mistake.
BTW CI, do you know the "popcorn trick"?
mxpop is offline   Reply With Quote
Old 11-05-2011, 05:28 PM   #367
mxpop
Member#: 103776
2006 STI
Originally Posted by Junior2JZ View Post
Are you OutFront Motorsports?
Nope, just a racer/customer that pays for their work. They give me racer discount.
Old 11-05-2011, 05:34 PM   #368
mxpop
Member#: 103776
2006 STI
Thx for the link, hadn't actually seen that
I am a customer of AQ Motorsports and the owner of this car. They have always treated me right and do most of their work on the car for free. I do most of the work on car myself and bring it to AQ for things I can't handle at my home workshop. Wish I had a lift...
Old 11-05-2011, 05:50 PM   #369
Joshwrx04
Member#: 135429
'05 Cornfed CGM STi
94 Legacy SS
jawls^^
Joshwrx04 is offline   Reply With Quote
Old 11-05-2011, 06:21 PM   #370
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
First they ship it ground instead of overnight, and this
P&L FPR steal leaks after changing the rubber seal WTF
Before when i took it apart everything was rusted inside, spring / spring holders i had to clean everything up. When i replaced the rubber seal i made sure everything was clean and surface was flat, i try to tighten it more and more nothing is helping, took it apart twise to make sure it was compressed correctly.
I demand overnight replacment
Old 11-06-2011, 02:36 AM   #371
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Use something else from another manufacturer.
alcoolaid is offline   Reply With Quote
Old 11-06-2011, 10:31 AM   #372
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
I have the Aeromotive one. it seems to work well on every application i've seen it on! They have been in the game for a longtime!
I got it from Summit
waynoSTI is offline   Reply With Quote
Old 11-06-2011, 12:17 PM   #373
02WRX2.5
Member#: 63192
02 wrx
161mph Trapspeeds
Yup aeromotive. Stick to what's proven especially when it comes to fuel delivery. Goodluck and nice setup!
02WRX2.5 is offline   Reply With Quote
Old 11-06-2011, 01:11 PM   #374
3MI Racing
Member#: 200987
I've used Aeromotive, Mallory and now a Turbosmart with no issues...Have you contacted P&L directly to let them know of the issue? I ask as I'm almost certain they don't manufacture those in-house.
-Micah
3MI Racing is offline   Reply With Quote
Old 11-06-2011, 01:17 PM   #375
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
if I get a different unit I choose fuelab I've seen pics of aeromotive opened looks not too far to p&l quality wise
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 563 05-16-2012 08:28 PM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 03:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 02:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 10:28 AM
