#1576 |
Member#: 179846
NWIC
Vehicle:07 STi MPS Build EFR 7670 TS |
i dont seee how its possible to have 20 psi while shifting
#1577 |
Member#: 32669
SCIC
Vehicle:2007 FR TS EFR 7670 LINK G4 hybrid STi |
You also have the activation delay you could set if you did see boost for a split second during a shift or if you wanted to use this with FFS.
#1578 | |
Member#: 179846
NWIC
Tested works good, had to redo map table like this 0 100 200 300 kpa Blocked hood vent, 10 dollar mod! ![]() ![]() some random shoots with good camera ![]() ![]() ![]() Last edited by Bariga; 09-23-2012 at 09:08 PM. |
#1579 |
Member#: 65140
NWIC
Vehicle:2007 STI Limited#213 05 STI (rip) 03 WRX (rip) |
What wheels are those? I would say works emotions at a glance. What is he offset/ size?
I pretty much want my car to look like yours but not as clean or as fast ![]() |
#1580 | |
Member#: 134949
VIC
Vehicle:'07 SWP STi Twinscroll ViPec Anti-lag |
#1581 |
Member#: 179846
NWIC
bbs S204 18 / 8.5 56 offset i think
#1582 | |
Member#: 193757
Vehicle:2006 XTI Limited OBP, Junior tuned |
You're car is so ****ing clean and stealth. It is the **** in my book! Really what all Tarmac driven Subarus should be. So unsuspecting but relentless should some so called fast car pick on it! I'm bad but it is fun to embarrass other drivers some times. Idiots that pick on my XTI, usually regret it and I'm sure some cry ![]() Do you really want to block off that hood scoop? That will create more drag and I think that hood scoop flow is not bad for the engine compartment even with a FMIC. Almost like a Venturi effect from the volume of both the front grill and the hood scoop. The constriction is the exit at the fire wall, the air speeds up and helps evacuate all of the air in the engine compartment. |
#1583 |
Member#: 179846
NWIC
thanks man, about the scoop i was reading that people saw improved intake temps with scoop being blocked off "some where on iwsti" i gotta find the link
#1584 |
Member#: 190729
NWIC
Without a sealed tmic, the scoop adds drag. It also pressurizes the engine bay reducing cooling flow through the radiator. With a tmic, there is still a little drag, but the intercooler slows flow through the scoop minimizing the effect.
Multiple tests have been done over the years to prove this. |
#1585 |
Member#: 166215
NWIC
I installed a hood vent from KSTech along with a custom plate a few years ago with the idea that it would help vent the positive under-hood pressure and increase airflow through the radiator/FMIC. Obviously doesn't look stock though so if that is important to you perhaps running an RS or painted carbon one would suit your needs, and might be marginally better than forcing air into the engine compartment with the scoop.
#1586 |
Member#: 179846
NWIC
so I got mine, I hope you ("got yourself a pump")
![]() will plug it to stock fuel controller do a test, and then will hard wire it to 100% duty with fat wires and then do test again! I think ill prove everyone that different wires wont do **** ![]() new toy for quick logging ![]() Last edited by Bariga; 11-21-2012 at 04:07 PM. |
#1587 |
Member#: 23123
SWIC
Vehicle:05 Legacy GT 13 Scion FR-S |
those pumps are awesome. I swapped an aeromotive 340 out for the Walbro 416 (or 460?) E85, my old fuel system was so taxed, the AFRs richened up 2 POINTS!
#1588 |
Member#: 179846
NWIC
i have feeling that the WD300 and aeromotive 340 and new aem's pump is overclocked walbro 255
#1589 |
Member#: 179846
NWIC
#1590 |
Member#: 124282
NWIC
Vehicle:04 WRX Wagon PSM 13 STI Sedan SWP |
A lot of people have already proven than there is a voltage drop through the controller, even under low amperage/load. Go throw a DMM on the pins at the top of the pump hanger. You'll save yourself time from trying to prove the world wrong
#1591 |
Member#: 179846
NWIC
installed the pump! Went smooth had to trim the plastic tip of the pump tiny bit and bend the bottom bracket! Soldered the wires and used 2 layers of shrink wrap.
![]() ![]() Using stock FPC for now, and just tested it at idle sounds little quieter than DW300, and makes noise like old CRT monitor ![]() |
#1592 |
Member#: 103631
Vehicle:2004 STI Black |
How is the direct port running?
#1593 |
Member#: 179846
NWIC
#1594 |
Member#: 193757
What injectors are you using? I know that ID's do not have good response to fuel pressure changes. I know this because I chose to run older disc style DW 1100's because they respond to fuel pressure changes. My 1100's will flow 1300cc's at 4 bar/ 60 psi which will give me the fuel requirements for 500WHP on E85. Along with a Walbro 400 E85 pump direct wired with 12 gauge wire.
#1595 | |
Member#: 124282
NWIC
![]() ID1000's and ID2000's perform great all the way up to 100psi base pressure, WITH correct latency and flow data all the way up there. You are misinformed. ![]() ![]() |
#1596 |
Member#: 193757
No, what I am saying is their flow does not change as much as other injectors at different fuel pressures. I know they flow well at all pressures. What I was saying is that you can get higher flows from higher pressure with some DW injectors.
#1597 | ||
Member#: 124282
NWIC
Basically, your 1100's -- assuming the 1100cc rating is accurate -- can only flow at a very theoretical max of 1283cc with the stated pressure increase. 3 bar to 4 bar is a 33.3% (1/3) increase in pressure, which means a 1/6th (16.6%) increase to flow rate, or 1100 * (1 + 1/6) = 1283.33. All injectors are subject to the same principles of fluid dynamics ![]() Because I love math -- note that the ID1000 and ID2000 flow goes up by ~16.26% and ~15.73%, respectively, when pressure is increased from 3 bar to 4 bar. The theoretical increase should be 16.6%. Not a coincidence ![]() Last edited by lancelucas; 11-22-2012 at 06:07 PM. |
#1598 | |
Member#: 103631
If you use taps you can just remove it. If the duty cycle goes down then its likely not the pump. |
#1599 | |
Member#: 193757
#1600 | |
Member#: 134949
VIC
Is fuel pressure dropping up top? I'm running 40-42 psi base with engine running. Time for a Bosch 044? ![]() |
| Thread Tools | |
| Display Modes | |
| Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band | Maxwell Power | Proven Power Bragging | 563 | 05-16-2012 08:28 PM |
| Maxwell Power Services aka GetaDomTune | AwaySooner | Vendor Reviews | 7 | 03-11-2010 03:54 PM |
| +1 for Dom/Maxwell Power | Jeff54 | Vancouver Impreza Club Forum -- VIC | 22 | 09-02-2009 02:22 PM |
| My new Maxwell Power Services engine is almost in !!! | leonbmx | North West Impreza Club Forum -- NWIC | 13 | 03-23-2009 10:28 AM |
