Old 01-04-2012, 12:23 PM   #651
sumfoo1
Member#: 82146
2005 Legacy GT
.... my td06 20g is doing 15 psi @ 3500 lol.....
ok turbo envy is official.
sumfoo1 is offline   Reply With Quote
Old 01-04-2012, 01:03 PM   #652
RealStreet
Member#: 205916
2003 Subaru WRX
in the 10's and the bends
Everything looks promising. I still really like the Ball Bearing 5857/6262 units for these engines because the price and availability is good, but I can't wait to see more results with this thing!
RealStreet is offline   Reply With Quote
Old 01-04-2012, 02:09 PM   #653
armyssoldierboy
Member#: 109424
06 AW STI
Twin Scroll HTA gt3076r
Geoff @ Full Race told me this turbo would be very comparable to my hta gt3076r. I hit 15psi @ 3400rpm. I want to see the boost turned up on this thing
armyssoldierboy is offline   Reply With Quote
Old 01-06-2012, 12:17 AM   #654
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
changed the oil at 1400 miles! Break in is over...
Bariga is offline   Reply With Quote
Old 01-06-2012, 12:57 AM   #655
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
Do a leak down test to see if rings seated.
methaddict is offline   Reply With Quote
Old 01-06-2012, 08:54 PM   #656
monkiboy
Member#: 202958
2008 wrx
what time is the tune tomorrow so i can begin refreshing this page every thirty seconds?
monkiboy is offline   Reply With Quote
Old 01-06-2012, 09:18 PM   #657
fourmicah
Member#: 128760
2015 STI
^^^^ My thoughts exactly, can't wait to see the results! Have fun Bariga!
fourmicah is offline   Reply With Quote
Old 01-07-2012, 12:10 AM   #658
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
just did a compression test on the engine, 115 psi across the board.
Old 01-07-2012, 12:22 AM   #659
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
What compression ratio, if you don't mind me asking? Sorry if it's already been mentioned.
lancelucas is offline   Reply With Quote
Old 01-07-2012, 02:52 AM   #660
Maxwell Power
Member#: 190729
Is this the same tester you used Last time that gave you low readings?
The important thing is they are even.
I think his is 8.17:1. Because we were going to run high boost on this turbo on pump then more with meth.
Add in bigger cams than stock and avcs in full retard with I'm guesting a closed throttle body...
Maxwell Power is offline   Reply With Quote
Old 01-07-2012, 03:33 AM   #661
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
didn't press gas pedal when i did the test, totally forgot.
we not going to dyno tune it tomorrow, my cam sensor is acting up.
i'm eye balling the new 2012 vipec v10 plug in board
Old 01-07-2012, 05:10 AM   #662
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
Son of a....
EtoS is offline   Reply With Quote
Old 01-07-2012, 07:13 AM   #663
methaddict
Member#: 159738
2004 WRB STi
AEM v1 has issues with our cam sensor and has been fixed on AEM v2 which I sold my Hydra 2.6 to get.
Old 01-07-2012, 07:49 AM   #664
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Does the plug in board have a knock sensor? I know the current boards are based on the V44 which don't have knock control unless you buy the separate unit.
V88 has it built in, just food for thought! That reminds me... they finally fixed the issue where it retarded timing even though I did not pass the knock threshold yet. Time to go back to Dom for a tune! Maybe play with closed loop boost control and closed loop idle?
alcoolaid is offline   Reply With Quote
Old 01-07-2012, 12:33 PM   #665
Maxwell Power
Member#: 190729
Yes. the new boards are based off the 88.
Technically based off the link g4 extreme. The link is the actual unit and the vipec is just a rebranded link.
Old 01-07-2012, 01:10 PM   #666
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
aem worked perfectly with kelford c, now it doesn't like the b`s
some one should come up with chart which cams are compatible with aem.
dom does link have close loop?
Old 01-07-2012, 01:37 PM   #667
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Closed loop what?
Things Link can do in closed loop:
boost control
knock control
fueling w/ wideband
cam control
throttle control
idle control
and maybe more
Old 01-07-2012, 06:36 PM   #668
slowgenius
Member#: 48350
04 Jackstands
Dirty PSM
Originally Posted by Maxwell Power
...avcs in full retard ...
You never go Full Retard! Lol sweet build going on here.
slowgenius is offline   Reply With Quote
Old 01-07-2012, 10:06 PM   #669
reid-o
Member#: 103631
2004 STI
I still have delayed startup but it could be a setting I haven't figured out yet.
It idles my 1200cc well on pump though.
edit...
Nevermind my voltage is dropping below 10volts on crank for some reason..with jump pack it's starting up first crank.
Don't count the EMS 2 out is all I'm saying.
reid-o is offline   Reply With Quote
Old 01-08-2012, 05:24 PM   #670
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Thanks to Dom i had my car on dyno for couple of pulls. We found the boost tappers down 4 psi at red line, something i need to trouble shoot and fix before next session!
Good thing it pumps 16psi at 3500 rpm, we ran max 20 psi so no crazy numbers
Old 01-08-2012, 06:14 PM   #671
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Sweet any graphs, just a sneek peek at how its responding so far?
TDagen is offline   Reply With Quote
Old 01-08-2012, 07:09 PM   #672
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Looks like i found the potential problem, efr internal bov was caped off with rubber cap and believe it was lifting under boost because it has tiny spring in it and no boost applied.
Just did a small test on the 40 mph speed zone in 3d, looks ok
The purpose of the dyno was just to make sure i have every thing correctly setup so we dont have to waist time on final session. I wont post it
Old 01-09-2012, 12:43 AM   #673
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
i want ! this would make it so easy to change springs forge is just not using there brains when making products.
http://www.turbosmartusa.com/news/ne...ors-are-coming
Old 01-09-2012, 05:04 PM   #674
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Just ordered 30 psi spring for the Forge actuator!
That should hold 20 psi on spring pressure!
Old 01-10-2012, 01:26 PM   #675
Maxwell Power
Member#: 190729
I'm confused. Does the EFR not come with it's own actuator?
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 607 10-11-2015 09:50 PM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 04:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 03:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 11:28 AM
