Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 07-15-2012, 05:26 PM   #1326
R/TErnie
Member#: 169005
2004 STi
You need a competent tuner.
R/TErnie is offline   Reply With Quote
Old 07-15-2012, 05:29 PM   #1327
Layvon
Member#: 195711
STi 04/05/06/07
Just leave. You are clueless
Layvon is offline   Reply With Quote
Old 07-15-2012, 05:41 PM   #1328
Ohhey1
Member#: 260297
2006 STI White
HTA Green Methanol
What made you use 5w50 if you don't mind me asking? I've always gone back n forth on 30 or 40 but never made the switch. First time seeing someone use 50.
Ohhey1 is offline   Reply With Quote
Old 07-15-2012, 06:41 PM   #1329
kurion
Member#: 75543
05 05 WRX 4eat
PSM 2.5 35R
Personally dunno really know any of the parties involved in the build, and hope it works out well for Bariga - But R/TErnie, unless I'm mistaken, own an EFR 7670 - has put it on his evo (tuned on a ViPec) and has been making alot of power with it, so probably has more experience with that turbo than probably anyone else in this thread. Plus he owns an STI too....
http://forums.evolutionm.net/all-mit...4-efr7670.html
So I guess what I'm trying to say is people should probably think before calling someone clueless....
kurion is offline   Reply With Quote
Old 07-15-2012, 06:53 PM   #1330
Layvon
Member#: 195711
STi 04/05/06/07
Based on his posts on here, I didn't see anything showing the fact that he is knowledgeable about it. If intact he is quite knowledgeable ... I would have thought he would have posted something more helpful to Bariga. ...
Anyhow.. I am eager to read his thread
Old 07-15-2012, 06:55 PM   #1331
CatfaceType-R
Member#: 81102
RTe is a very knowledgeable user...Didn't even know he had an Sti. I am morepsitehbett4 on everywhere else but here, btw.
Layvon is a good guy, let's all get along, pls
Carmi
CatfaceType-R is offline   Reply With Quote
Old 07-15-2012, 07:57 PM   #1332
Maxwell Power
Member#: 190729
Not a nice thing to say.
Maxwell Power is offline   Reply With Quote
Old 07-15-2012, 10:02 PM   #1333
Layvon
Member#: 195711
STi 04/05/06/07
After reading a bit of his thread on his Evo, definitely knows his stuff. So I retract my initial statement regarding being clueless. However - Dom has 99% positive reviews from customers and competitors alike, so the tuner bashing was a little out of line. I think that Bariga and Dom will soon show us what this EFR can do
Old 07-16-2012, 12:25 AM   #1334
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
Tuner bashing is all the rage. It leads to epic conversations like: "Bro my turbo seized", "Brah your oil pressure is tune related, serious" "Thanks Bro, that's what I thought"
907Bum is offline   Reply With Quote
Old 07-18-2012, 05:39 PM   #1335
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
So what are the results Anton?
alcoolaid is offline   Reply With Quote
Old 07-19-2012, 12:08 PM   #1336
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Here are the results!
Half of day we were fighting stupid ass EFR boost control issues!
With perrin Actuator it was same results as Forge, boost goes to 18 psi and tappers to 15!
The only way to properly control the boost with "No Tapper"on IWG EFR is to run Perrin dual port Actuator and using 2 boost control Solenoids! Or one Quad port!
19 psi on pump
22 psi with meth
With 2 solenoids hooked up inline we had trouble with Vipec's PID seating had to make them at around .4 and duty cycles at 30%
I will come back on Dyno with 4 Port solenoid installed next month to see if we get better control of boost!
The car runs awesome full boost at 4200 rpm
Bariga is offline   Reply With Quote
Old 07-19-2012, 01:00 PM   #1337
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
Wow! 500 Wheel HP at only 23 psi!
I see no boost taper in your pressure graph though. I'd say it works as is?
Good job!
Beetspeed is offline   Reply With Quote
Old 07-19-2012, 01:01 PM   #1338
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Good job!
After installing second boost solenoid we fixed the boost tapper!
That took good 3-4 hours!
Old 07-19-2012, 01:12 PM   #1339
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
I assume you mean to say that the "only way to have the ECU control the boost is with..."
Cause I am pretty sure an MBC or AVCR would do it
aboothman is offline   Reply With Quote
Old 07-19-2012, 01:32 PM   #1340
Layvon
Member#: 195711
STi 04/05/06/07
Well... insert regret I didn't get The EFR... nice graphs man.
Old 07-19-2012, 01:44 PM   #1341
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Dom hated the design and i had to spend **** loads of dyno time and money to get it to work correctly, save time and money and buy EWG version!
Old 07-19-2012, 02:47 PM   #1342
alcoolaid
Member#: 134949
'07 SWP STi
Stick with what's proven. Ewg all the way!
So you're using closed loop boost control now right? How is part throttle response on it.
Like boosting 2 psi then suddenly mash it wot.
Old 07-19-2012, 03:03 PM   #1343
reid-o
Member#: 103631
2004 STI
I know that this sounds ridiculous, but rather than upgrade to the EWG version, you may want to just add ewg to the up pipes or get the ewg up pipe from Full Race. At the pressures you're running, the smaller 92 A/R is probably better suited to your driving style than the 1.05. It defeats the purpose of getting that model though, I know. It sure looks like a damn fun ride. Anyone with a tig can easily lock down the IWG flapper for you with a bracket. You could even just add preload to the arm and then tack it to the port, assuming the assembly is some form of steel.
Just curious (the ricer in me wants to know): Is the turbo as loud as the 83-75, like Alcoolaid's setup? I normally don't like psh psh sounds, but that turbo spool sounds cool as hell.
reid-o is offline   Reply With Quote
Old 07-19-2012, 03:09 PM   #1344
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
i really don't know what to say on this one, but all my friends say when i drive behind them all they hear is like jet engine taking off.
Old 07-19-2012, 03:10 PM   #1345
reid-o
Member#: 103631
2004 STI
Also on a side note, I'd ask for DOM to set the fuel boost cut rather close to target boost. I'd rather live with the irritation of hitting boost cut every so often, something like 25psi, as an alternative to trusting the IWG ability to regulate boost after seeing all the trouble it's caused.
Old 07-19-2012, 03:17 PM   #1346
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
we set boost cut on dyno to 28 psi
Old 07-19-2012, 03:29 PM   #1347
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
You mean all the under boosting it's been doing?
Old 07-19-2012, 03:44 PM   #1348
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
Nice results. But this isn't true. Not to say my EFR hasn't been touchy, but I'm in good control with the stock 2 port and BW's high pressure actuator. No overrun, no taper. With the stock ECU running the show.
I agree that it did take a bit of work to nail down a combination that works well. Too much preset on the actuator or too small of a pill, and the turbo would run off on me...
thefoos is offline   Reply With Quote
Old 07-19-2012, 04:40 PM   #1349
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Sadly it is true! Only way to get the tapper off is the pressuring the spring chamber on Perrin Actuator with 2nd boost valve, by tapper i mean like big drop from 18psi to 13psi.
Old 07-19-2012, 04:47 PM   #1350
Layvon
Member#: 195711
STi 04/05/06/07
Finally this threads has turned on some smiles Anton
I ended up going with some older technology and got a PTE 6262 with the ceramic bearings and billet wheel, and EWG.
Glad you got it with the dual port though.
Nice work... eager to see some boost in the middle of the efficiency range!
Levon
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 624 05-27-2016 09:26 PM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 03:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 02:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 10:28 AM
