Old 02-15-2012, 01:35 PM   #826
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
You should talk to Raffi He has a dualport.
jkopinga is offline   Reply With Quote
Old 02-15-2012, 01:44 PM   #827
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
he sold me Forge dual port that doesn't work! the spring chamber doesn't hold pressure
Bariga is offline   Reply With Quote
Old 02-15-2012, 05:23 PM   #828
Spike_916
Member#: 170007
2006 STi
Obsidian Black Pearl
Man Bariga, I am sorry you are having all these complications. When it's done you can at least have some fun with it instead of fixing problems.
BTW, when you got your turbo did it come with all the fitting for the lines or did you have to locate and find correct fittings?
Spike_916 is offline   Reply With Quote
Old 02-15-2012, 06:13 PM   #829
Layvon
Member#: 195711
STi 04/05/06/07
It does come with the -4 an fitting for the oil, but yes I agree letting us know what fittings to purchase would be very helpful!
Layvon is offline   Reply With Quote
Old 02-15-2012, 06:49 PM   #830
Spike_916
Member#: 170007
2006 STi
Agree, Ed @ EQ Tuning had to do some research and special ordered the rest of the fittings. Don't know about the fittings but it sounded like they weren't common.
Old 02-15-2012, 07:52 PM   #831
Layvon
Member#: 195711
STi 04/05/06/07
They aren't that bad, the one for the oil fitting is the most difficult in my opinion .. . Which is included. But you can also use a 1.5" span tube to bolt it in.
The coolant lines can be just AN also, I read the BW EFR manual this weekend, but forgot the fine details beyond this.
What was cool was the 15 increments you can rotate for placement of your lines.
Old 02-15-2012, 08:13 PM   #832
Spike_916
Member#: 170007
2006 STi
See that's where it drew some concerns, we didn't get a manual or any step by step when the turbo arrived. Literally it was a turbo in a box with a small baggy that included interchangeable parts. One part from memory was the EBC faceplate that said "Full-Race" instead of the stock beige faceplate which was interchangeable.
EDIT: oh and the FR invoice.
Old 02-15-2012, 09:31 PM   #833
Layvon
Member#: 195711
STi 04/05/06/07
Edit... didn't want to clutter bariga's thread.
Still eager for results Anton!
Old 02-16-2012, 01:58 AM   #834
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
The turbo has to be fixed almost as WG bracket touching the T4 flange bolt.
I used 2 90 degree -8 AN coolant fittings for coolant lines "make sure to use BW coolant seal rings", and oil return i tried everything and only one thing worked. 45 degree NTP -10 AN fitting and then straight -10AN to barb.
Also i had to take out the BPV spring out and replacing with 5mm rubber hose for suspension of lifting under load "because the spring is tiny"
Old 02-16-2012, 01:58 AM   #835
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
http://www.full-race.com/articles/efrturbotechbrief.pdf
You read that yet? If you plan on installing an EFR it would behoove you to read it.
Old 02-16-2012, 03:09 AM   #836
vicious_fishes
Member#: 158864
2003 SOHC destroker
does anyone know anyone that works @ borg that can tell us what the hell is going on?
vicious_fishes is offline   Reply With Quote
Old 02-16-2012, 06:17 AM   #837
Layvon
Member#: 195711
STi 04/05/06/07
Yeah I read that in that was my edited post I didn't wanna clutter up the thread I actually sent that to spike haha. It is a very good reading it teaches you pretty much any then you need to know about the EFR that borg warner want you to know
Old 02-16-2012, 08:12 AM   #838
kellygnsd
Member#: 32669
LINK G4 hybrid STi
If your not gonna use the built in BPV there is a block off plate that you have to use otherwise it will open when you don't want it to since its looking for boost pressure to stay closed. It's all in the technical briefing document.
Old 02-16-2012, 08:43 AM   #839
tomespo
Member#: 306922
tomespo is offline   Reply With Quote
Old 02-16-2012, 10:55 AM   #840
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
The last story posted up was that Bw switched foundries. So I'm assuming they're setting up the casting molds/tooling. Then the new products need to be tested again. And bw's contract with Indy probably comes way before fr. Plus there is probably litigation going on between Bw and the first foundry. Most of that is just a guess though.
Old 02-18-2012, 05:53 AM   #841
monkiboy
Member#: 202958
2008 wrx
any tuning today Anton?
monkiboy is offline   Reply With Quote
Old 02-18-2012, 12:24 PM   #842
Maxwell Power
Member#: 190729
Wired in a different knock sensor, got the knock control working, wired in the methanol injection, got the map switching to work.
Only issue is massive boost creep on this internal wastegate.
I strongly advise against the iwg. I have from the start and now that I see it in action it is worse than I had anticipated.
Maxwell Power is offline   Reply With Quote
Old 02-18-2012, 12:32 PM   #843
Nuke209
Member#: 108089
2003 WRX
NF Performance
Nuke209 is offline   Reply With Quote
Old 02-18-2012, 12:50 PM   #844
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
I'll be having a word with Geoff to see what's up. I'm not liking this.
EtoS is offline   Reply With Quote
Old 02-18-2012, 12:58 PM   #845
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
you guys have something effed up -- there is NO boost creep, ive been flogging the hell out of my evo and saw zero. also five other cars ive done with this internal gate and seen zero creep
Full-Race Geoff is offline   Reply With Quote
Old 02-18-2012, 12:59 PM   #846
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
bariga- before coming to any conclusions give me a call - im willing to bet you have the actuator cranked with too much preload OR plumbed wrong. I have pushed this internal wg very very hard and have shaft speed sensor videos to prove it does not creep if setup properly.
Old 02-18-2012, 01:01 PM   #847
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
ok bariga - if the dual port doesnt work, please email me whats up and ill get it taken care of. Raffi's father passed away at the beginning of this week so he has been out of the office and unable to get back to everyone's messages. If you have emailed him with no response, please be patient. he will get back to you as soon as he returns
the water connections are identical to GT30/GT35 -- M14 nothing fancy there
the oil feed connection is -4 AN, it comes with the turbo
the oil drain connection is 3/8" NPT - no 2 bolt flange needed
the turbos are still on backorder - if youre waiting and want to try a different turbo i recommend S200SX 7670 external WG or S300SX FMW external WG.
Old 02-18-2012, 02:32 PM   #848
Maxwell Power
Member#: 190729
both those turbos are freakin rocking!
I like the efr and I suppose it's possible that Anton goofed something up with the IWG, but it acts like most IWGs on Subarus.
I know Geoff and the BW crew like the IWG, and claim there is no performance gain in an EWG on that turbo. However, I just don't see it being possible. If you reduce the amount of flow going into your exhaust post turbo, then you lower the back pressure and therefor get a better differential pressure across the turbine which means more turbine work which means more bypassed gasses through the EWG which means less back pressure on the engine which means better flow through the engine, more scavenging, more beneficial flow during overlap to cool hot spots and flush all exhaust gasses out of the cylinder. I suppose if you had a 4" exhaust you could possibly see the same performance on each, but at the hp levels we push a 3" exhaust would benefit from an EWG.
Old 02-18-2012, 04:15 PM   #849
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
Dom, I don't think anyone is expecting the IWG to be right onpar with an EWG. It's more of a balancing act of pros/cons especially with twinscroll. Twinscroll EWG means double the WGs, dump tubes, required room, etc. It's definitely a step above traditional IWG methods while lessoning the gap between that and EWG.
Dom, have you yourself messed with the actuator on Antons car yet? I know he did ALOT of tinkering with it. Maybe he did something to screw it up?
Also how well does the Vipec work with the hydramist system? I'm assuming direct port injection as well?
Old 02-18-2012, 05:48 PM   #850
Phatron
Member#: 36033
CEO PhatBottiTuning
How did u get that dyno pull at flat 20psi if it's spiking?
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 634 06-11-2016 02:34 AM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 03:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 02:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 10:28 AM
