Welcome to the North American Subaru Impreza Owners Club Tuesday June 2, 2015
Old 11-22-2011, 03:34 PM   #501
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Took the gasket apart to see how its made
And Finally got myself some AN wrenches about time
Bariga is offline   Reply With Quote
Old 11-22-2011, 04:38 PM   #502
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Looks like you've had issues with multi-layered gaskets too. I guess your only option is no gasket.
Old 11-22-2011, 04:58 PM   #503
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
or go baller and o-ring
Old 11-22-2011, 05:05 PM   #504
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
I wish i had CNC Stianless flanges with O-rings! Maybe for 5 grand kit full-race should rethink the design?
Old 11-22-2011, 05:08 PM   #505
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
I'll use single layer gasket and copper sealant, what's the correct way of installing with that sealant? Do I have to let it dry I torque the bolts?
Old 11-22-2011, 05:11 PM   #506
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
waiting til it dries to tq the bolts sounds like a bad idea to me. Im sure if you just used the supplied gasket and tq it correctly there would be no issue.
Old 11-22-2011, 05:14 PM   #507
n2oiroc
Member#: 141952
03 11 wrx/13 brz
thin bead around the ports, both sides of the gasket. slap it together, torque it to final value and let it dry overnight before you start it.
n2oiroc is offline   Reply With Quote
Old 11-22-2011, 05:42 PM   #508
Homemade WRX
Member#: 33782
96 bastard child
Yes! Letting it dry is a bad idea. It won't let you compress the liquid layer as much. That leaves more of the weak RTV layer to fail and leak.
Old 11-22-2011, 05:56 PM   #509
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
+1
+1
Torque down while wet, DO NOT START CAR. I was always told 24 hours for it to dry, less if it's hot outside. I personally would wait 24hours cause it's pre turbo where there will be higher exhaust pressure then post turbo. Just my paranoid .02.
EtoS is offline   Reply With Quote
Old 11-22-2011, 06:28 PM   #510
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
thanks for the tip! I hope I'll be able to remove the broken stud out from the uppipe! It broke in 2 days after i torq that bolt more to see if it fixes the leak
Old 11-22-2011, 07:33 PM   #511
MartinSTi05
Member#: 145145
2006 wrx STi
Marinade it in PB Blaster and come from the top with a drill smaller than the minor dia of the threads. Usually it will spin right out.
MartinSTi05 is offline   Reply With Quote
Old 11-22-2011, 07:42 PM   #512
3MI Racing
Member#: 200987
50:50 acetone/ATF works if/when PB blaster fails you
3MI Racing is offline   Reply With Quote
Old 11-22-2011, 09:05 PM   #513
Maxwell Power
Member#: 190729
just be sure you don't put so much in there that it squeezes out into the exhaust.
Maxwell Power is offline   Reply With Quote
Old 11-23-2011, 01:03 PM   #514
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Removed the broken stud last night, it broke mostly due to the hex hole cut out on the bottom of it! Had to drill the bitch out! Checked all the flanges they all flat, no idea why the grimspeed 2x gasket leaked at the bottom of the uppipe!
Old 11-23-2011, 01:04 PM   #515
Maxwell Power
Member#: 190729
because it's a 2x gasket.
I'm not sure why people don't understand that a 1 ply gasket has two places to leak and that a multi-ply gasket has many times more chances of leaking.
NEVER use more gasket than you need. If the flanges are perfectly flat, don't use a gasket. I have multiple turbo kits where the turbo sits right on the flange and doesn't leak.
Old 11-23-2011, 01:06 PM   #516
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
I have 2 more of them installed at the block side should i swap them with oem?
Old 11-23-2011, 01:08 PM   #517
Maxwell Power
Member#: 190729
the fewer the layers the better.
Old 11-24-2011, 06:49 PM   #518
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Will install the uppipe with hotside bolted on, used single layer gasket with ultra copper sealant
Old 11-24-2011, 08:30 PM   #519
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
^ thats so sick. but yeah always surprises me every time i install my ultimate racing turbo kit and using a thin layer of right stuff gasket junk and no real gasket it always seals perfect!
stretchedk7 is offline   Reply With Quote
Old 11-24-2011, 08:39 PM   #520
MartinSTi05
Member#: 145145
2006 wrx STi
A word of caution: I read the you had a broken stud. If you are using a stud that is broached for a hex key on one end make sure that you thread the nut past the broached portion of the stud. Otherwise you are pulling on a fastner with a drastically reduced cross section/ultimate strength.
Old 11-24-2011, 10:24 PM   #521
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
I got metric studs, the studs with hex are very weak
Martin this is exactly how my failed
Old 11-25-2011, 09:45 AM   #522
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
thats good info ^.
Old 11-25-2011, 10:35 AM   #523
MartinSTi05
Member#: 145145
2006 wrx STi
I ran "set screws". Or hex broached studs. In cases where there was clearance I was able to simply leave enough exposed stud that I could thread the nut down past the broached hex portion. Otherwise I had to thread the stud in upside down (broached end into up pipe flange, and have about 1/4" protruding out the bottom of the flange to ensure I was pulling on the full cross section.
Old 11-27-2011, 09:48 PM   #524
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Grinded the Comp housing to gain more clearance at the wheel wall
Mounted the assembly
This Vband gasket is to thick and not going to work
Coolant leak check
Guess whos behind the wheel?
Old 11-28-2011, 08:44 AM   #525
MartinSTi05
Member#: 145145
2006 wrx STi
A thin coat of ultra copper on the V-band flage should cure what ails you on your down pipe; the stuff is like the "tussin" of the automotive world.
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 563 05-16-2012 08:28 PM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 03:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 02:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 10:28 AM
