#1526 |
Member#: 179846
NWIC
Vehicle:07 STi MPS Build EFR 7670 TS |
it doesn't hit anything, it opens up about little less then half inch with 1/8th inch preload.
Hard to see on this pic ![]()
#1527 |
Member#: 190729
NWIC
that's as far as it goes?
#1528 |
Member#: 179846
NWIC
#1529 |
Member#: 32669
SCIC
Vehicle:2007 FR TS EFR 7670 LINK G4 hybrid STi |
You should consider renting me your turbo so I can get my car up and running and sort my map out. I promise not to make more power than you.
#1530 |
Member#: 179846
NWIC
if you drop 5.5k in my paypal account sure!
#1531 |
Member#: 32669
SCIC
That's steep, is that per day?
#1532 |
Member#: 179846
NWIC
haha i was implying on the whole kit
they keep saying its arriving next month? |
#1533 |
Member#: 32669
SCIC
October is the werd I herd
#1534 |
Member#: 134949
VIC
Vehicle:'07 SWP STi Twinscroll ViPec Anti-lag |
Jesus. I said 2012 in 2011. I'll say 2013 before you see yours haha
#1535 |
Member#: 179846
NWIC
#1536 |
Member#: 32669
SCIC
#1537 | |
Member#: 103631
Vehicle:2004 STI Black |
I hope you get yours soon. |
#1538 |
Member#: 179846
NWIC
#1539 |
Member#: 179846
NWIC
haha tell me about it, if you with in 90 days you can always do charge back if they not taking it back!
#1540 |
Member#: 195711
Vehicle:STi 04/05/06/07 JBP / OBP for now |
Wish I was this smart. C&P from the document:
"The speed sensor is powered by a +5V supply, and the return signal is a variable frequency square wave that has maximum amplitude of 5V and has a 50% duty cycle. The frequency of this signal depends on the speed of the wheel. Each passing blade creates a pulse, and all the EFR wheels have 14 blades except for the 67mm (which has 12 blades). The sensor embedded electronics divides the blade-pass frequency by 8, and then the resulting count forms the output waveform. Here is an example: 100,000 rpm * 14 blades/rev = 1,400,000 blade pass counts per minute 1,400,000 / 60 sec/min = 23,333 blade pass counts per second (Hz) 23,333 / 8 count divisor = 2,917 Hz output frequency" So in short, you aren't necessarily looking for a voltage, but a frequency for the computer to read. Once you know your frequency, you'd know your rpm with some quick math OR... you buy this box ![]() http://www.roadragegages.com/xcart/p...cat=251&page=1 |
#1541 | |
Member#: 179846
NWIC
if yes thats all that matters |
#1542 | |
Member#: 134949
VIC
#1543 |
Member#: 190729
NWIC
bingo, the speed is worthless without a compressor map.
#1544 |
Member#: 32669
SCIC
I was looking at the roadrages signal converter but I don't have any 0-5V analong inputs left so no I need to find a frequency divider that will allow me to get the max signal down below 500 Hz. I had found one before but forget where I saw it.
#1545 |
Member#: 179846
NWIC
had to do this lol
#1546 |
Member#: 179846
NWIC
its back together ones again
![]() This this was a real pita! first i installed the engine it took me 10 min i was surprised how quick it was and then i realized i didn't put the ****ing clip on pressure plate , Second try it really didn't want to go back in :P spent 5 hours and at end used old trick with bolts. Looks like with new tensioner i get no start up rattle, thanks Dom for quick turn around. I want this! ![]() |
#1547 |
Member#: 195711
Help me out... clip on pressure plate... what did I forget to install on my motor?!?!
#1548 |
Member#: 134949
VIC
Finally going with a wider tire setup? Haha
#1549 |
Member#: 124282
NWIC
Vehicle:04 WRX Wagon PSM 13 STI Sedan SWP |
#1550 |
Member#: 65140
NWIC
Vehicle:2007 STI Limited#213 05 STI (rip) 03 WRX (rip) |
Subaru version of this... |
| Thread Tools | |
| Display Modes | |
| Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band | Maxwell Power | Proven Power Bragging | 563 | 05-16-2012 08:28 PM |
| Maxwell Power Services aka GetaDomTune | AwaySooner | Vendor Reviews | 7 | 03-11-2010 03:54 PM |
| +1 for Dom/Maxwell Power | Jeff54 | Vancouver Impreza Club Forum -- VIC | 22 | 09-02-2009 02:22 PM |
| My new Maxwell Power Services engine is almost in !!! | leonbmx | North West Impreza Club Forum -- NWIC | 13 | 03-23-2009 10:28 AM |
