Old 01-23-2011, 10:21 PM   #126
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
I'm looking forward to seeing the results.
What's the duration and lift of the new cams?
Old 01-24-2011, 11:29 AM   #127
Maxwell Power
Member#: 190729
He's going to a smaller cam for more torque.
http://www.camshaftshop.com/home?pag...category_id=65
264/260
225/222@.050
10.7/10.2
Maxwell Power is offline   Reply With Quote
Old 01-24-2011, 11:28 PM   #128
NSFW
Member#: 140444
05 Stage Free LGT
Interesting, thanks!
Old 01-27-2011, 01:41 AM   #129
evoevo
Member#: 166301
04 500 hp evo
Wow amazing numbers. Gotta love that 35r. I love mine just hate the frikkin lag.. Haha... Good luck with your new found power. I can imagine this is a blast!
evoevo is offline   Reply With Quote
Old 01-29-2011, 06:47 PM   #130
Maxwell Power
Member#: 190729
Here are some pictures of the OP's heads. The porting is just about done.
Old 01-29-2011, 07:28 PM   #131
35RspoolinScooby
Member#: 272137
very nice
35RspoolinScooby is offline   Reply With Quote
Old 01-29-2011, 08:28 PM   #132
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Nice Dom,
Glad there is some progress going, i cant even come up to the shop
more header porn
Bariga is offline   Reply With Quote
Old 01-31-2011, 02:47 AM   #133
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Get the 8374 instead so I know how much power it makes
alcoolaid is offline   Reply With Quote
Old 02-01-2011, 12:30 PM   #134
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Not trying to break subaru hp record, looking for super torq fast spool and make 500-540 whp
Old 02-02-2011, 07:04 PM   #135
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
same reason i am using the 7670 on my street car
Full-Race Geoff is offline   Reply With Quote
Old 02-07-2011, 12:26 PM   #136
Maxwell Power
Member#: 190729
Here is the flow sheet from your heads, Anton.
Old 02-07-2011, 12:47 PM   #137
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
+12345
I don't think you will hit 500-540whp on low reading dyno with the 7060, you will need to run tons of timming and boost. Never the less this is a great setup, I can't wait to see what she puts down.
Old 02-07-2011, 12:55 PM   #138
Maxwell Power
Member#: 190729
7670 is rated for 650hp. With proper modifications he should be able to max that turbo out and hit at least 500whp. 23% drivetrain loss on 650hp is 500whp.
He's running meth injection as well.
Old 02-07-2011, 01:03 PM   #139
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
The head porting should help out a bit. Smaller cams but the flow of the heads back it up!
FuJi K is online now   Reply With Quote
Old 02-07-2011, 01:09 PM   #140
juanmedina
Member#: 133146
he might make it on race gas on E85 on meth I doubt it. GL
Old 02-07-2011, 01:09 PM   #141
Maxwell Power
Member#: 190729
The idea was to get better airflow without sacrificing as much velocity as huge cams and getting full use of the AVCS to broaden the power band. With the 199-B cams and our valve reliefs, we can run as much advance as is mechanically possible, the 199-C is a little too aggressive for that.
The heads do flow quite well.
Old 02-07-2011, 01:11 PM   #142
Maxwell Power
Member#: 190729
it's my first tune, so I need it.
Old 02-07-2011, 01:47 PM   #143
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Equilibrium Tuning is offline   Reply With Quote
Old 02-07-2011, 02:22 PM   #144
NSFW
Member#: 140444
05 Stage Free LGT
Those rules-of-thumb worked for Garrett turbos, but I don't think they will work so well with EFRs. With Garretts, the compressor flow capacity was basically synonymous with the point at which compressor efficiency dropped to 65%. So since the 3582 flows a little over 65 lb/min at 65%, people refer to it as a 65 lb/min or 650 chp turbo:
http://www.turbobygarrett.com/turbob...-allcomp_e.gif
Borg-Warner, on the other hand...
http://www.turbodriven.com/performan...ages/76s75.jpg
They've got 64 ft/lb highlighted for some reason... but at 65% efficiency it flows around 61 ft/lb, and to reach 61 ft/lb you have a run a 4.0:1 pressure ratio, or 40+ psi. I expect to see people running more like 2.5:1 where it flows about 50 lb/min at 65% efficiency. So, 400whp, making it an alternative to the GT3076, not the GT3582. On pump gas, anyway.
The big question in my mind is whether it reaches that 2.5:1 pressure ratio any sooner than the GT3076 does.
Old 02-07-2011, 02:45 PM   #145
juanmedina
Member#: 133146
Why so angry? I meant good luck with the built
Originally Posted by Equilibrium Tuning View Post
You know whats funny, his 470whp 2.3LR 35r STi trapped 121mph the same as my VF39.......
Old 02-07-2011, 03:19 PM   #146
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
you may want to read more into that cars first and botched run...
Old 02-07-2011, 03:19 PM   #147
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
you and your LONG GEARS!!!!
Old 02-07-2011, 03:32 PM   #148
juanmedina
Member#: 133146
G[quote=Homemade WRX;33232748]you may want to read more into that cars first and botched run...
[/quote....n
Old 02-07-2011, 07:37 PM   #149
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
if 7670 wont be good enough, I'm sure i can sell it in 5 seconds of posting on here, and get the next sized turbo which will be plug and play.
Dom so my heads got back from shop?
Old 02-07-2011, 07:59 PM   #150
Maxwell Power
Member#: 190729
not yet.
Valves guides are being redone. There was too much play.
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 634 06-11-2016 02:34 AM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 03:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 02:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 10:28 AM
