Old 07-04-2012, 02:08 AM   #1276
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
ya i think that would be good idea add 2 degrees and 2% fuel to 2 and 4, i may pull the plugs out and check like dex did.
Bariga is offline   Reply With Quote
Old 07-04-2012, 02:15 AM   #1277
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
or u could try what u said and swap the injectors and see if they even out better
Old 07-04-2012, 03:04 AM   #1278
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Checked compression today came out 130 across!
here is a pic of 1100 miles spark plugs
4 3 2 1
4 and 2 should be the whitest by EGT readings! 4 Looks like its richest
Last thing i will do send the ID1000s to WitchHunter for flow check.
Old 07-04-2012, 06:30 PM   #1279
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
They all look super rich. Can't even see the insulator
alcoolaid is offline   Reply With Quote
Old 07-05-2012, 05:07 AM   #1280
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
^^This!
I'd say something is just (very) off with your tune (waaayyy too rich) or your plugs are the wrong heat range.
Flow checking injectors is not gonna do much about either of those two. Especially since your compression is very nice.
If your that rich maybe bad mixture firing occures and you get more variation in individual EGT readings as well.
Also if spark plugs are the wrong heat range, getting in the right ones will probably also clean up your perceived variations in EGT's: if the plug doesn't fire cleanly, etc etc...
From your EGT reading, 350-400 Celcius is very low, suggesting also pig rich conditions coinciding with the plug reading.
I'd check tuning first. Whats your lambda target map where you ran these EGT readings?
Beetspeed is offline   Reply With Quote
Old 07-05-2012, 04:45 PM   #1281
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
it might be rich starting and rich fuel accel maps, because when i drive afr is spot on
Old 07-05-2012, 04:57 PM   #1282
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
You sure you have the O2 calibrated properly? That looks crazy rich!
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 07-06-2012, 02:17 AM   #1283
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
-- Ed
That sort of thing happens on AEM widebands
My $.02 -- Bariga, you are using a partial set of consumer/enthusiast-grade hardware to attempt an OEM-grade tune. You need better measurement equipment. I would also not attempt what you're doing beyond a *very* minor per-cylinder adjustment without having complete in-cylinder pressure data at my disposal. You're relying on an incomplete analysis of the situation to make changes...but, you seem like the type of guy who will do whatever it takes, and in-cylinder pressure measurement tools can be had for sub $10k these days
lancelucas is offline   Reply With Quote
Old 07-06-2012, 02:22 AM   #1284
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
-- Ed
wide band is calibrated and gauge and ecu show same number,
When the engine just fired what crank enrichment AFR i need to have?
Also how about fuel accel enrichment when i hit gas i think it goes rich as hell, because when you tap the throttle multiple times it chocking.
Old 07-06-2012, 05:17 AM   #1285
alcoolaid
Member#: 134949
'07 SWP STi
You have the over run fuel cut turned on too right
Old 07-06-2012, 11:51 AM   #1286
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
also found out crank enrichment was set to key on, so every time i turn key on it sprays i need a better tune ......
Old 07-06-2012, 11:56 AM   #1287
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
That kind of deposit is not going to happen from a brief rich condition on tip-in. Those plugs are showing a nearly constant rich condition and/or incomplete combustion. Maybe you're running too little ignition advance?
-- Ed
Old 07-06-2012, 12:13 PM   #1288
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
-- Ed
fuel and ignition looks decent
Old 07-06-2012, 01:41 PM   #1289
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
Whats your fuel table's unit? Is that IDC percentage or something?
I've only seen # milliseconds before..
Do you run closed loop? If so, what does your lambda target map looks like? That would tell more then a fuel table as each engine is different and all that.
Old 07-06-2012, 01:59 PM   #1290
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Old 07-06-2012, 03:33 PM   #1291
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
What benefit do you see having the AFR Target as a function of MAP and ECT instead of as a function of MAP and RPM.
It looks like you're trying to handle you start-up enrichment via the AFR target table instead of with the post enrichment and warm up enrichment tables. Keep in mind that closed loop lambda may not be active during warm-up so you may not get any response tweaking your AFR target table until the conditions are met for close loop lambda.
Old 07-06-2012, 03:56 PM   #1292
alcoolaid
Member#: 134949
'07 SWP STi
+1 my afr target table isn't even active until ect is 70+ C
Old 07-06-2012, 04:36 PM   #1293
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
make sense, but any way you do this you will get same result.
Old 07-06-2012, 05:43 PM   #1294
kellygnsd
Member#: 32669
LINK G4 hybrid STi
You probably mean pre-crank prime. That only pulses the injectors once before the start for milliseconds. You won't flood anything out here.
Crank enrichment just adds a percentage of fuel for a predetermined amount of time during cranking.
Old 07-06-2012, 06:57 PM   #1295
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Ok thanks, just don't like the idea of injectors open when key is on
You have the over run fuel cut turned on too right]
Its set on 1400, looks ok,,
Old 07-06-2012, 09:25 PM   #1296
alcoolaid
Member#: 134949
'07 SWP STi
What do you have in your injector timing table under fuel? degrees @ BTDC
Old 07-07-2012, 10:59 PM   #1297
Maxwell Power
Member#: 190729
Most ECM'S do that.
You keep saying you need a better tune, but you won't schedule a time and you keep ****ing with it.
Not to sound like a Dick, but you don't understand half the stuff these engines do.
For example, you said ecu and gauge read the same afr. Of course they do! Its the same output from the same sensor. They will always read the same if you have the 0_5v setup right.
Maxwell Power is offline   Reply With Quote
Old 07-07-2012, 11:04 PM   #1298
Maxwell Power
Member#: 190729
Lots of advantages.
I can enable closed loop right after the sensor warms up. This means I can ensure that she doesn't run too rich when cold in lots of different conditions.
Pretty much all oem ecus do this.
Rpm has very little purpose on the afr target as load and coolant temp are the primary factors.
Old 07-07-2012, 11:05 PM   #1299
Maxwell Power
Member#: 190729
This is something we still need to work on. it looks like we are short circuiting the fuel.
Old 07-09-2012, 02:53 AM   #1300
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Dom but my setup didn't change at all from last tune we had..
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 634 06-11-2016 03:34 AM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 04:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 03:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 11:28 AM
