Old 01-15-2013, 01:11 AM   #1776
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
so with walbro 400 and bumped fuel pressure my max duty cycles are around 90%, was 105% before.
Bariga is offline   Reply With Quote
Old 01-15-2013, 10:06 AM   #1777
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
Did you rewire the pump as well? if not, that should provide even more fuel.
Z0rr0 is offline   Reply With Quote
Old 01-15-2013, 11:56 AM   #1778
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
yep rewired, to 100% all the time.
Old 01-15-2013, 12:31 PM   #1779
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
I'm surprised you didn't just do like 10% IDC or something for your high toggle. That way for just cruising its fine
Or is the delay noticable when you're flogging it?
Layvon is offline   Reply With Quote
Old 01-15-2013, 12:35 PM   #1780
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
cant do! stock fuel pump controller was keeping my rely from cutting off, so i took that **** out.
Old 01-15-2013, 12:42 PM   #1781
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
Oh okay. I have my 044s using that relay too hopefully I don't have issue.
The relay itself is only pushing a W255 for surge so it shouldn't be a problem. Thanks again for the help. It was cool seeing how you do Meth injection. I'm not going to but it was neat to see how you did
Old 01-17-2013, 02:59 PM   #1782
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
this is what EFR should of come with
http://www.bmturbosystems.com/en/pro...ktuatoren.html
Old 01-22-2013, 11:24 PM   #1783
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
going on dyno this Saturday for final numbers with upgraded fuel pump "walbro 460"!
Old 01-23-2013, 12:11 AM   #1784
monkiboy
Member#: 202958
2008 wrx
anton, good luck!
i'm living through this and a couple other EFR builds while i wait for my 7670 EWG EFR. will you have video or photos posted?
i'm excited to see what she does, sir!
monkiboy is offline   Reply With Quote
Old 01-23-2013, 12:44 AM   #1785
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Do you have any predictions Anton?
Old 01-23-2013, 04:30 AM   #1786
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
I want to find a way to mount my dslr to recaro seat, so i can do 1080p videos. As far as getting on dyno id like dom to take a look at fuel and timing to see if its spot on and see if my top end improved with bigger fuel pump, before i was getting 105-110% duty cyles at 25 psi @ 6000 rpm
Old 01-23-2013, 06:37 AM   #1787
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Anton, What pump were you running before you installed the Walbro 400?
I made 535 WHP on E85, 26 psi at 7k with the Dom 3.5xtr (58 lb/ min.), DW 1100's, Walbro 465, re-wired, Aeromotive FPR at 50 psi and I was at 80% IDC.
I now have the ID 1k injectors in my car and I saw 28 psi up to 7k rpm in 4th gear and my IDC's were 81% at the same base fuel pressure on E85.
Based on what I made it seems like you should see a drop in your IDC's with this pump and hopefully holding more power out longer.
Old 01-23-2013, 11:37 AM   #1788
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
yeah max IDC with bumped pressure is about 90% now
Old 01-23-2013, 12:12 PM   #1789
manitou
Member#: 193757
2006 XTI Limited
What base pressure are you running through which regulator?
Old 01-23-2013, 01:17 PM   #1790
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
At warmed up idle fuel pressure gauge reads 49 psi
Old 01-26-2013, 12:46 PM   #1791
kellygnsd
Member#: 32669
LINK G4 hybrid STi
What time is the tune today Anton?
Old 01-26-2013, 11:31 PM   #1792
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
It was more of a check up then tune, everything was spot on except WG-2 boost "it was dipping like 2 psi in some areas", i had to tweak that after dyno on road spend like 4 hours and got it flat, tested on hill and it was about .5 psi over but still flat so that's good.
IWG just sucks.... but i have to deal with it.
Car made same power about 515 to wheel with meth at 24 psi & full boost at 4k.
Old 01-26-2013, 11:38 PM   #1793
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Yeah the clean up tune on the street really just puts the icing on the cake
Slimsti is offline   Reply With Quote
Old 01-28-2013, 10:34 AM   #1794
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Closed loop or open loop boost control?
Old 01-28-2013, 11:17 AM   #1795
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
closed loop, other wise it would never work lol
Old 01-29-2013, 09:29 PM   #1796
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
just noticed my fuel pressure drops when bass hits "around 4 psi drop"
Old 01-29-2013, 11:47 PM   #1797
manitou
Member#: 193757
2006 XTI Limited
just noticed my fuel pressure drops when bass hits around 4 psi
Hahaha!! Turn the volume down
Old 01-30-2013, 06:39 PM   #1798
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
This setup gives me better WG resolution and i'm able to make boost flat to redline.
To maintain 25 psi my WG duty cycles goes like this 24,26,28,30,32,35,37
Old 01-30-2013, 07:41 PM   #1799
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Going to do any racing this year?
Drag racing or HPDE?
alcoolaid is offline   Reply With Quote
Old 01-31-2013, 12:13 AM   #1800
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
thinking about it, if they will have 250 dollar no license days. Cant afford the license yet
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 608 05-02-2016 06:54 PM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 03:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 02:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 10:28 AM
