Old 12-22-2011, 01:20 PM   #601
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Originally Posted by MartinSTi05 View Post
The original thread was titled something like twin scroll 35R....
Results were posted from that setup. He has since changed his setup and renamed the thread accordingly. In the meant time if you wanted results that bad I suggest you build a 7670 car in the next few days and test it, I would love to see the results!
LOL Great idea Martin! I'm sure we would all love to see some 7670 results!
Old 12-24-2011, 05:43 PM   #602
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Tune is on 7th,
Just fixed some boost leaks on IC pipe, and changed oil again.
No exhaust leaks!
Bariga is offline   Reply With Quote
Old 12-24-2011, 07:02 PM   #603
MartinSTi05
Member#: 145145
2006 wrx STi
Copper RTV is the ****.
MartinSTi05 is offline   Reply With Quote
Old 12-24-2011, 07:06 PM   #604
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
some of it came out even after 1 month of not driving.
i dont think it gets dry if there if there is no air.
Old 12-25-2011, 08:06 PM   #605
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Low boost, high boost MBC
With Water activated EBCS switches to the high boost MBC "dom's idea "
Old 12-25-2011, 09:42 PM   #606
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Why not just switch the boost maps in the ECU when meth is active. You do have an AEM standalone ya know.
Old 12-26-2011, 12:22 AM   #607
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
Originally Posted by project_skyline View Post
Why is this even in PBB? I don't see a dyno sheet or results for the 7670. This looks more like a build thread.
If your going to title it 7670 at least have some results.
................k
sense of nature is offline   Reply With Quote
Old 12-26-2011, 01:25 AM   #608
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
In case one has a malfunction while not having their computer with them or not having to pull over, get the laptop out, plugged in, etc.
Old 12-26-2011, 03:08 AM   #609
reid-o
Member#: 103631
2004 STI
I also prefer mbc to ebcs,even if it's dual in this case. It's just simpler and works better in some cases.
I only prefer ebcs when I want to run per gear boost levels.
reid-o is offline   Reply With Quote
Old 12-26-2011, 06:48 AM   #610
kellygnsd
Member#: 32669
LINK G4 hybrid STi
You would have less chance of failure via the all electronic method than by allowing a mechanical solenoid to dictate what boost map you run. Even if you wanted to run a hybrid boost control using an ebcs and a mbc you just switch between two WGDC maps.
For me speed density alone doesn't really justify the price a standalone ECU. If you have one with all the extra input, outputs, and user configurable maps why not use them?
Old 12-26-2011, 01:51 PM   #611
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
2 MBC via EBCS is very reliable method of controlling boost! Boost always was on point, low boost was 22psi, high boost was 25psi never had problems! the EBCS ether at 100% or at 0%!
Old 12-26-2011, 02:50 PM   #612
kellygnsd
Member#: 32669
LINK G4 hybrid STi
There is no doubt that it works I was just interested in why you opted not to use some of your AEM functionality that you already paid for instead of adding extra points to the system with another BCS and another MBC.
Are you using the ebcs + mbc for boost control or just using the ebcs to switch between mbc's? If the latter, why the extra MAC 3-port solenoid valve ?
Old 12-26-2011, 03:07 PM   #613
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Originally Posted by Bariga View Post
im not spending any more money on this box with 4 wheels
*snickers*
OrbitalEllipses is offline   Reply With Quote
Old 12-26-2011, 03:24 PM   #614
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
yep, it switches between 2 mbc's. I don’t remember why we did that, maybe dom could add more
Old 12-29-2011, 01:24 PM   #615
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
So my AEM EGT system "1000 dollar investment" still not working, iv sent the ECU to aem, also the egt amp box.
Now they want ECU back again.
This is horrible!
Old 12-29-2011, 02:13 PM   #616
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Can the AEM take thermocouple inputs directly or do you need to go through a signal processor that outputs 0-5V to the AEM?
EDIT: can't see video at work
Old 12-29-2011, 02:32 PM   #617
joshuaj
Member#: 216249
2011 STI Sedan
This is horrible!
If you plug your probes in one at a time into the port that works what happens?
joshuaj is offline   Reply With Quote
Old 12-29-2011, 03:49 PM   #618
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
same ****, the aem amp box not connected to ecu out puts perfect! Ones you connect to ecu "any order" it starts to go crazy!
The pins inside the aem set correctly for 0-5 volts.
Domenic could never get this to work on Leons car as well, aem better fix this or ****ing take all there **** back..............
So i can switch to different brand that actually been tested and works
Old 12-30-2011, 03:07 AM   #619
Maxwell Power
Member#: 190729
Coughvipecorlinkcough
Maxwell Power is offline   Reply With Quote
Old 12-30-2011, 11:12 AM   #620
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I'll let you borrow my Link if you let me borrow your EFR.
Old 12-30-2011, 02:41 PM   #621
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
sup with yours? still didnt get it ?
Old 12-30-2011, 03:40 PM   #622
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Same thing happened to me last year with the aem, I sent it back 2 times to get updated on my own dime! Couldn't control AVCS just a complete nightmare to deal with!
Ended up going with the Vipec v88, got a few up here running with zero issues!
waynoSTI is offline   Reply With Quote
Old 12-30-2011, 03:44 PM   #623
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
well my aem works great, accept the egt inputs. Im not planning to switch to other ecu already had hydra before "thanks to dom lol"
Old 12-30-2011, 03:49 PM   #624
reid-o
Member#: 103631
2004 STI
Hopefully if you make a big enough fuss you can have them give you a deal on a version 2 (or maybe upgrade you for free). I'm just starting to push mine now, and all the low speed stuff is so much easier to work with.
Old 12-30-2011, 03:56 PM   #625
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Still no turbo for me. I was hoping to get mine shortly after you got yours but no dice.
I'm dropping the new motor in the car now and wiring up the Link so when the turbo does show up all I need to do is bolt it on.
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 624 05-27-2016 09:26 PM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 03:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 02:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 10:28 AM
