Old 01-10-2012, 01:27 PM   #676
Layvon
Member#: 195711
STi 04/05/06/07
From what I've read and understand is that the actuators (even the high psi application) isn't strong enough to run lots of boost. Hopefully I worded that right.
Layvon is offline   Reply With Quote
Old 01-10-2012, 08:57 PM   #677
tanker_wx
Member#: 255789
2008 sti10(GRF)
Red
amazing torque power band
i love high cam
tanker_wx is offline   Reply With Quote
Old 01-20-2012, 10:29 AM   #678
Maxwell Power
Member#: 190729
Originally Posted by Bariga
PUMP
PUMP / METH
You should specify in this post that these are the graphs from the 35r
Then you can go back and add the graphs from the efr after we get done tuning it.
Maxwell Power is offline   Reply With Quote
Old 01-20-2012, 12:11 PM   #679
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
i made forge not to leak from spring chamber!
Basically sealing the rubber end of the diaphragm on the road!
tested and doesn't leak!
Dom any info on ETA of Vipec?
Bariga is offline   Reply With Quote
Old 01-20-2012, 05:14 PM   #680
armyssoldierboy
Member#: 109424
06 AW STI
Twin Scroll HTA gt3076r
What did you put down at 20psi?
armyssoldierboy is offline   Reply With Quote
Old 01-20-2012, 07:21 PM   #681
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
graph is posted on the blog
was 18 psi max falling off
Old 01-21-2012, 01:52 AM   #682
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
2nd day with no power at home due to snow storm
Old 01-22-2012, 10:57 PM   #683
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
After testing the Forge 2nd port again with higher psi the rubber part expends and creates a balloon. How the **** forge released something like this with out testing it?
anyways i put in 30 psi spring and did 1 turn preload, "using MBC on low setting"
looks like im ready for dyno again@
Old 01-22-2012, 11:09 PM   #684
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
So are you sticking with the series I, or going series II or Vipec?
Old 01-22-2012, 11:18 PM   #685
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
vipec should arrive some time next week i hope!
Old 01-22-2012, 11:39 PM   #686
joshuaj
Member#: 216249
2011 STI Sedan
Why not use the actuator that came from BW?
joshuaj is offline   Reply With Quote
Old 01-22-2012, 11:53 PM   #687
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
looking forward to your vipec results. i hear there is a ton of wiring involved.
maxpowr is offline   Reply With Quote
Old 01-23-2012, 03:53 PM   #688
armyssoldierboy
Member#: 109424
06 AW STI
Originally Posted by Bariga View Post
Thanks to Dom i had my car on dyno for couple of pulls. We found the boost tappers down 4 psi at red line, something i need to trouble shoot and fix before next session!
Good thing it pumps 16psi at 3500 rpm, we ran max 20 psi so no crazy numbers
All I saw was your 35r graph is why I was asking. Maybe I missed it.
Old 01-23-2012, 03:53 PM   #689
kellygnsd
Member#: 32669
LINK G4 hybrid STi
You're the second or third person I've heard say that in the past few days and I don't know where or who you get your info from but its wrong. The only thing you need to wire up to run correctly is an IAT probe but you need that for any correct SD system. Wiring in a wideband is optional but give you closed loop fueling and autotune functionality. Everything else is plug and play via the adapter harness or direct plug in with the replacement board units.
Old 01-23-2012, 03:57 PM   #690
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
So you know the Adapter harness is discontinued, because they just released v88 board that goes inside the stock ECU case. its all plug and play and has extra harness cable that you can attach for input and output channels.
Old 01-23-2012, 03:59 PM   #691
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
This is the EFR with poor WG spring
Old 01-23-2012, 04:13 PM   #692
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i was interested in buying a vipec back in 2009. at the time i was told the wiring would take a couple days and i would need a vipek specific tuner which would cost another thousand on top of the steal of a price of 2500$ installed. if i remember correctly the tuners name was franz?
that being said, i opted for ecutek. then i met phatron. i have used open source for years since then to monitor the car and open source tune it but never was able to get anyone to show me what was being changed and how.
considering the carberry 16bit sd rom.
sorry for the thread jack bariga, maybe i will reconsider the new vipec. i havent committed to anything (AEM), and since junior and ray are my local tuners, i'm not sure if they even wanna mess with that. we'll see.
Old 01-23-2012, 05:03 PM   #693
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I heard they were gonna do start doing that. They may have stopped production of the adapter harness but it can still be found in stock in the right places.
They make a full wire-in universal model too and that's probably what you where quoted. Now they have model specific, nearly plug and play units for certain cars now. Like Bariga said they have the replacement boards or the universal models with the adapter harness like I have.
Old 02-01-2012, 08:01 PM   #694
Layvon
Member#: 195711
STi 04/05/06/07
Sooooo today is February 1st. Did you get tuned?!?
Old 02-01-2012, 08:04 PM   #695
Maxwell Power
Member#: 190729
Vipec will be here Friday.
Old 02-01-2012, 08:06 PM   #696
Layvon
Member#: 195711
STi 04/05/06/07
Good good. You guys getting excited over there at Maxwell Power?
Old 02-01-2012, 08:25 PM   #697
Maxwell Power
Member#: 190729
I guess....
Old 02-01-2012, 09:14 PM   #698
biodude
Member#: 271720
Originally Posted by Maxwell Power View Post
I guess....
lol45
biodude is offline   Reply With Quote
Old 02-01-2012, 10:25 PM   #699
monkiboy
Member#: 202958
2008 wrx
so vipec arrives friday, when is it installed and when is tuning day?
monkiboy is offline   Reply With Quote
Old 02-01-2012, 10:49 PM   #700
cpturbo
Member#: 49175
2004 STI
I sure hope there are no more set-backs!!
cpturbo is offline   Reply With Quote
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 623 Yesterday 10:58 PM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 03:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 02:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 10:28 AM
