Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 11-23-2012, 08:21 PM   #1626
CatfaceType-R
Member#: 81102
Originally Posted by Md05STI View Post
a dump tube burning through a power steering line.
I had this happen, scared the **** out of me. Luckily I caught it, quickly and went to a braided line.
CatfaceType-R is offline   Reply With Quote
Old 11-23-2012, 08:35 PM   #1627
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Me too and unfortunately that car burned to the ground.
Old 11-23-2012, 09:49 PM   #1628
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
bumped the fuel pressure about 4 psi and duty cycle lowered about 10%
with this pump working i can hear fuel running threw lines when car is off so weird lol
Little bit of wires under seat
Bariga is offline   Reply With Quote
Old 11-24-2012, 07:57 AM   #1629
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Nice man ^ .
stretchedk7 is offline   Reply With Quote
Old 11-24-2012, 09:07 AM   #1630
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Holy ****
Remind me to sit in your car next time and play me some tunes...
alcoolaid is offline   Reply With Quote
Old 11-24-2012, 09:09 AM   #1631
alcoolaid
Member#: 134949
'07 SWP STi
And my surge tank setup from a while back. Aluminum fire wall behind it.
Still can fit 2x 18x10 wheels with 275's on them in the back along with some luggage.
Old 11-24-2012, 06:13 PM   #1632
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Originally Posted by alcoolaid View Post
Still 101%? Damn. I'm in the 8x% range with a little more boost.
Is fuel pressure dropping up top?
I'm running 40-42 psi base with engine running.
Time for a Bosch 044?
no comment
or http://www.radiumauto.com/blog-page....l-Pump-Test-73
Old 11-24-2012, 07:55 PM   #1633
alcoolaid
Member#: 134949
'07 SWP STi
Still seems like you're have flow problems? Time to upgrade the feed line lol
Old 11-24-2012, 08:41 PM   #1634
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
after i bumped pressure 5 psi duty cycle lowered.
Old 11-24-2012, 08:51 PM   #1635
alcoolaid
Member#: 134949
'07 SWP STi
Bump it up to 45 at idle
Old 11-26-2012, 12:56 AM   #1636
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
its about 47
Old 11-26-2012, 01:49 AM   #1637
IAMBANARSEE
Member#: 338931
Good results ... I plan on running the EFR in my build, don't know which of em yet ...!
IAMBANARSEE is offline   Reply With Quote
Old 11-26-2012, 03:52 AM   #1638
alcoolaid
Member#: 134949
'07 SWP STi
its about 47
still high duty cycle?
Old 11-26-2012, 11:56 AM   #1639
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
i saw 110% the other day on highway, AFR was 10.6 at redline.
Not sure wtf is going on lol, peak fuel pressure is about 80
Boost is perfect, adjusted IAT WG map for cold temps
Old 11-26-2012, 12:09 PM   #1640
Maxwell Power
Member#: 190729
You must be calculating duty cycle improperly.
Maxwell Power is offline   Reply With Quote
Old 11-26-2012, 01:19 PM   #1641
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
that's what i'm thinking, how come Arthur's shows in 80's ?
Old 11-26-2012, 02:31 PM   #1642
Maxwell Power
Member#: 190729
We should check your injection method. Maybe Arthur is doing two injections and you're doing one.
Old 11-26-2012, 02:35 PM   #1643
alcoolaid
Member#: 134949
'07 SWP STi
I just looked at my ECU statistics the other day and the highest duty cycle I have ever gone to is 91.7%... then I looked at max engine RPM and it was like 9100rpm. Holy shiet!
Old 11-26-2012, 02:45 PM   #1644
alcoolaid
Member#: 134949
'07 SWP STi
Per Vipec:
This is the percentage injector duty cycle being applied to the injectors. A value of 100% indicates that the injectors are on continuously.
Note: In practice it is wise to leave some margin with the duty cycle remaining below 90% at full power. If higher values are required then this indicates an inadequate fuel supply system or undersized injectors.
Doesn't seem like we can change anything... what's your fuel master? 10ms?
And i'm on the standard sequential injection.
Old 11-26-2012, 04:43 PM   #1645
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
11ms on mine, and everything else is same
if i drop it to 10 its gets lean almost 1.5 afr
Old 11-26-2012, 06:46 PM   #1646
KurtP
Member#: 44836
1999 Fozzy
Is this a single scroll or a twin scroll set up?
Looks like a very fun power curve.
KurtP is offline   Reply With Quote
Old 11-27-2012, 12:52 PM   #1647
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
twin scroll
Old 11-27-2012, 05:51 PM   #1648
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
3d gear full spool at 3900rpm 25 psi, boost is flat line to red line thanks to perrin's dual port actuator, mac 4 port solenoid and vipec's boost control system
i leaned out the fuel at redline to 11 as it was 10.8 with meth and duty droped a bit.
i will probably be buying new ID1500
Old 11-27-2012, 05:53 PM   #1649
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
Nice!
Z0rr0 is offline   Reply With Quote
Old 11-27-2012, 06:01 PM   #1650
Maxwell Power
Member#: 190729
you need to send me your current map!
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 634 06-11-2016 02:34 AM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 03:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 02:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 10:28 AM
