Old 07-27-2012, 03:06 PM   #1426
joshuaj
Member#: 216249
2011 STI Sedan
Originally Posted by vica153 View Post
Yeah that is odd. It seems like it would just be a software issue and why would they stop at just barely minimum number of tables.
I know nothing about the specific ecu you mention but it's likely hardware and processing ability. A lot of micros are really memory limited. I do some embedded programming and it's not as simple as one might think. FWIW
joshuaj is offline   Reply With Quote
Old 07-27-2012, 03:18 PM   #1427
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Originally Posted by Bariga
Man wtf are you talking about? The 2 solenoids were tried because Jeff @ Perrin recommended, because we had mad tapper and wanted to try other ideas instead of waisitng time on dyno.
if i see more ignorant posts in here ill delete this thread,.
How was it an ignorant post? Didn't the mbc provide a nice solid boost curve? Where as all the other setups did not? All I was saying is if it worked then why not use it.
I admit I can't name everything you have tried because you have tried many different boost control setups but if the mbc worked then it seems like the easiest solution.
Old 07-27-2012, 03:29 PM   #1428
3MI Racing
Member#: 200987
Originally Posted by Bariga View Post
I went on motec website, place their top of the line ecu in cart and choose all available options and price tag was over 80,000 bucks.
the funny thing most of the options were software unlocks, man that's just silly!
Since when had Motec sold directly? When did they add a shopping cart function?
edit: went and looked real quick and don't see one. I know for a data aq system, you can quickly blow $60k in a setup. I'm guessing every option was well beyond just the ECU
3MI Racing is offline   Reply With Quote
Old 07-27-2012, 04:30 PM   #1429
Bariga
Member#: 179846
07 STi MPS Build
EFR 7670 TS
As we though the problem was with EFR IWG design and the WG actuator so by slapping MBC in there it ruled that out right away. So i still would like to try 3 port again, and 4 port just for ****s and giggles.
Bariga is offline   Reply With Quote
Old 07-27-2012, 04:32 PM   #1430
Bariga
Member#: 179846
07 STi MPS Build
EFR 7670 TS
let me check where i got 80k price from
Old 07-27-2012, 04:59 PM   #1431
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
So when is the 4 port getting thrown on?
~levon
Layvon is offline   Reply With Quote
Old 07-27-2012, 05:09 PM   #1432
Bariga
Member#: 179846
07 STi MPS Build
EFR 7670 TS
~levon
when i come down to mps, i think some time next week!
the 4 port might be ideal setup! with lighter spring will see.
should i hook it up and run open loop boost control and work with WGDC tables?
Old 07-27-2012, 05:11 PM   #1433
reid-o
Member#: 103631
2004 STI
I guess the reason everyone is confused is that--I can't speak for all--but I think we don't understand what features you want to use from the VIPEC in terms of boost control?
Is it because you want a failsafe for your meth?
Is it because you want RPM adjustability? Or do you want switchable levels?
I think if you defined it then it would explain more.
I think that most are under the assumption that you just want stable boost control, in which case the MBC seems to be working to do that. But then a single MBC is too simple for RPM control or perhaps dual stage, but it's not quite clear what you want to run.
You can still have a failsafe for example running a single MBC and enabling the output of the aquamist to trip a nitrous map which has reduced timing and a slightly richer mixture. That would still be maximizing the features of the VIPEC--just not all of them.
reid-o is offline   Reply With Quote
Old 07-27-2012, 05:16 PM   #1434
Bariga
Member#: 179846
07 STi MPS Build
EFR 7670 TS
Well my pump gas map is set to 19 psi "430 whp" and meth map at 23psi "500whp"
So 2 different boost settings, 2 solenoids in parallel defiantly not the way to do it.
Old 07-27-2012, 05:56 PM   #1435
Maxwell Power
Member#: 190729
calm down gents!
It's just a car!
Maxwell Power is offline   Reply With Quote
Old 07-27-2012, 05:57 PM   #1436
reid-o
Member#: 103631
2004 STI
Is the 19 psi a fail safe map?
Old 07-27-2012, 06:02 PM   #1437
reid-o
Member#: 103631
2004 STI
Since the delta between the 2 boost levels are not extreme I think a second option is to just run the 23 psi with 2 fuel maps triggered by the failsafe unless you plan to run for long periods without the methanol.
Old 07-27-2012, 06:04 PM   #1438
Maxwell Power
Member#: 190729
you are correct, 19psi is just pump.
23 is with meth. When the DDS3 cuts, it switches back to the 19psi map.
We will NOT be running 23psi on pump gas with this engine.
Old 07-27-2012, 06:28 PM   #1439
vica153
Member#: 76586
1994 GF6
No need for other options people. Vi-PEC and 4port will work just fine. Do it. Do it now!
vica153 is online now   Reply With Quote
Old 07-27-2012, 06:40 PM   #1440
Bariga
Member#: 179846
07 STi MPS Build
EFR 7670 TS
Old 07-27-2012, 06:49 PM   #1441
alcoolaid
Member#: 134949
'07 SWP STi
Twinscroll ViPec Anti-lag
Less posting on Nasioc more wiring in ebcs lol
alcoolaid is offline   Reply With Quote
Old 07-27-2012, 11:03 PM   #1442
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
don't spawn my thread with retarded posts ETOS
That's fine, go ahead and keep ignoring everyone's suggestions. It's funny how just about everyone has nothing to say about you other then how hard it is to work with you. I wonder why.
EtoS is offline   Reply With Quote
Old 07-28-2012, 11:18 PM   #1443
Bariga
Member#: 179846
07 STi MPS Build
EFR 7670 TS
hooked up the 4 port solenoid, enabled close loop boost control, set all settings to recommended "per help file" works flawless! Works even better than MBC
Tested my Defi boost guage and that sucker is spot on , this only tells me my aem 3.5 bar map sensor is out of calibration
Old 07-28-2012, 11:37 PM   #1444
alcoolaid
Member#: 134949
'07 SWP STi
Did you calibrate the boost gauge? Defi has a calibration sequence. Atmospheric pressure sensor in the control unit.
Old 07-29-2012, 01:10 AM   #1445
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
AEM is cheap Chinese Junk!
Just playing around Anton. Glad you finally got er.
Old 07-29-2012, 04:11 AM   #1446
Bariga
Member#: 179846
07 STi MPS Build
EFR 7670 TS
please share calibration process, how I check it was connect air compressor with 20 psi and check on defi. I calibrated map sensor in kpa by aem chart, so it's less than 1 psi diffarance before the numbers where little off
Old 07-29-2012, 04:56 AM   #1447
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
OP, Get some boost LOGs up so we can see the improvements! Also include WGDCs so we can see the WGDCs behaviour nearing the topend. Thanks!
Jasper.
jkopinga is offline   Reply With Quote
Old 07-29-2012, 01:55 PM   #1448
Bariga
Member#: 179846
07 STi MPS Build
EFR 7670 TS
Code:
Boost Target	WGate DC	DI 1 Frequency	Gear	Speed -DI1	Engine Speed	WideBand 1	D-Gain	I-Gain	P-Gain	An V11 - WideBand	MGP (PSI)
kPa	%	Hz		kph	RPM	AFR	%DC	%DC	%DC	AFR	PSI
0	0	40.5	3	60.4	2883	14.4	0	0	0	14.4	-7.3
0	0	41.2	3	61.5	2956	14.6	0	0	0	14.6	0.2
236	43	42.7	3	63.7	3063	12.2	0	0	0	12.2	2.3
236	43	42.7	3	63.7	3090	12.7	0	0	0	12.7	2.6
236	43	47.3	3	70.9	3395	12.5	0	0	0	12.5	6.9
236	43	49	3	73.4	3535	12	0	0	0	12	9.1
236	43	50.4	3	75.6	3664	11.9	0	0	0	11.9	11.3
236	22.1	51.7	3	77.4	3753	11.6	-15	0	14.1	11.6	13.3
236	21.8	56.2	3	84.2	4013	10.9	-6	0	4.8	10.9	17.5
236	24.5	56.7	3	84.9	4062	10.5	-3	0	4.5	10.5	17.6
236	25.4	58.3	3	87.1	4174	10.6	0	0	2.4	10.6	18.7
236	22.2	61.2	3	91.8	4373	10.6	0	0.1	-0.9	10.6	20.1
236	21.6	62	3	92.8	4477	10.5	0	0.1	-1.5	10.5	20.5
Old 07-29-2012, 02:01 PM   #1449
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
Do you shift at 4k5 rpm? I was hoping to see a pull towards the topend so we could see the behaviour of the 4-port, etc. Anyways... glad to hear you got it better under control now.
Jasper.
Old 07-29-2012, 02:03 PM   #1450
Bariga
Member#: 179846
07 STi MPS Build
EFR 7670 TS
lost rpm feeld somewhere but i rev this one to 7k, still not best logs due to 3d gear in 35mhp zone
Code:
WGate DC	DI 1 Frequency	I-Gain	P-Gain	MGP (PSI)
%	Hz	%DC	%DC	PSI
23.4	65.8	0.1	0.3	19.7
23.4	68.9	0.1	0.3	19.5
23.7	70.6	0.1	0.6	19.4
23.8	72.5	0.2	0.6	19.2
24.2	73.9	0.3	0.9	19.1
24.9	75.9	0.4	1.5	19.1
24.7	77.6	0.5	1.2	19.1
25.2	79.3	0.7	1.5	18.9
25.3	80.8	0.8	1.5	18.9
25.1	82.7	0.9	1.2	19.1
25.5	84.3	1	1.5	18.9
26.4	86.2	1.3	2.1	18.7
26.2	86.6	1.4	1.8	18.8
26.3	87.9	1.5	1.8	18.8
27	90.3	1.9	2.1	18.7
27	90.6	1.9	2.1	18.7
27.3	92.3	2.2	2.1	18.7
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 563 05-16-2012 08:28 PM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 03:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 02:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 10:28 AM
Message Board Statistics All times are GMT -4. The time now is 03:54 PM.
