Old 07-09-2012, 02:48 AM   #1301
reid-o
Member#: 103631
2004 STI
Originally Posted by Bariga
Dom but my setup didn't change at all from last tune we had..
If he just tuned it on the dyno for a break in tune, he may not have had time to adjust all of the warmup and startup settings to his liking.
reid-o is offline   Reply With Quote
Old 07-09-2012, 03:01 AM   #1302
Maxwell Power
Member#: 190729
We changed compression ratio and rod length for starters. And we never finished the last tune, remember? You were having boost control issues and we put off finishing the tune until you got them squared away.
Maxwell Power is offline   Reply With Quote
Old 07-09-2012, 12:02 PM   #1303
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
Bariga,
Maybe a long shot (or a short one), but couldn;t you just try a warmer plug for starters?
Spark plugs are cheap after all and an easy/fast swap.
Beetspeed is offline   Reply With Quote
Old 07-09-2012, 12:31 PM   #1304
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Rod length is same, we went with long rods remember? And compression changed to 8.5 from 8.2 or something like that. Ill call you tomorrow to see if you have time some.
Bariga is offline   Reply With Quote
Old 07-09-2012, 01:40 PM   #1305
Maxwell Power
Member#: 190729
Originally Posted by Beetspeed View Post
Whats your fuel table's unit? Is that IDC percentage or something?
I've only seen # milliseconds before..
It isn't really anything. It's like VE, but not exactly. If you change the master fuel, then it changes total fuel by a percentage, which then means you need bigger or lower numbers in that table. I can set it to be 55% at idle and make it approximately match VE, but it doesn't matter.
I've asked multiple times while tuning this car "Are you sure the WBO2 is calibrated properly?"
Judging by the EGTs and rich plugs I'm not so certain. I'm going to check the end of injection point and see if we're short circuiting the fuel.
One thing to point out is that Bariga lugs this engine alot. By a lot, I mean A LOT. He shifts very early and just putts around on it less than 2k rpm everywhere. He doesn't accelerate with any zest. He thinks he's doing the engine a favor, but I don't agree.
I think what needs to happen is this:
1. New WBO2. LC1 at a minimum. Or at least let me verify the readings with my AFX WBO2. If the plugs are that dirty, the sensor is probably that dirty.
2. New plugs.
3. Let me finish the tune.
He got the boost control system working fine so let's do it.
Old 07-09-2012, 02:37 PM   #1306
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
Tnx Maxwell for the interesting read on the fuel table numbers!
I'am sure between the two of you, you'll sort the engine out till its ~perfect!
Old 07-09-2012, 03:02 PM   #1307
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Do you run closed loop? If so, what does your lambda target map looks like? That would tell more then a fuel table as each engine is different and all that.
Its in percentage of the overall fuel master value. If you overall fuel master is 16.35ms a value of 100 in that cell would net you a 16.35ms pulse width.
Old 07-09-2012, 05:33 PM   #1308
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
not sure if this means anything but under statistics i have max INJ of 19ms after 5 days of driving. And when i'm at wot from the back it looks like i have diesel engine
Old 07-09-2012, 06:30 PM   #1309
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I suggest you don't do that then
Old 07-09-2012, 07:10 PM   #1310
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Lolol
alcoolaid is offline   Reply With Quote
Old 07-09-2012, 07:34 PM   #1311
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Old 07-10-2012, 11:14 AM   #1312
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
The last two AEM WBO2's in my car have proven to be worthless except for quick visual checks that fueling is half-way sane. Not nearly accurate enough for precise tuning.
lancelucas is offline   Reply With Quote
Old 07-10-2012, 01:22 PM   #1313
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
1000% truth
Junior2JZ is offline   Reply With Quote
Old 07-10-2012, 01:30 PM   #1314
Maxwell Power
Member#: 190729
did you change the master fuel on accident? It was 12.5:1 according to your wbo2 at 7psi.
Old 07-10-2012, 03:51 PM   #1315
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
No bro, the only places i mess with is idle and cold starts
I noticed gauge read out is .2 / .3 different from what ECU shows! I tipple check Cal settings for it with manual and its correct.
Old 07-10-2012, 03:53 PM   #1316
Maxwell Power
Member#: 190729
and cylinder trims....
put those back to 0.
Old 07-10-2012, 04:01 PM   #1317
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
yeah i did that, only messed with it on cruising speeds
Old 07-10-2012, 04:10 PM   #1318
Maxwell Power
Member#: 190729
most of my standalone customers use LC1 and not the AEM, so I haven't had that much time with it.
Old 07-10-2012, 05:25 PM   #1319
alcoolaid
Member#: 134949
'07 SWP STi
Voltage offset from different ground. You have to manually correct until they read the same. Or make sure sensor ground is same as ecu ground.
Also thought you said before that you were 100% sure it read the same...
Old 07-10-2012, 06:48 PM   #1320
kellygnsd
Member#: 32669
LINK G4 hybrid STi
This is the easiest fix, ground them all at the same physical location, same ground lug.
Old 07-11-2012, 11:46 AM   #1321
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
wideband connected to external plug on the vipec board,
Old 07-11-2012, 11:59 AM   #1322
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Yes and one of the 4 leads that come from it is an ECU sensor ground. Your LC-1 and gauge should both be connected to the lead that is the ground lead. Are they?
Old 07-11-2012, 12:08 PM   #1323
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
there was 4 pins
1 AnVolt11
2 +14V from Main Relay
3 Power Ground
4 Signal Ground
i used power ground
Old 07-13-2012, 05:29 PM   #1324
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
break in is done, 1200 miles!
Good stuff is going in thanks Dom!
Old 07-13-2012, 05:34 PM   #1325
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
Ready to tune and thrash!
Dave D. is offline   Reply With Quote
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 634 06-11-2016 02:34 AM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 03:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 02:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 10:28 AM
