Old 06-29-2012, 02:38 PM   #1251
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
time to try out flex fuel sensor ? mix 92 with meth ?
Bariga is offline   Reply With Quote
Old 06-29-2012, 04:02 PM   #1252
Layvon
Member#: 195711
STi 04/05/06/07
Even though there is a bov on the EFR the full race kit has a vband/ flange for bov?
Layvon is online now   Reply With Quote
Old 06-29-2012, 04:31 PM   #1253
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
He doesn't have the full race FMIC kit
... and there is no BOV on his full race headers
Old 06-29-2012, 04:50 PM   #1254
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
there is, its called EWG
Old 06-29-2012, 11:14 PM   #1255
Layvon
Member#: 195711
STi 04/05/06/07
Oh okay. I thought you had a full race kit Anton my mistake. ... sneaky sneaky with the EWG
No doubts this way!! I ended up bagging the EFR unfortunately. . But I'm going with vipec now!
Old 06-29-2012, 11:40 PM   #1256
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Good choice with the Vi-Pec, you won't be dissapointed. Have you downloaded PC Link or whatever Vi-Pec calls it?
Do you have your EFR already?
Old 06-30-2012, 04:49 PM   #1257
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
PC link software looks same as vipec, just not as ugly
Old 07-01-2012, 12:08 AM   #1258
Layvon
Member#: 195711
STi 04/05/06/07
I did download it a while back, but haven't done much with it. Is there a map one of you fellas could send me so I could tinker around? Doesn't need to be anything special.
Guess I worded it funny... I am getting a pte 6262 with ceramic bearings and billet wheel now. Not as technologically advanced but proven. Running twin scroll still so hopefully spool up is not sacrificed too much. Sorry Anton, didn't mean to clutter...
When is your "final" tune scheduled?
Old 07-01-2012, 01:27 AM   #1259
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Should be some maps that came with the download that you can play around with.
alcoolaid is offline   Reply With Quote
Old 07-01-2012, 01:03 PM   #1260
yuto1981
Member#: 324657
Totally and undeniably SICK!
yuto1981 is offline   Reply With Quote
Old 07-02-2012, 12:46 AM   #1261
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
was logging EGTs on vipec today
Cyl 1 340
Cyl 2 400
cyl 3 345
cyl 4 360
Cyl 2 runs hottest, not sure why going to swap injectors around see if anything changes.
I also got all the air out of PS pump took a long time now its not telling ecu that its always on
Old 07-02-2012, 12:53 AM   #1262
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Does the vipec have per cylinder fueling/timing?
And from those temps I'm assuming that's C and at cruise? Does that correlation hold true at wot too?
Old 07-02-2012, 01:50 AM   #1263
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
^ Yes i can add more fuel or timing per cylinder!
Temps where checked at idle, light wot, and 10 psi boost. Probes are good! - when u shut off the engine the temps are about all same.
Old 07-02-2012, 03:27 AM   #1264
alcoolaid
Member#: 134949
'07 SWP STi
which EGT amp are you using?
Old 07-02-2012, 12:49 PM   #1265
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
AEM Thermocouple
Right now all the Per cylinder tables are at 0, i was searching the web and couldn't find anything other than stock ecu advances timing on 2 and 4 for knock control
To balance out #2 and #4 i will have to add more fuel ?
Old 07-02-2012, 04:24 PM   #1266
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
to get 15-30 degrees in differences between cylinders i had to do this
1. -5.0 %
2. + 19 %
3. - 5.0 %
4. + 8.0%
19% more fuel to cylinder 2 that's is ****ing mad! any ideas?
Old 07-02-2012, 04:34 PM   #1267
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Swap #1 & #3 EGT probes and report back.
Old 07-02-2012, 04:43 PM   #1268
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Isnt MPS doing the build/Tune? Id have a tuner set all that up for ya....19% seem very high.
Old 07-02-2012, 04:58 PM   #1269
Layvon
Member#: 195711
STi 04/05/06/07
You had to add fuel to 1 bank and subtract from the other.. do you think there is a problem with fuel flow between the rails?
Old 07-02-2012, 05:04 PM   #1270
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
EGT probes are accurate, if you look up 3 posts before i said when engine off EGT's are within 3 C.
I don't think fuel system can be issue its all -6 with P&L Rails and Fuellab regulator. For note bank 2 and 4 has shorter fuel return line
Dex was also having similar issue with his setup but doesnt have EGT probes for troubleshooting.
Old 07-02-2012, 05:13 PM   #1271
Layvon
Member#: 195711
STi 04/05/06/07
Refresh my memory, do you have 2 - 6 lines going the whole way or do you split before the rails from a -8 or bigger?
It has to be pretty freakin cool to be able to troubleshoot on the level that you can with this computer
Old 07-02-2012, 05:39 PM   #1272
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
-6 from stock lines every where if that's what you asking
Old 07-02-2012, 05:51 PM   #1273
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Old 07-04-2012, 12:18 AM   #1274
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Noticed if i set fuel trims to 0 and just add 3 degrees of timing to 2 and 4 temps drop about 20-30c creating less differences with in all 4 instead of adding tons of fuel with little improvement. What you guys thing?
Old 07-04-2012, 12:52 AM   #1275
Phatron
Member#: 36033
CEO PhatBottiTuning
you could make valid arguements on both sides....
more timing, less fuel should give u better mpg and better feel at low loads....but at WOT have 4* variance and way higher cylinder pressures could be a downfall
the highest variance between cylinders subaru uses is 2*.
so maybe a happy medium of 2* of timing and a little fuel is the answer to garner benefits from each strategy.
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 634 06-11-2016 02:34 AM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 03:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 02:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 10:28 AM
