Old 12-30-2011, 04:01 PM   #626
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Originally Posted by reid-o View Post
Hopefully if you make a big enough fuss you can have them give you a deal on a version 2 (or maybe upgrade you for free). I'm just starting to push mine now, and all the low speed stuff is so much easier to work with.
hmm that would be cool, if they wont fix ill ask for v2 box.
Bariga is offline   Reply With Quote
Old 12-30-2011, 04:03 PM   #627
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Originally Posted by kellygnsd View Post
Still no turbo for me. I was hoping to get mine shortly after you got yours but no dice.
I'm dropping the new motor in the car now and wiring up the Link so when the turbo does show up all I need to do is bolt it on.
holly ****, i though that big wait was over...
Old 12-30-2011, 06:41 PM   #628
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
14 psi by 3500 rpm in 3d, still on break in tune with low timing.
Old 12-31-2011, 08:22 AM   #629
CatfaceType-R
Member#: 81102
What kind of pull was that lol, and what the heck are you listening to?
CatfaceType-R is offline   Reply With Quote
Old 12-31-2011, 03:07 PM   #630
Maxwell Power
Member#: 190729
He was showing how soon the boost comes in.
He's still on his break in tune so he's being responsible by not doing long pulls.
Maxwell Power is offline   Reply With Quote
Old 12-31-2011, 04:48 PM   #631
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Originally Posted by Bariga View Post
Subaru Sti 7670 14 psi pull - YouTube
Thats about right inline with what my 3076 used to do on the 2.5L. This is 2.3L motor your running correct?
TDagen is offline   Reply With Quote
Old 01-01-2012, 02:19 AM   #632
spackyscooby
Member#: 169257
00 rsti & 04 fxt
millenium jade
I am pretty sure its a 2.6 stroker.
spackyscooby is offline   Reply With Quote
Old 01-01-2012, 04:17 AM   #633
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
happy new year guys !
Old 01-01-2012, 08:33 AM   #634
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
Factory stroke/bore but with long rods.
EtoS is offline   Reply With Quote
Old 01-01-2012, 11:39 AM   #635
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
So that nets a 2.6L? Damn I have been reading this for about 2 months thinking this was a 2.3 destroker.
What are the advantages of running factory stroke/bore with longer rods? Shorter pistons less side loading?
Old 01-01-2012, 02:37 PM   #636
reid-o
Member#: 103631
2004 STI
Rod ratio changes but displacement stays the same
reid-o is offline   Reply With Quote
Old 01-01-2012, 08:32 PM   #637
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
Anton has a 2.5 with +2mm rods.
NW2TONE is offline   Reply With Quote
Old 01-02-2012, 03:54 AM   #638
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
No it makes it a 2.5l.
Search around built motor about long rods. There have been threads that go into great depth. Or you can ask Homemade or Dom since they are the main guys who do long rods on subarus.
Old 01-02-2012, 10:51 AM   #639
MartinSTi05
Member#: 145145
2006 wrx STi
Bore,stroke,cylinder cout are the only factors in displacement; rod length has no effect.
MartinSTi05 is offline   Reply With Quote
Old 01-02-2012, 11:11 PM   #640
sumfoo1
Member#: 82146
2005 Legacy GT
so people who have them now... worth the hype or no?
sumfoo1 is offline   Reply With Quote
Old 01-03-2012, 01:37 AM   #641
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
we will find out this Saturday!
Does AEM map from v1 can be adapted into v2 box? I'm going to ask aem if they can upgrade me..
Old 01-03-2012, 10:45 AM   #642
3MI Racing
Member#: 200987
A 2.6L is an 83mm stroked EJ25 and is qiute the opposite of a destroked engine, which is a 75mm stroked EJ25.
A 'long rod' EJ25 (79mm stroke) is not actually a long rod but pushing the rod lenght +2mm does slightly reduce rod angulation etc but really is negligable. It primarily reduces reciprocating mass.
/threadjack and onto seeing what this 7670 puts down
-Micah
3MI Racing is offline   Reply With Quote
Old 01-03-2012, 02:31 PM   #643
wrxhard
Member#: 108091
Originally Posted by 3MI Racing View Post
...It primarily reduces reciprocating mass.
-Micah
How does putting more material into a rod make it lighter (2mm longer)? Not trying to be a dick, honestly wondering how that works? I mean, if they make something a special way for the long rod motors, couldn't they in turn make it the same way for a standard rod motor and come out even further ahead in reciprocating mass?
wrxhard is offline   Reply With Quote
Old 01-03-2012, 03:30 PM   #644
Loubaru
Member#: 155489
07 STi
I'm assuming its because you end up with a shorter piston....?
Loubaru is offline   Reply With Quote
Old 01-03-2012, 08:41 PM   #645
3MI Racing
Member#: 200987
Largely yes. The rods, even my +4mm ones still way FAR less than a stock rod too.
Old 01-03-2012, 09:20 PM   #646
wrxhard
Member#: 108091
However, could those principals not be applied to a "stock length" rod and custom forged piston for an even lighter still reciprocating mass? I guess, that's the question i was going for...
Old 01-03-2012, 10:26 PM   #647
MartinSTi05
Member#: 145145
2006 wrx STi
NO, in other words. If you lengthen the rod by 2mm you must shorten the compression height of the piston by 2mm. even though the aluminum that composes the piston is is ~1/3 the density of the steel that makes up the con rods; there is a more than 3:1 difference in the effective cross section of the length shortened from a piston VS. the length added to a rod.
CN: 2mm less piston compression height weighs less than 2mm extra rod length.
Oh, and you are right you can apply both principles if you are willing to have a piston that sits way below deck, but that sucks.
Old 01-03-2012, 11:55 PM   #648
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
From my understanding it has little to do with the weight and more to do with the geometry.
Old 01-04-2012, 02:30 AM   #649
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Little compare of 35R and EFR 7670 lol no number yet this is just for ****s and giggles
35R did 9 psi at 3500 rpm
EFR did 15psi at 3500 rpm
so EFR spools about 500 rpm faster, and im sure on dyno dom will make it spool even faster!
Old 01-04-2012, 11:18 AM   #650
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Hurry up and get tuned. I'm getting antsy over here
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 624 Yesterday 09:26 PM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 03:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 02:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 10:28 AM
