Old 11-28-2011, 11:21 AM   #526
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
^ thats what i end up doing
Got it running today, looks like no leaks so far! Also did 2 turns on a WG preload bolt
Ill have to RMA the AEM box, its not reading any voltage on EGT inputs 2,3,4!
Bariga is offline   Reply With Quote
Old 11-29-2011, 05:19 PM   #527
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Does any one make block off plate for Tial BOV flange?
Old 11-29-2011, 05:28 PM   #528
monkiboy
Member#: 202958
2008 wrx
why not remove it and run a plate and gasket from matt (kstech) on the pipe?
monkiboy is offline   Reply With Quote
Old 11-29-2011, 05:29 PM   #529
n2oiroc
Member#: 141952
03 11 wrx/13 brz
try full-race and grimmspeed.
n2oiroc is offline   Reply With Quote
Old 11-29-2011, 05:48 PM   #530
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
more info please
Old 11-29-2011, 05:56 PM   #531
monkiboy
Member#: 202958
2008 wrx
Old 11-29-2011, 06:21 PM   #532
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
This may seem obvious and maybe you have but did you check with Tial?
Old 11-29-2011, 06:22 PM   #533
manitou
Member#: 193757
2006 XTI Limited
If no one has a bov delete plate then I would just make one.
Old 11-29-2011, 06:33 PM   #534
unclemat
Member#: 114530
2005 LGT 6MT wagon
I posted this in Grimmspeed thread. Somebody should start making BPV/BOV block off plates.... stock STI, stock LGT/WRX, Tial, etc.
unclemat is offline   Reply With Quote
Old 11-29-2011, 06:40 PM   #535
monkiboy
Member#: 202958
2008 wrx
when my plans were to go blow-through, i got all my plates and block-offs from matt. he makes and sells whatever you need.
Old 11-29-2011, 06:50 PM   #536
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
i was also thinking to run a solenoid between EFR Bov and Tial bov and just choose whatever i feel like with a press of a button lol
Old 11-29-2011, 07:03 PM   #537
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Does the EFR BPV make any noise at all?
Old 11-29-2011, 07:12 PM   #538
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
i didnt even try it yet !
Old 11-29-2011, 07:46 PM   #539
manitou
Member#: 193757
2006 XTI Limited
I like it, quiet or the gnarly ppssssSTT
Old 11-29-2011, 09:14 PM   #540
Maxwell Power
Member#: 190729
it wouldn't work because removing the pressure signal would prevent the valve from staying closed under boost. You would have to trap high pressure air in the signal port of the valve which would require you to actuate the solenoid under full boost.
Maxwell Power is offline   Reply With Quote
Old 11-29-2011, 09:57 PM   #541
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Some guy on here runs an int and ext plus ebcs+hallman. He just posted in the hybrid boost control sticky in the em section
Old 11-29-2011, 09:57 PM   #542
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Thats how my was setup but with 2 MBC's 1 for pump gas and other one for meth
AEM box sent out today for RMA and car is at speedware for wheel repair and rear end suspension inspection/fixing from last year’s curb hit in snow. Should be done in 1-2 weeks! After that tuning for higher boost time
Old 11-29-2011, 10:01 PM   #543
MartinSTi05
Member#: 145145
2006 wrx STi
A threey way set up to switch quickly under boost could work, basically something. That does not exhaust as it switches.
MartinSTi05 is offline   Reply With Quote
Old 11-29-2011, 10:02 PM   #544
Phatron
Member#: 36033
CEO PhatBottiTuning
Heres his username
Originally Posted by xsnapshot
Just an update. I've been running the hybrid boost control system now for....around a year I think? It still performs great.
Just for reference its a dual wastegate/EBCS/MBC setup on a small 16G, where I see 10 psi spring pressure on the IWG (STI catback exhaust...stealthy) and 17 psi on the EWG. I had been running E85 at 20 psi on the EWG, but switched back to 91 @ 17 psi for the winter months.
Old 11-30-2011, 10:40 AM   #545
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Dom is talking BOV, you're talking wastegates. Not the same animals.
Old 11-30-2011, 11:19 AM   #546
Phatron
Member#: 36033
CEO PhatBottiTuning
^ since when? i've been running a tial bov on my up pipe for years
Old 11-30-2011, 11:47 AM   #547
kellygnsd
Member#: 32669
LINK G4 hybrid STi
But you think way outside the box Ron. Now get back to work and finish your stinkin' racecar
Old 11-30-2011, 12:27 PM   #548
Phatron
Member#: 36033
CEO PhatBottiTuning
lol...no i just cant read sometimes and then end up having conversations with myself.
Old 12-01-2011, 09:48 AM   #549
Ninja007
Member#: 150637
02 WRX Wagon
96 Impreza, 06 STI
Subscribed, you have an awesome build! Looking forward to seeing what the 7670 TS can do. I still haven't found anyone who has completed any size twinscroll EFR install and tune on a subaru, but I think your the closest to being done!
Ninja007 is offline   Reply With Quote
Old 12-01-2011, 12:23 PM   #550
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
yeah ill be first one to do it! I am making full write up soon on a blog site!
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 608 Yesterday 06:54 PM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 03:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 02:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 10:28 AM
