Old 09-10-2012, 11:41 PM   #1551
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Originally Posted by lancelucas
The clip in the center of the PP that retains/engages the TO bearing.
Not sure why he removed it during the R&R, but they do sometimes get mangled or need to be replaced.
You need to remove it to get the throw out bearing out. How else do you separate it from the pressure plate
alcoolaid is offline   Reply With Quote
Old 09-11-2012, 01:22 AM   #1552
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
i actually put the clip on throw out bearing it self lol dont ask
Bariga is offline   Reply With Quote
Old 09-11-2012, 03:47 AM   #1553
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
No, you don't Have removed many TO's from the PP without removing the ring (or damaging it).
lancelucas is offline   Reply With Quote
Old 09-11-2012, 05:53 AM   #1554
Layvon
Member#: 195711
STi 04/05/06/07
Oh okay. I found that if you have the Pressure Plate on the bench, plate down and let the throw out bearing settle, you can pop it out very easily with a flat head screw driver and a twist. Whew. Thanks gentlemen!
Layvon is offline   Reply With Quote
Old 09-11-2012, 02:10 PM   #1555
Maxwell Power
Member#: 190729
that's how we do them when we pull the motor. Just use a long flat head, reach down next to the release arm and pop it out of the plate. No need to remove the shaft or any of that crap.
The clip never comes out of the pressure plate for any reason.
Maxwell Power is offline   Reply With Quote
Old 09-11-2012, 05:36 PM   #1556
Layvon
Member#: 195711
STi 04/05/06/07
Originally Posted by Maxwell Power View Post
that's how we do them when we pull the motor. Just use a long flat head, reach down next to the release arm and pop it out of the plate. No need to remove the shaft or any of that crap. .
Good to know for the future!
Old 09-11-2012, 10:24 PM   #1557
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
was about to renew tabs after car is all back together guess what emissions test required wtf... now i need AP
Old 09-12-2012, 11:06 PM   #1558
BlackEyeII
Member#: 65140
2007 STI Limited#213
05 STI (rip) 03 WRX (rip)
Default No prob
Just flash an OTS stage 7 and your good to go....
BlackEyeII is offline   Reply With Quote
Old 09-17-2012, 12:25 PM   #1559
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Been getting weird AFR spikes lately, not sure if its the Innovate MTX gauge or its actual misfires! Feedback any one?
https://docs.google.com/open?id=0B8g...W9UczUzQUJLbU0
https://docs.google.com/open?id=0B8g...UpVdmJNbmFORDQ
https://docs.google.com/open?id=0B8g...XV1VmE1RjlSUWs
https://docs.google.com/open?id=0B8g...3JqYkRaOUE0WVU
Happens at random boost levels, usually anywhere from 4500 to 5500 rpm under load.
Same with meth injection as well
Cant really feel it in the car, also knock sensor is quiet.
Running Brisk 2 step cold plugs gaped to .030 and factory coil packs.
Old 09-17-2012, 01:21 PM   #1560
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
I'm I missing something here? The logs you provided don't go into the 4500 -5500 rpm zones??????
SCRATCH THAT. you think google docs would work better on android.
Old 09-17-2012, 01:46 PM   #1561
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Do you have a log with individual EGTs at the time of the AFR fluctuation
Old 09-17-2012, 01:52 PM   #1562
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
EGTs looks same as always climbing to about 690c at red line, with no major bumps, the EGT system is not very fast acting anyways, its only good to see a big picture.
Old 09-17-2012, 02:30 PM   #1563
kellygnsd
Member#: 32669
LINK G4 hybrid STi
http://www.exhaustgas.com/Deptselect.asp
A little OT but I'm running these guys EGT probes and oil sensor probes and I'm trying out one of there exposed junction EGT probes that they use on top fuel cars. The response time is 250 ms and they say with their probes you can see a single misfire @ 8000 rpm. I'm going to log the exposed junction probe along with the normal EGT probe to see the difference in response times.
Old 09-17-2012, 06:45 PM   #1564
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
i'm thinking it might be the spark plugs, going to drop in old NGK iridiums or Denso IKH22 and if it changes anything.
step 2 cold plugs are rated for 700+ whp,
Old 09-19-2012, 12:46 AM   #1565
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
passed emissions today thanks again Dom!
Old 09-21-2012, 10:01 PM   #1566
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
after long time of trouble shooting the AFR spikes thinking its misfires went to store bought new sensor and boom afr in perfect line!
****ing innovate support is trying to blame it on missfires and that if the sensor is not showing error code its good ********...
Old 09-21-2012, 10:28 PM   #1567
alcoolaid
Member#: 134949
'07 SWP STi
Told you man
Old 09-22-2012, 12:40 PM   #1568
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
So you've had that innovate for like 4-6 months and it crapped out? Sounds about right.
Innovate tried to blame the car or install for problems with their product....sounds about right.
That's why I stopped recommending them. 99% of their "troubleshooting" is blaming the customer and telling them they didn't install it correctly.
I really believe innovate has some serious electrical issues with their controllers that causes premature wear. The same Bosch sensors last a million times longer with uegos than innovate.
Old 09-22-2012, 12:48 PM   #1569
berdugo
Member#: 163108
07 EuroDM STi 2.5L
What kind of Innovate is that? LC-1? I have LM-1, removed it and replaced with LC-1. LC-1 is horrible compared to LM-1. I'm thinking if LC-1 gets damaged easily due to severe heat of the engine bay, unlike LM-1 since LM-1 controller is inside the car, much cooler but eats up a lot of space.
berdugo is offline   Reply With Quote
Old 09-22-2012, 12:51 PM   #1570
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
its mtx-l, the problem with uegos its very slow!
ill be calling them on monday to get free sensor, will see how thats going to flow
Old 09-22-2012, 12:51 PM   #1571
alcoolaid
Member#: 134949
'07 SWP STi
I had an lc-1 with main unit mounted on my strut bar, sensor mounted at rear o2 location and I went through sensors like nuts. I sold it after the 5th or 6th sensor swap. On an aem now and still on the original sensor. Might give the mtx-l a try though.
Old 09-22-2012, 12:56 PM   #1572
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
can sensor get damaged from cleaning it with compressed air?
Old 09-22-2012, 01:08 PM   #1573
berdugo
Member#: 163108
07 EuroDM STi 2.5L
I have my sensor for both lm-1 and lc-1 at the back of the turbo exhaust housing. Never need to replace the sensor with lm-1, my lc-1 ate 2 sensors already
I'll try to put the lc-1 controller inside the car, if it still kill sensor that soon, i'll just remove it and put back my lm-1.
Old 09-23-2012, 12:51 AM   #1574
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
As i have 1 available table left thinking to use it for AFR limit under boost, does it make sense?
Old 09-23-2012, 06:24 AM   #1575
alcoolaid
Member#: 134949
'07 SWP STi
That's probably going to cut in and out under shifting
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 634 06-11-2016 02:34 AM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 03:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 02:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 10:28 AM
